Question about Hotpoint Washing Machines
I have a Hotpoint WMA10P washing machine, which I carried out the Maintenance wash cycle recommended in the manual, the programme stopped, left water in the drum, the indicator lights had all gone off & found steam coming out of the dispenser. Since then I've checked the drain hose to checked if there was a blockage, which emptied the water, but now if you try to set a programme the door locked light flashes. Does any one have any ideas, what the fault is please?
  • Hotpoint Master
  • 1,830 Answers
Try to unplug the washing machine and then plugging it back in. This might reset the washer.
Posted on Jun 10, 2017
  • Pamela Leach
    Pamela Leach Jun 10, 2017
    Try unplugging it from the wall and then plugging it back in.
    See if that changes anything.
SOURCE: we have a hotpoint wd420
you have a blocked pipe - where the water is draining out. Either that or your filter is blocked.
best you open the back and take a look at the filter before calling out hotpoint - might save you 100 pound call out charge.
Posted on Oct 18, 2008
beltronic205
  • 1474 Answers
SOURCE: Door latch broken on hotpoint wt761g washing
Depending on which part has gone, some hotpoints door trim post snaps which makes too much play not allowing door to open, in this case needs new door trim. others need drum to be empty of all Water, or could be door interlock faulty .give it a slight bang with your hand to ease open, remember has a 3 min delay on door....
Posted on Nov 20, 2009
barkencoa
  • 3463 Answers
SOURCE: Hoover hpe 236. water not draining, stops mid cycle, lights flash
Have you checked the pump filter, and or that the pump is actually working. if it spins o/k with no water in, then I would suspect a draining problem.
If filter clean and pump o/k, then it could be a control module fault. if this were the case, then it would probably be wiser to purchase a new washer.
Hope this is of some help to you.
Posted on Jan 16, 2010
  • 353 Answers
SOURCE: i have an electrolux EWX14440W Washing machine,
could be your door interlock is faulty
Posted on Mar 02, 2010
SOURCE: Bosch classixx 1000 washing machine - stops on spin
Washing machine stops at the spin cycle - light flashes. Have to drain water out manually. Happened last week and was then able to run an empty rinse cycle. Machine worked normally for another week. Same problem today but have had to drain water manually from the drum after trying an empty 90 wash and rinse cycle (both stopped on the Spin and flashed). Any ideas? Thanks. x
Posted on Mar 21, 2010
Hi my hotpoint washing machine wont stop spinning for some reason any ideas what is wrong
Very likely that the filter is blocked. Because the machine senses there is still water present it carries on spinning but the blocked filter is preventing the machine emptying. Turn off the power at the plug. The filter is usually mounted at the front near to the floor. Unscrew counter clockwise and be prepared for some water to leak out. Clean the filter under a tap, it will probably looked blocked and then re fit. Select a short programme cycle and see if the fault is cured.
Jul 04, 2010 | Washing Machines
Stopping mid cycle, not taking softner, doing a
OKAY.....Could be cold water not entering the machine , due to turned off. or faulty valve coil not too expensive to fix...
May 24, 2010 | Washing Machines
Hotpoint wma76 stops and displays ON
Could be rinse water valve ..Faulty Solonoid coil
Nov 10, 2009 | Hotpoint WMA76 Front Load Washer
Wash machine stays on wash cycle and doesnt go to rinse or spin
If the water is not getting hot, this will probably stop the programme advancing .Check heater.
Plz rate solution to prob.
Dec 10, 2008 | Hotpoint Aquarius WF000 Front Load Washer
Clothes still wet after fast spin cycle
Belt loose or motor / motor control board possibly defective
Sep 13, 2017 | Hotpoint Aquarius WF000 Front Load Washer
Hotpoint first edition takes in water but does not wash
Could possibly be a broken drive belt to the motor or motor brushes may need replacing.
Oct 28, 2008 | Hotpoint First Edition FEW12 Front Load...
Display panel (cont.)
hi there try pressing and holding the start button for about eight seconds
Oct 10, 2007 | Hotpoint Aquarius WD640 Front Load...
Hotpoint WD440
On the power pcb panel, there is an eeprom. This gets corrupted and throws the machine into a frenzy. A replacement should include a new pcb and a new eeprom. Only from dealers unfortunately.
Aug 28, 2007 | Hotpoint Aquarius WD63 Front Load...
Washing Machines Logo
66 people viewed this question
Top Hotpoint Washing Machines Experts
vince
gbob59
Eric Taylor
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
