Question about Nixon Key Men's Watch - Gunmetal Dial - Black Band
When I try to unclip the crown to set the time, the whole crown comes out! If I screw it partially back in and try turning it the hands do not move??
Set reserve indicator on invicta 6106
Here is how to set the Invicta 6106 Invicta 6107 and other similar models with the ISASWISS 8173 movement with the following functions:
TIME - DATE - DAY - ALARM - GMT - POWER RESERVE
DO THINGS IN THIS ORDER AND YOU WILL FIND IT TO BE VERY EASY! After you understand how to set ALL the functions you can skip steps later to set individual functions but for now just do it exactly step by step:
1. Unscrew the center crown (if it is a screw down crown) and pull it all the way out (this is position 2) and turn it until you see the DAY sub-dial at the 6:00 position set to the day BEFORE today. There is no QUICK SET for the day on this movement so you must just keep turning the crown and hour hand past 12 midnight and watch the day pointer until it gets to the day you want - the day BEFORE today.
2. Now set the time to 6:00 (am or pm doesn't matter at this point). This is very important because you do not want the time to be between 9:00pm and 12:00pm when you set the date later on - we are using 6:00 just to be safe.
3. Push the crown all the way in - you don't have to screw it down.
4. Now pull out the crown very gently to the 1st position - just one "click" out. Now turn the crown AWAY from you to set the date to the date BEFORE today - this appears in the small window at the 4:00 position.
5. Now pull the crown all the way out again to position 2 and turn it away from you until it goes past 12 midnight and TODAY's DAY AND DATE are showing and then adjust the hour and minute hands to the current time - be sure to set the hour to AM or PM and push the crown all the way in. If you wish to set the seconds exactly - with the crown pushed in watch until the small seconds hand in the sub-dial at 2:00 is exactly at 60 and then pull the crown out to Position 2. Set the time ahead a minute or so and push the crown in when the actual time is the time you have set - you can set it to atomic clock time on the internet or by another watch that sets itself to atomic time.
6. Now the DAY, DATE and TIME are set to current. Now when the hour hand passes 12 at midnight tonight the DAY and DATE will advance correctly.
YOU CAN STOP HERE IF YOU WISH - but you can continue on to set the ALARM and the GMT indicators as follows:
7. To set the GMT hand (the one with the red-bordered pointer) the crown is pushed all the way in and screwed down. Now simply hold the bottom pusher in for a few seconds until you hear a beep - now you can start pushing it and watch the GMT hand moving - one push at a time for small adjustment or hold it down to make it move faster. When you stop pushing it another beep indicates that it is OUT of the setting mode - so if you want to adjust it again just hold it in until short beep and start pushing the lower pusher same as above.
Understanding GMT (or second time zone): Note that the GMT hand time is indicated on the 24 hour dial (think in military time where 3:00AM is 0300 and 3:00PM is 1500) using the very small numbers around the very outside of the dial. When the local time is 3:00PM if GMT is adjusted for the SAME TIME ZONE as you are in now the GMT HAND will be pointing at the small "15" which is between the 7:00 and 8:00 hour markers. If the local time is 3:00AM and the GMT is adjusted for the SAME TIME ZONE as you are in now the GMT HAND will be pointing at the small "3" between the 1:00 and 2:00 hour markers. So lets say you are in Pacific Time Zone and it is now 3:00pm local time and showing on the minute and hour hands - and for example you want the GMT hand to show Eastern (New York) time which is 6:00pm (in military time that is 1800 indicated by the very small 18 which aligns with 9:00) - hold in the bottom pusher until you hear a beep - now start pushing it in short increments or hold it down to move it faster until it points to small 18 (large 9). Now the GMT will indicate the hour in the EASTERN time zone while the main hour hand indicates your local time.
7. To set the ALARM - unscrew the crown and pull it to Position 1. Turn it TOWARDS you (if you turn it way from you will set the date which you don't want to do) and you will see the hand with the white pointer and the word "Alarm" in tiny writing on it move clockwise. Set the ALARM to the time you want. Push in the crown and screw it down.
8. To activate the ALARM push the TOP PUSHER once - the small hand in the POWER RESERVE sub-dial will move slightly and then it will move again (give it a second or so) and you will hear a BEEP - now the alarm is activated and the small hand points to the "ON" label. When the alarm sounds if you wish to stop it push the top pusher. But it will stop on its own and then repeat a few minutes later - you can just leave it alone if you wish. Note that the Alarm will turn OFF after sounding - so if you want to wake up for work on time tomorrow be sure the ALARM indicator is pointing to "ON".
