Question about Carrier XHD183D Air Conditioner
Compressor is fine but the blower doesn`t work how can i fix it?
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 50 Answers
In all honesty, it probably will cost you more to fix it than to replace it. Almost all Carrier motors are OEM, which means you can not get an after market replacement. If you want to give it a try, you can contact Pierce-Phelps (branches in Pennsylvania) through www.peirce.com/ They can tell you if the part is available. Good luck.
Posted on Jul 22, 2010
I have a 2005 Mercury Mountaineer Premier 4.6 liter. A/C blows cold however the blower in dash cuts on and off thru dashboard from 0-50 works fine above the blower in dash doesn't blow.
Strange for blower but not unusually for compressor. The usual high or low limit switch would cut off the compressor but not the blower. Maybe check alternator and battery voltage to see if there is a voltage problem. The blower motor resistance switch is problematic but I have not heard of one acting like yours.
May 04, 2018 | Mercury Cars & Trucks
2003 Toyota Corolla AC Blower/Fan will not turn on, I replaced the Blower/Fan a few weeks ago,
A/c compressor works fine and the blower motor works and shutdown right? it is the problem with the blower resistor or with blower motor relay. try to direct the resistor irrespective of the speed. hope the problem may be solved.
Jun 05, 2014 | 2003 Toyota Corolla
My Air cond, heat and vent doesn't work at all on my car. I have replaced fuses and the blower motor. Whenever I put the new motor in it would run then blow the fuses. Could it be the compressor?
No, the compressor will NOT cause these fuses to blow. You have a SHORT in your electrical system. you have a HOT wire getting into the Ground for that system
Apr 09, 2013 | 2002 Mercury Sable
Model Number: UACC-036JAS The unit works fine. The problem is it doesn't shut down after the specified temperature has been reached. The furnace blower shuts down, but the ac unit keeps on running....
Hello, usually a stuck contactor coil will cause this on the outside unit. When the outdoor unit runs continously and the indoor blower does not run no heat is being absoebed by the evaporator coil and thus the line freezes. Replaceing the contactor will fix the problem.
Aug 30, 2011 | Ruud Heating & Cooling
I have numerous proglems. I have a 2000 intrique. The right back signal light blinks very fast, doesn't work in the front. The ac blower works fine but blows warm air.A mechanic , someone my hysband...
Your rear turn signal flashes fast because the front is not working. Most likely you have a burnt out bulb in the front. If your A/C compressor can be turned over by hand and doesn't lock up or make any clanking sounds it's probably alright. The compressor will not run if the system is low on refrigerant. If you're having problems with the A/C and heater controls, that would be the first ting to repair. It doesn't sound at all like any electrical problems.
Jul 20, 2011 | 2000 Oldsmobile Intrigue
--2005 GMC Envoy AC Trouble--(compressor still active) Have replaced blower motor (original one had "burn" evidence), resistor and resistor connector. The blower is still not working. Have...
SOUND LIKE BAD BLOWER MOTOR RESISTOR.CHECK BLOWER MOTOR HI BLOW FUSE AND RELAY.YOU WILL NEED OWNERS MANUAL IN GLOVE COMPARTMENT TO LOCATED BLOWER MOTOR FUSES AND RELAYS.
Jun 06, 2011 | GMC Envoy Cars & Trucks
AC compressor works fine, Blower does not. How do you repair?
check the fuse in the fan-fan relay-check voltage at the terminals of the blower if you have the voltage problem is to check the blower motor of the blower speed control
Aug 11, 2009 | 2006 GMC Sierra
AC blower won't come on
The problem is most likely the AC compressor clutch connector. It is a one pin connector. Located under the hood, near the clutch of the AC compressor. Clean this connector, make sure there is a good connection. I had the same problem and had to fix it myself. Works fine ever since.
Aug 11, 2009 | 2004 Kia Sorento
Carrier XHD183D Air Conditioner Logo
Top Carrier Heating & Cooling Experts
Bill Long
Tim Whalen
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
