Hi, When my washing machine finish wash normall the cloth should be spinned. But this week the cloth in are still very wet after it finish the wash. And I try to play "spin" only, it does not move at all. Do you think I need to get a new washing machine or this problem is solvable?
  • 15,935 Answers
It is likely the lid switch acting up - as a safety precaution - the tub will not spin unless the lid is shut.
If the switch fails - the machine does not know the lid is closed, and will not spin.
Replacing the switch is about $20usd and having it done for you would be about $60-80 USD.
Is good to have someone experienced replace it for you - as it requires removing the shroud of the washer to get at the switch.
Thanks!!
Posted on Jul 22, 2010
I just purchased my Cabrio washer...have had it a week. When I use the normal cycle, the machine does not spin the clothes at the end of it so when they cycle is done the clothes are dripping wet. I then...
I have had my Cabrio washer a little over a year. No it isn't suppose to do that. There is a setting for spinning high medium and low spin. Maybe you can change the spin setting manually. See if that works The washer is computer operated so the spinning cycle must be out on your normal cycle. I did myself a favor and I keep all clothes on towels and sheets. I set the temp for the water on what I would like manually. The washer fills up with more water and seems to clean the clothes better and My washer does the same thing from time to time about not spinning. Just remember you can set all wash manually with water temp and spin cycle. Is your washer still under warrenty?
Jan 03, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
Spin cycle is not working. clothes are soaking wet when cycle is finished.
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Dec 21, 2010 | Whirlpool Ultimate Care II LSQ9564J Top...
Water not spinning out. clothes still wet when finished spinning.
check that you have water going down the machine drain pipe when the machine would normally be draining, if not could be a faulty water pump or a water pump blockage the machine is spinning whilst still full of water I am suprised you can open the door after the wash has completed
Jan 16, 2010 | Washing Machines
My zanussi washing machine fj1033 finishes normal wash progam but doesnt go into hihg spin therefore clothes are wet rather than damp.if i turn dial to spin cycle only it works that way.please advise.
If you have not already done so, then check and clean the pump filter, this is usually located at the bottom right front of washer, behind a drop down cover or flap.
Unscrew anti-clockwise to remove and clean.
Jan 08, 2010 | Washing Machines
Wet clothes
the reason the clothes are wet is the washer is not shifting to high spin,does the washer have a speed switch(normal wash spin,high wash spin)if its not the speed switch than the clutch is bad,how old is the washer?mike
Apr 19, 2009 | Kenmore 24032\24036 Top Load Washer
Ca230 w. machine not spinning leaving clothe wet, no water in drm
It is possible that the belt at the back of the machine is slipping. try running the spin cycle without any load in the machine. I assume this is a front loading machine and you are in UK. the Belt is available on line for about 15 pounds.
If it is running the washing cycles normally, it can't be the motor.
Dec 06, 2017 | GE S8000E
Model 110 washer will not go into a final high speed spin.
hi, i would suggest the timer/programmer is faultyas it is ok on the other cycles, the noises you have described may have caused some damage,
Feb 10, 2009 | Washing Machines
Dripping wet clothes
will be an UNBalanced load, maybe there was not enough clothes in the load so in that case the drum would not be able to distribute the load evenly so gave up on the spin, hence wet stuff!
Jan 27, 2009 | Haier Washing Machines
Bosch classixx 1000 washing machine - stops on spin
Washing machine stops at the spin cycle - light flashes. Have to drain water out manually. Happened last week and was then able to run an empty rinse cycle. Machine worked normally for another week. Same problem today but have had to drain water manually from the drum after trying an empty 90 wash and rinse cycle (both stopped on the Spin and flashed). Any ideas? Thanks. x
Apr 29, 2008 | Bosch Classixx WVF 240S Front Load Washer...
Top load does not spin dry the clothes
Transmission or solenoid that should pick and put transmission into spin. I bet it's a kenmore or similar.
Mar 08, 2008 | Washing Machines
Washing Machines Logo
21 people viewed this question
Top Washing Machines Experts
