How do I find the year my Carrier A/C was put in my house?
The serial # first 4 #s are the date of manufacture. probobly was installed soon after being manufactured
Posted on May 03, 2008
Heat exchanger replacement for carrier weathermaker 8000
After 18 years of service, it is not cost effective to just replace the heat exchanger. Go the complete replacement route. There may be a utility company incentive to do it.
Jun 06, 2016 | Carrier Weathermaker 8000 Gas Furnace 125k...
Im replacing the clutches in a chrysler 8.25 rear end and cant get the spider gear washer back in. My ? Is can i pull the center section to put them in and if i do will i have to readjust anything to...
the spider gear washers are located at the back of the spider gears and to remove/replace them then the diff carrier has to be split. IF you have the diff in your hand but cannot put it back in the housing then what you are referring to are the side bearing preload shims (washers) If you have the diff that comes out of the back of the housing leaving the pinion behind then on either side of the housing when the axle tubes go into the housing you will see 2 round holes ( about 5/8" dia) there is a rectangular tool that picks up these holes and by the use of a spreader bar actually bends the housing enough to slide the shims in to place. when you pulled the centre out you probably need a pry bar to do so and that would have been the preload on the side bearings of the carrier.
Oct 29, 2014 | Chrysler Cars & Trucks
Air conditioner model # 38ckc 42..350 not working, keeps tripping the breakers, had electrician check out and stated it was the fan or the compressor, i bought the house in 2009, was built in 2005, what do...
Hi, if that is a 2005 carrier condenser, it may still have a warranty on the compressor. You need to copy down model and serial #, call the local Carrier rep and ask. That is your right to do so. The fan is probably not in warranty, but it is definitely worth replacing if it is bad. I sold carrier for 15 years, and sold many with 10 year parts warranty. First thing you need to do if you haven't done so is check on your warranty! If you can explain what it is doing a little more in detail I could probably tell you exactly what is wrong. Hope this helps.
Jun 23, 2011 | Carrier 38CKC042 Air Conditioner
We require condenser fan motors for Interclisa Carrier package (rooftop) air conditioner model AAD 250 (1980's model) model. Air conditioner - supply voltage 380 Volts 50 Hz AC. Condenser fan motor voltage...
Hi, this is an odd voltage 380 volts. Is it a 3 phase unit? To get a 220 volt 50hz condenser fan motor, you will have to go through a refrigeration/air conditioning parts house and order this. 60hz you would have no problem finding one in stock. Carrier is a good unit, and have been around for many years. You shouldn't have any problems locating one.
Sincerely,
Shastalaker7
PS You will need to go through a wholesale parts house.
Jan 21, 2010 | Carrier Heating & Cooling
How to remove rear axle 03 chevy silverado
You will have to remove the rear end plate off of the back of the rear end. Then turn the carrier untill you see a big silver pin that goes through the spider gears. Those will be 4 small gears in the rear end carrier. If you look at the right side of the carrier were the pin goes through it you will see a small bolt head, That bolt goes through the carrier and holds the pin in place. Remove that bolt then reach up in the rear end housing and push the pin towards you untill it comes out. ( DO NOT TURN ANYTHING AFTER YOU REMOVE THE PIN) are the spider gears will fall out.
Now get someone to push the axel in while you are looking at the 4 small gears in the housing, when they push the axel in a C-clip will fall off the end of the axel and into the rear end, You will see it fall out. Then just pull the axel out.
When you put the axel back in, push it all the way in then slide the c-clip over the end of the axel and then pull out on axel and that will hold the clip in place untill you put the big long pin back in the carrier. I hope you understand, just watch what you are doing. GOOD LUCK.
Oct 09, 2009 | 2003 GMC Yukon
Carrier Product # 38BRC042320
This unit was manufactured 1/8/00 and is a 4 1/2 system
Sep 30, 2008 | Carrier 38CKC036 Air Conditioner
Inside house is warm
Use the spell check and please restate your issue. Have you checked your air filter? Has the unit been serviced recently?
Sep 04, 2008 | Carrier 38CKC036 Air Conditioner
Carrier 38CK036330
The model numbers change.You have a 3 ton system.The make and model that you replace it with is not nearly as important as a quality install.Do your homework on picking a contractor that you can trust.Have them do a load calculation to make sure a 3ton system is right for your house.13 seer is the minimum you can get.You need to weigh the projected annual savings of higher seer units against the added cost of having them installed.Again,get a contractor you trust and go with the best warranty.None were stupid questions.
Jul 08, 2008 | Carrier 38CKC060 Air Conditioner
Heating & Cooling Logo
56 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
