Question about Linksys Wireless-G Broadband Router
Just stopped working. all lights light up - but
Just stopped working. all lights light up - but internet does not work Linksys wireless-g broadband router
  • 700 Answers
You did not post model, you did not post what operating system on your computer either. general help therefore only can be provided. if you post required data, then i can provide more detailed instructions how to check your router.
disconnect all cables from the router, including power cable, wait about 20sec then insert cable connecting to the computer, insert cabel connecting your telephone line and then insert power cable.
in about 2min router should connect itself to the line and to the computer.
check if you have valid ip address on your computer (in most linksys routers it will look someting like: 192.168.1.***), that will meant that router did establish connection with computer. check if you can connect to the internet (through the cable!), if you can, this meant that your router is working correctly, so is your computer. disconnect cable and check if you can connect via wireless, if yes, problem is solved, if you cannot, check and compare settings between your computer and router, problem ususally is wrong credentials on the computer or wrong protocol. both of these must be same on the router and on the computer.
if you use wep, wep must be in both, on router and on the computer, if you use network name johnny, exactly this same spelling in router and computer must follow, same with password. and do not use spaces in passwords! especially if you use password on every login...
Posted on Jul 22, 2010
My road runner internet works fine, and for years my linksys srx200 wireless has worked great, just yesterday my wireless connection is excellent as always but our laptops all say cannot connect to the...
Hi
If you have an internet connection using the ethernet cable but not on the wireless and there is an orange light blinking.. Try to reset the router by pressing the reset button located on the back or on the location were you can twist the stand for the router. press it for about 10secs and that will return the router on a factory settings. before u reset the router make sure to acces the configuration for the internet settings of your isp provider. if the orange light still there, try to download the latest firmware of your router on linksys site and that should fix the problem
Jun 10, 2011 | Linksys WRT54GX2 Wireless-G Broadband...
Router stopped working.
As long as the power light stays solid, then the router is fine. You need to reconfigure the router for it to receive internet connection from the modem.
May 17, 2010 | Linksys Wireless-G Broadband Router
Setting Up a Wireless Network
You can still use your existing Linksys router with your cable modem. In fact the router your have is designed to work with DSL/Cable Broadband connections.
1. Make sure to properly connec the devices in your network. Modem will be connected to the Internet port of the router. Then, laptop will be connected to one of the 4 Ethernet ports of the router. For initial setup of your router with modem, you need to hardwire laptop to the router.
2. Press and hold reset at the back of the router for about 15 seconds.
3. After 15 seconds turn off the router and then turn off the modem. Wait for a minute.
4. Power on modem and wait for the lights to be ready.
5. When modem lights are on, turn on router.
6. There should be 4 lights on. Power should be steady green. Internet, WLAN and Ethernet port.
7. Checked if you have Internet connectivity on your laptop while it is wired to the router.
8. If Internet is working, disconnect laptop from wired connection to the router and check available wireless network that laptop can detect.
9. The default wireless network name that the Linksys router broadcasts is "linksys". Connect to it which is an unsecured wireless network.
10. Once you are successfully connected, check Internet.
Hope this helps!
Nov 16, 2008 | Linksys Wireless-G Broadband Router
Linksys Wireless-G BroadBand Router
Who is your ISP (Internet Service Provider)?
If you're using a Cable provider, do the ff. steps. (For Linksys router)
1. Launch Internet Explorer and type http://192.168.1.1
2. It will prompt you for username and password. Leave it blank on username and type admin for the password.
3. Under SETUP tab, click the sub-tab MAC Address Clone. The click the button Clone My PC's MAC. Then click on Save Settings.
4. Unplug the power to the modem and the router for 30 secs. After that, power on the modem first, wait for all lights to go solid then power on the router. Check if the internet works.
Hope this helps.
Jul 19, 2008 | Linksys Wireless-G Broadband Router
LInksys wireless router stopped working
Who is your internet service provider and what is the model no. and brand of your modem?
Jun 01, 2008 | Linksys BEFW11S4 Wireless-B Broadband...
Router works with wire not wireless
there are lots of thing ht can be done like enviroment chek
wep key config ,firewall setting, go one by one minimize the firewall then try to ping it
to to network connection set it up again
this time with proper wep key and in enviroment make sure ur router is not near a carpet or microwave or any plant
May 22, 2008 | Linksys Wireless-G Broadband Router
If the power light on the router is Blinking very Fast .
Then Reset the router fro 30 sec and then leave the power cable unplug for 1 min .
Then plug the power plug back in and then check ............if the power light stop light stop blinking then the router can be reused or else the router has gone bad
Mar 09, 2008 | Linksys Wireless-G Broadband Router
Linksys Wireless-G Broadband Router Logo
114 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