9. To deactivate the ALARM when the small hand is pointing towards the "ON" label simply push the top pusher again and and the small hand will move clockwise down to the "OFF" label.
10. POWER RESERVE sub-dial. To align the Power Reserve sub-dial hand (after battery change) pull the crown out to Position 1 and push the top pusher until the hand points to 0%. Push the crown back in and screw it down.
11. Reserve Indicator - the instructions for this movement states that holding down the top pusher for 3 seconds will move the POWER RESERVE hand to the power reserve scale - but this is confusing because the hand never actually stays on the power reserve scale - it will only stay on "ON" or on "OFF".
However - I believe that this is the way it works. When you push the top pusher with the small hand in the "OFF" position it will momentarily move to the power reserve scale and stop for a second before it moves again to "ON" - I believe that this reading indicates the POWER RESERVE just before it moves again to the "ON" position..
Jan 03, 2012 | Invicta Reserve Watches
SETTING DATE&TIME
i cant get a manual for this but watches have standard mechanical function so maybe this will do.
the center crown of the watch right side of the picture, loosen the crown. Be careful, some crown have a screw function so if your bulova has this don't force to pull it to prevent damage. if you have loosen the crown, check if can be turn it, if yes pull gently the crown, first pull date adjust,second pull time adjust.
This is the proper way to adjust you day and time.
say you want to adjust your watch to (date)10th (time)10:15am
adjust your date to 9th, then move your watch hands clockwise until the date change at 12oclock this is the evening time (PM) continue moving your watch hands until you reach 10:15am.
if your crown is a screw time remember to turn it close tightly for waterproofing.
Dec 13, 2010 | Accutron BULOVA men's 26B62
I've lost the owner's instructions and need directions for setting the alarm.
  • Unscrew the crown (the main knob on the center right side of the watch casing), wait until the second hand is at the 12 o'clock position, and pull the crown knob up so that it clicks once.
  • 2 Press the button below the crown knob repeatedly until the hands of the alarm dial point to the time within the next 12 hours that you want the alarm to ring. Pressing the button once will move the alarm one minute forward. Pressing and holding the button will move the alarm forward quickly.
  • 3 Pull the crown knob one click further out and turn to adjust the main hands to the correct time, to take into account the time you took to set the alarm.
  • 4 Push the crown knob two clicks back into its normal position, and screw it into place until it locks.
  • Aug 20, 2010 | Pulsar PXH225 Watch
    Manuel for yacht timer 700 please. Best regards P.Hessner
    Could not find a download for instructions on this watch, but I did manage to find some basic instructions for the Sector brand. I hope this helps as this is the best I can come up with.
    Good luck.
    Sector Chronograph Watch Instructions
  • Most chronograph watches have screw-down crowns for water resistance. You must unscrew the watch crown before you can make any changes to the watch time. After time is set screw the crown back in. To utilize the chronograph dials, use the buttons on the side of the watch. One button will be for the second timer. Press once for the second hand to start timing. Press again to stop it. Another button will be to reset the second hand timer back to zero. Sector Chronograph watches may have different dial functions (see link in References).
  • Sector Dual-Time Watch Instructions
  • Because Sector watches are known for their sports capabilities, the Dual-Time watches have screw-down crowns. For Dual-Time timepieces, unscrew the crown counterclockwise. Pull the crown to middle position to set the date. Pull the crown out to its fully extended position and rotate it to set the day of the week, hour and time. Press and hold in the crown and turn clockwise to seal the crown back in to the watch.
  • Sector Ana-Digi Watch Instructions
  • Sector Ana-Digi timepieces have analog hands plus digital timekeeping functionality. To set the time, unscrew the crown counterclockwise and then clockwise to the appropriate time. The digital functionalities are programmed by the buttons on the side of the case. Depending on the style of the Sector watch, you can set the digital time with one button, set the date display, 1/100 seconds chronograph timer, altimeter, thermometer and alarm functions.
  • Aug 12, 2010 | Sector 700 2653700025 Watch
    How to set and use the subdial on my invicta model 5749 gmt watch
    While I'm not familiar with that particular model, most GMT hands are set by turning the crown "backwards" in the date setting position. IOW, if you set the date by pulling the crown out to the first detent and turning it clockwise, turning it counter-clockwise will set the GMT indicator.
    Apr 10, 2010 | Bulova Watch
    Setting a cartier chronograph watch
    1. click the top button to stop the second hand
    2. click the bottom button to reset the timer
    3. pull the crown out all the way
    4. twist the crown forward hard and fast for a few seconds. The minute hand will start advancing very quickly.
