Question about Konica Minolta PagePro 1400 Laser Printer
Paper not going in
The paper is not being taken in the paper. what could be the problem? no error light is blinking.
  • wagih Mar 04, 2009
    when printing it stops sudenlley
  • 101 Answers
Check the paper path, make sure the cassette spring bounce up went you load
Posted on Apr 22, 2008
Blinking Light with no cartridge problems My HP Deskjet D1460 has its light blinking with no status messages that suggests an error. However, I am unable to print as the light keeps blinking. Could...
Hi
this problem has many reasons :
- no paper or error in paper feed sensor.
- jammed paper in printer thats prevent it continue.
- try to disconnect usb cable and if its stop lighting reinstall the driver
- else you must search about hardware errors
Apr 26, 2011 | HP DeskJet D1460 InkJet Printer
Paper stops half way
Please check for torn piece in the carriage which is causing the error
Jul 06, 2008 | Canon PIXMA iP4200 InkJet Photo Printer
The red hazard light is lit on my hp2550 printer. The job has been cancelled the printer turned off and leads taken out but still no joy. Would you please advise. Thank you
Please check out the manual, available here: http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?lang=en&cc=us&taskId=110&prodSeriesId=388394&prodTypeId=18972&prodSeriesId=388394&objectID=c00159488#A39
What that light means depends on the blinking pattern of it, and the other lights on the printer. You find a description of the errors on the above page.
Nov 16, 2010 | HP LaserJet 2550n Printer
Paper Jam
Remove ink cartidge, undo clips first and give it a tug upwards, you should see the paper. Shut machine & restart.
Jan 10, 2010 | Brother HL 2140 Laser Printer
5C00 error on Canon iP90 printer
The alternate flashing of orange and green indicates a service call error, something that needs to be taken into a canon authorized service facility for repair. 4 alternate blinking of these lights indicates a problem with the purge unit, most likely requiring replacement.
May 21, 2009 | Canon Office Equipment & Supplies
Samsung printer ml 1510 red light flashes after self test
Red Error Light Stays On The following conditions can cause the On Line LED to glow solid red:
  • Printer paper is jammed inside your printer.
  • A cover is not be closed properly.
  • The toner cartridge is not inserted properly and needs to be reinstalled.
  • The toner cartridge is running low.
  • There is no paper in the paper tray.
  • The paper inside the paper tray is not be installed correctly.
Red Error Light Blinks If your printer's On Line LED is blinking red, your printer's toner is exhausted and needs to be replaced. On Line and Error Light Blink Simultaneously
If your printer's On Line and Toner Save LEDs blink simultaneously, your printer requires service.
You can go to samsung online service request http://www.samsung.com/us/support/repaironline/supportOnlineServiceRequest.do
Mar 21, 2009 | Samsung ML 1510 Laser Printer
Light keeps flashing red,amber, green
If you turn off the printer and turn it back on, do you get any noises, ie motor noises, or does it instantly go to all lights flashing?
If you get no noises this usually indicates a board fault and you should look for a new printer.
Apr 07, 2008 | Brother HL 5140 Laser Printer
Error light, can't find the problem
Hi, you should check the position of paper sensor flag, called "actuator" (part number 4139 3505 02). On the picture - part 15. The "paper jam" error message means also - "toner cartidge missing", "paper out" or "photoconductor missing" e8dd7eb.gif
Sep 12, 2007 | Minolta magicolor 2400W Laser Printer
Konica Minolta PagePro 1400 Laser Printer Logo
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
