First go to: Canon MP210 Support
In the box, type replace ink cartridge. Click Search.
One of the top options given will be just that. Click on the link and it will give step by step instructions with pictures and animations for replacing them. (Note that the model used may not be your exact model, but the procedure will be the same.)
Thanks for using Fixya.
SOURCE: reseting mp210
i've refilled mp210 both cartridges.do you know how to reset the printer?cause it's show error 6,please help
SOURCE: Canon PIXMA MP210
Hi. This might be stating the obvious, but try cleaning the contacts in the printer and on the cartridge with isopropal alcohol. I have a Canon Pixma MP520 which I have had for most of this year now, and it works fine. I am not sure if I will be buying another Canon printer after the problems I have just read on FixYa though! Another thing you might try is carefully bending the contacts on the printer that touch the copper strips on the cartridge to ensure they touch properly. I have not looked too closely at mine, but I presume there must be copper contacts of some sort that are spring loaded, which press up against the contacts on the cartridge when it is installed. Hope that helps.
SOURCE: Canon pixma mp210 printer -
Dear merryan,
This printer uses FINE cartridge which has memory chip inside that store ink level data. Once the cartridge is EMPTY we cannot restore this data to be FULL even though we physically refill ink until FULL. So the printer keep displays NO INK warning.
Similar with using compatible cartridge, NO INK warning still remain because ink level data has been recorded as empty. Why?. Here is the explanation. As far as I know no third party compatible cartridge produced this printer since canon protect it with the chip. Compatible cartridge that sold in the market is refurbish cartridge which repacked with another brand.
To fix this problem we need to deactivate ink level detection function by holding down STOP/RESET button for about 9 seconds or more for each cartridge. The consequence of this is ink level become UNKNOWN.
Hope this will be helpful to you
Regards,
Xanda
SOURCE: Installed new cartridge in canon pixma mp210 & now can't print
The printer needed to be reset.
Unhook the printer then take out the new cartridges.
try to very gently clean the contacts also make sure the contact on the new cartridges is clean.
Let it dry for a few minutes assembly.
Plug it. My printer is reset by pressing the start button and hold it down until it beeps 6 times.
You can check your manual how to reset yours.
I hope it work for you.