    5. when the desired date and time is reached, push the crown back in place. If you missed the time, pull the crown back out and twist backwards. The minute hand will move slowly in reverse. If you twist hard and fast, the minute hand will start spinning in reverse again.
    Sep 15, 2009 | Cartier Tank Francaise Chronograph White...
    How do I set date & time?
    usually breitlings have a screw-in crown with a gasket for diving. If you cannot pull the crown away from the case, try unscrewing it. After a little pressure to the left, the crown should begin to turn. Unscrew it carefully and you should be able to pull it out one stop for the date and all the way (note second hand stops) to set the time. Be careful pushing it back in and screwing it back down. You don't want to potentially damage the threads. The crown is back in place when you ca't screw it in any more and the "B" is straight up and down
    May 06, 2009 | Breitling Aerospace 455 Wrist Watch
    Need instructions on National Geographic Men's watch #NG010GYSK
    go to Buliva web site and look for the chorograph 561/598
    FEATURES
    1. Hours, minutes, seconds and date display.
    2. 60 minute Chronograph (CHRONO) with minutes and
    seconds display.
    3. 24 hour hand, permanently synchronized with the normal
    12 hour hand.
    A. SETTING THE TIME
    1. Pull the crown out to position “3” (See diagram). If the crown has
    a “screw-down” lock, then unscrew the crown lock first by turning
    the crown toward you, then pull it to position “3”. Do not forget to
    screw the crown back “IN” after all setting is completed.
    2. Turn the crown towards you (hands moves clockwise) until the
    date changes at approximately midnight.
    3. Continue turning the hour and minute hands to the correct time.
    If it is afternoon you must go past 12 o’clock again (noon) to set
    the correct time.
    4. When the correct time is set,push crown back to position “1”.
    B. SETTING THE DATE
    1. Pull crown to position “2”(See proceeding diagram).The watch
    will continue to run.
    2. Turn the crown away from you until the correct date appears.
    3. Once the date is set, push the crown back to position “1”.
    Note: Do NOT set the date between the hours of 8:00 PM and
    3:00 AM.This would not damage the watch,but the date may need
    to be reset later.
    C. CHRONOGRAPH (CHRONO) ADJUSTMENT
    If the chrongraph second hand is not positioned at the proper
    starting position (12 o’clock or “zero” position), use the below
    procedure.It does not need to be repeated unless the watch
    receives an impact sufficient to move the hand out of position, or
    the Battery has been changed.
    1. Pull crown out to position “3”.
    2. Push button “A” to move the Chrono Second hand (long hand) to
    the “0” or 12 o’clock position. Each button push will move the
    hand one step – BUT holding the button down will advance the
    hand rapidly.
    3. Push crown back to position “1”.
    D. USING THE CHRONOGRAPH (CHRONO)
    Note:
    The maximum chrono reading is 60 minutes, However the
    chrono will continue running once 60 minutes has passed. The
    resulting one hour periods may be added together mentally to keep
    track of longer periods.
    For example – If you know that approximately one hour has
    passed since you started the chronograph, and the chrono reads
    25 minutes, then you know that the chrono has been running 60
    minutes plus 25 minutes, which is one hour and 25 minutes.
    1. Push Button “A” to start the chronograph. Push button “A” again
    to stop the chronograph.
    2. Push button “B” to return the two chronograph hands to the
    “Zero” or starting point.
    3. The Chronograph can be stopped and started again
    (Button “A”), repeatedly, to “ADD” times together.
    BOOK NO. 561/598 Chrono FS00/01/10
    Watch Setting Guide
    4/2007
    Feb 13, 2009 | Bulova Watch
    How do you set and deactivate the alarm function.
    I did find two authorized dealers:
    www.kenmarwatches.com
    www.princetownwatches.com
    Contact both and request users manual fur your specific model. They must be able to help.
    Jan 05, 2009 | Bulova Watch
    Steinhausen watch adjustment?
    To set time, you need to unscrew crown anti-clockwise direction if you have a screw-in crown watch. You need to softly and slowly pull the crown out a little bit. The best way to do this is to use first and second finger and use finger knuckle as a lever in order to pull the crown out with as little force as possible. You can feel a little "click"! Now you can set the time by turning it anti-clockwise. This would turn the minute-hour hands forward until you set the right time. When time is set, push the button back and screw the crown clockwise for a few rounds to ensure it is screwed back tight.
    May 12, 2008 | Watches
    Nixon Key Men's Watch - Gunmetal Dial - Black Band Logo
    110 people viewed this question
    Top Nixon Watches Experts
    Ansel Alberto
    Ansel Alberto
    rhodesworks
    Are you a Nixon Watch Expert? Answer questions, earn points and help others
