When using word 2007 how do you bring the ruler up and keep it up? Regards Jack
  • Jack Woolfe Jul 22, 2010
    I thank Taran 2005,
    Worked perfect and so quick.
    Thank You Regards Jack.
  • 10,515 Answers
1. Click the "View" tab in the ribbon at the top of Word 2007.
2. In the "Show/Hide" group, check "Ruler" to enable the horizontal and vertical rulers.
Look at the below image :-
http://office.microsoft.com/en-us/word-help/show-or-hide-the-rulers-HA010102271.aspx
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Jul 22, 2010
I have a sapphire 930 and would like to quilt using rulers but I need to know what shank size I have to get in order to use a ruler foot for my machine?
You can probably figure out which shank works on your machine:
Sewing Presser Feet
You'll just need to get a darning or free motion foot because they are shorter than regular feet which allows space to manipulate the fabric.
HOWEVER, some machines require different presser feet for use with rulers. The presser foot is actually deeper so it will not "jump" on top of the ruler while stitching. Some recommend Westalee rulers because they are thicker.
Dec 04, 2017 | Sewing Machines
What size speakers fit the Suzuki Swift 2007?
stock car?
stock speakers/?
front or rear.
round ?
if round use a ruler and bingo. size.? 4 inche is 4inch, like that.
impedance must match too. 8 ohms, or other?
Mar 14, 2015 | 2006 Suzuki Swift
What size is axle nut for a jeep compass
Depending on the year, it is either a 32mm or 36mm. Most likely 36mm.
Jun 30, 2014 | 2007 Jeep Compass Limited
What size are the exhaust pipes on a 2007 nissian sentra 2.0s
USE A RULER OR 4 INCH MICROMETER USE TO MEASURE PISTON DIAMETER.
Aug 20, 2011 | 2007 Nissan Sentra 2.0 SL Sedan
Office 2007 product key
It comes with the product. If you loose the key then you cannot use/install the package.
Aug 24, 2009 | Microsoft Office Professional 2007 Full...
Jack / Cord problem
yes basically if you look at the jack end you should see where the join is it may unsrew then look at the wires in side and the looose one should be seen if not yu can get a new jack from most online electronics Maplin -RS- or any electronics supplier you will need to resolder the wires onto the new connector..make sure you keep the other snipped off connector for reference when resoldering new.. There are a few tips to soldering.. maker sure the wire is twisted before soldering and touch the wire to the solder tip then bring teh solder wire to the wire to tin (melt solder) the end then do the same with other wires. once the wires are tinned bring to plate on teh connector and touch wire to connector and then solder tip to where wire and connector are.. if you keep teh soldering iron on the connection to long you may melt the plastic jack surround so I usually use a metal jack type.. if it has three wires one is for left one for right and one earth..copy the old jack wiring and you should be ok.. Good Luck A
Aug 04, 2009 | Audio Players & Recorders
How do i get the ruler at the top of the page?
What versión of Microsoft Office are you using?.
If you are using Office 2007 you can go to the view menu and then mark the "Ruler" checkbox on the second panel from left to right, that will enable the ruler on the top of the page, if you double click the ruler you can adjust margins and spacing.
hope this helps,
Regards,
Mar 07, 2009 | Microsoft Windows Vista Ultimate Edition
Using Calcomp 6 drawing board in corel draw and signwizard 4.1
I don't know about Signwizard but if Corel Draw is the problem, this might help. Double click on the ruler or...Go to tools and open the Options dialogue box. Click Document then click Guidelines then Rulers. The right panel should show a button the says Edit Scale. Click that. Make a note of what's there before you change anything.
You can calibrate the rulers to real-world distance too.
1. Click Tools Options.
2. In the Toolbox list of categories, double-click Toolbox, and click Zoom, hand tool.
3. Click Calibrate rulers.
4. Place a clear plastic ruler under the on-screen horizontal ruler.
5. Click the up or down arrows on the Horizontal box to match one unit of measurement on the on-screen ruler with one unit of measurement on the actual ruler.
6. Place the ruler beside the on-screen vertical ruler.
7. Click the up or down arrows on the Vertical box to match one unit of measurement on the on-screen ruler with one unit of measurement on the actual ruler.
Jan 07, 2009 | GTCO Calcomp 44"x60" SuperL III Digitizer...
Computers & Internet Logo
19 people viewed this question
David Payne
David Payne
