Question about Zanussi FC1200W Front Load Washer
Hi my zanussi 1221w washing machine stinks. I regularly empty and check the pump filter and the emergency drain. I have used calgon, bleach 95 degree empty wash cycle but it smells like there is a dirty stagnant mop in my washer still. I have the machine on its side and was hoping to find something underneath that might solve my problem but I cannot see anything untoward and need to know if I should remove a particular part to check further. I am clueless with what everything is. Please help
    President:
  • 2,468 Answers
Check the door boot just inside the door for dark spots on the gray rubber boot and the drain hole in the boot it can grow mold where the water stands in it from previous washings and this mold will smell like raw sewage from all the soap and softener that aids in mold growth
Posted on Jul 22, 2010
Testimonial: "Thank you I will check this again. I did clean the rubber seal recently but it does seem to accumulate slime. Can ya use bleach on the seal?"
Slow spin flashing lights zanussi 1221w
http://laundry.manualsonline.com/manuals/mfg/zanussi/zwf_1221w.html?p=20
how many lights
and is the drain system fully clear and the pump working
check obvious things looks plugs or bad connections {blasted to carbon and melted thru resistance build up over time}
other than this please post more details of the lights on etc
this could be lack of current to drive the motor fully
bad brushes on the motor or a bad capacitor...
Mar 09, 2015 | Zanussi Washing Machines
Hi my zanussi washing machine will only spin slowly and there is scale in the drum and on the clothes
the evacuation pump is either blocked up
or not running
i would remove the blockages
then run through an empty load cycle of 95deg white wash and some calgon tablets
Zanussi z918 washing machine wont empty or spin although the pump seems to work
if the pump seems to work, check outlet hose for blockage/check pump filter as well
Dec 09, 2011 | Zanussi Washing Machines
My zanussi f1045w wont drain, have emptied the emergency drain and cleared pump and is still holding water how do i get into pump and check it thourly
Sorry but I do not know your particular machine but see if these guidance notes help---------->
Here are my complete, general pre-typed guidance notes for checking filters and motors ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and most are held in by a round cover/knob.
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. If it doesn't work then the motor is malfunctioning!
Hope the filter is the problem and good luck!
John C
Mar 13, 2011 | Zanussi F1045W Front Load Washer
Machine clogged and rust and stink
to help clean the unit, do a large load of whites, extra bleach, extra-super-heavy-duty wash, hot wash and hot rinse. many small loads sometimes cause the unit to "smell up"
Sep 04, 2009 | LG WM2077CW XL Front Load Stackable Washer...
Zanussi washing machine, conditioner doesn't empty
If you are having a problem with your top load washer then check out this tip...
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
May 14, 2009 | Zanussi ZWF1430W Front Load Washer
Zanussi washing machine won't start E10, E40 & E50 at times
It was suggested that the pump had failed and taken out the programmer with it - expensive! Wife wouldn't wait, and bought new machine. Problem almost solved - anyone want an out of order washing machine?
Feb 03, 2009 | Zanussi ZWF1440 Front Load Washer
Zanussi ZWF1437W E23
E23 indicates Drain pump faulty; Wiring faulty; PCB faulty.
The service information also says it should stop with the door open.
Unplug the appliance and manually remove the water via the filter or front drain point if it's fitted.
Drain it into a shallow dish, tighten the filter when you need to stop the water (or plug the hose if draining via a hose) while you empty the container.
Once empty, try the door again.
Take the filter out and clean out any debris in it.
Plug the appliance in and put the machine on a drain programe.
Listen/look at the open filter to check that the drain pump is running.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jan 27, 2009 | Washing Machines
Zanussi Aquacycle 1200
Pump jammed or filter blocked, check filter if not blocked remove pump and replace if faulty. Regards Advisor
Aug 01, 2007 | Zanussi FJS1225W Front Load Washer
Zanussi FC1200W Front Load Washer Logo
369 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
