Question about Cameras
I have a Nikon D 70 and I was setting my menu and practice shooting and now when I am in P program I cant get a center focus it focus to the right.
    Legend:
    An expert who has written 200 answers of more than 400 characters.
  • 480 Answers
Dear Ericrach,
What is most likely happening is that the focus lock selector switch is set to the lock position. If this is the case just unlock the switch and you should be able to move the focus point to any one of the 5 focus positions (with the multi selector buttom).
Sincerely,
Allan
Go Ahead. Use Us.
Posted on Apr 22, 2008
Nikon s8100 focuses only in center and rest has a
You need to replace the lens assembly. Aspherical lens needs precise placement of all elements.
Feb 15, 2012 | Nikon S8100 Digital Camera
Why wont my Nikon af nikkor 70-300mm G lens autofocus its self with my D5000 camera
The D5000 does not have a focus motor in the body, relying on the lens to have one. The old 70-300mm G lens does not have a focus motor, relying on the camera to have one. Thus, this combination will not autofocus.
The newer 70-300mm AF-S G lens, as well as the even newer 70-300mm VR AF-S lens, do have the autofocus motor and thus will autofocus on the D5000.
Dec 26, 2011 | Nikon AF 70-300mm f/4-5.6 G Nikkor Lens
The camera is set on Auto. The pictures are a blur, not in focus. Is there a way to set up good focus?
Revie manual here:
User Guide.pdf
This your camera:
Nikon Coolpix 775
1.check your lens camera is clean and clear.
You have to choices, auto and scene.
What happen when you choose scene mode?
2. test change your image quality to normal. you can go to menu even in shooting mode.
3.change image to normal and back to shooting mode and try again
It is same ?blur?
4.if still blur, try go to menu mode again, at left side you can find BSS.
5 IF BSS is off.. change it on. if it is on, change it off.
6.go to shooting mode again.
that all. good luck and rate me..tq
May 12, 2011 | Nikon Coolpix 775 Digital Camera
How fix the back focus of Nikon AF 70-300mm f/4.5-5.6G? unable to focus whatever adjust made from the lens.
Hello marion.... Rutn the camera on and open up the menu. Find the reset function and reset the camera. All that does is reset it to the factory settings, the settings it had when you first took it out of the box. In most instances this will fix the problem. If it does, great. If not, take it or send it into a Nikon repair shop. Opening it up your self will void the warranty. Joe
thanks for choosing Fixya!
Jan 12, 2011 | Nikon Zoom Telephoto AF Zoom Nikkor...
I have a brand new nikon coolpix s3000. it's on full-time auto focus. Any ideas?
You can change this in the menu while in shooting mode. This is from page 48 of the manual:
Choose how the camera focuses.
A (auto) M d (Shooting menu) M I Autofocus mode
A Single AF (default setting)
The camera focuses when the shutter-release button is pressed halfway.
B Full-time AF
The camera focuses continuously until the shutter-release button is pressed down
halfway. Use with moving subjects. The sound of lens drive movement will be heard
while the camera focuses.
Sep 28, 2010 | Nikon Coolpix S3000 Digital Camera
Focus On My Subject
Change your metering mode to spot metering. Focus on your subject with half-press of shutter button...hold that press while you re-compose the picture and press the rest of the way. See if you get better results.
Apr 07, 2010 | Nikon D200 Body Only Digital Camera
Shutter frame rate drops to about 1 per sec on CH with MB D10 while using any auto focus lens. 14-24,24-70 or 70-200 and an older 20mm auto focus. With no lens or a manual focus, very old 55mm Micro, lens...
Wow, that's weird. Does it do it with the auto-focus switch on the body turned to manual? I shoot a D300 and know pretty much everything about it there is to know and the D700 is basically the same camera with a full frame sensor. The only things I know of that drop CH frame rate are shooting in 16-bit raw and it shouldn't kill it like that, using full-auto with tracking will also cause a lag in auto-focus but that still doesn't seem right here. If it only does it with the auto focus on then it may have trash on the AF screen in the camera and needs to be cleaned. Try setting the body switch to manual focus, remove the grip and shoot jpeg and see if it still happens. If it does, reset the menu settings and try again. If it still does it than you probably need to give it a trip to Nikon. If it quits than start putting things back one at a time until you figure out what is doing it.
Somebody told me that Nikon will clean the pro cameras for free once a year while under warranty, I haven't looked into it yet to make sure.
Nov 01, 2009 | Nikon D700 Digital Camera
Focus problems with Nikon D700
use center fous mode dont keep multi focusing mode
Jun 17, 2009 | Nikon D700 Digital Camera
Will Nikon D300 focus with the 11 point AF11 setting?
You may want to consider fine tuning the lenses. I understand that you want the shallow depth of field, but the lens is sharpest at the middle f stops. What is the comparison between a stationary object like an apple or grape (something with a circular shape). I understand you have a higher shutter speed, but the small movements of a person could cause variances in a single focus mode. Are you using the half-shutter press for focus or the AF-E button? Tripod? Remote shutter release?
I asked about the distance relative to the lens length because the DOF can really change based on this. I have found this recently with my macro work so I wanted to find out if you have experimented with this or fired a bunch of shots at a single setup.
Apr 27, 2009 | Nikon D300 Digital Camera
Over-exposure with AF Nikkor 70-300 telephoto
Friends have you tried not using the A-Aperture mode?? Set in on P-for Program or M-for Manual, this should produce the colors you are hoping for. If your photo is still "hot" use the + or - button called the Exposure compensation button on the top of the camera, push that little button and turn the outside main control dial where your right thumb sits 1 third stop at a time, (you have 4 to 5) The + adds light to your photo and the - will make your photos darker play with that and let me know. Barry Brown www.coralreefphotos.com
Jun 26, 2008 | Nikon D70s Digital Camera
Cameras Logo
67 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
