Question about Canon PIXMA iP2000 InkJet Printer
Just refill our black ink for canon pixma ip 1200 and it gives out lines in beetwen image. How can i fix? it says it needs to unclogged but i kept cleaning through maintenance tab and result is still the same.
  • june3t May 09, 2017
    Try this which I am using in my Canon ink jet printer with continuous ink system.
    Buy a 10 ml Syringe with needle. Open you printer and set the cartridge in the middle. if you notice that there is no ink in the plastic tube of the ink system, Using the syringe, get about 8 ml of ink from the reservoir or ink container. Close both caps of the reservoir. Insert the syringe ink on the bigger rubber cap and inject the ink just enough that the ink reaches the printer cartridge.Close the printer cover and
    perform several cleaning maintenance on the printer. good luck!
  • 4 Answers
Posted on May 09, 2017
  • Canon Master
  • 6,826 Answers
Canon recommends genuine canon ink jet cartridges. If you bought a remanufactured ink jet cartridge and it did this, I would return it immediately.
But, since you filled it yourself, there's no recourse with the ink company, I don't believe.
Even if you were successful with refilling, they can only be refilled 2 or 3 times at best.
Posted on Jul 22, 2010
Canon pixma ip2772 cartridge cannot be recognized
Pleas help me.
I have a Canon Pixma ip 2772 Printer, I used Original Canon ink Cartridge and it after refill. now i using original canon black and color cartridge but now have a problem. ink cartridge not recognized i used original cartridge 4.. pls. help me immediate
Jul 20, 2012 | Canon PIXMA Office Equipment & Supplies
My new pixma canon ip 2770 cannot recognize the black and colored ink
i am having canon pixma ip 2700 inkjet printer. it worked properly till. I got refilled both cartridge and fix it in my printer but the cartridge was not recognized. i had tried installing the cartridge many times and also tried switch off and on it again many times but the printer shows the same error that "An error occurred.Some ink cartridges cannot be recognized." and a message box is opened and it shows that "An ink cartridge is not installed properly.Open the printer's cover, make sure the ink cartridge is installed properly, and close the cover." help me to recover from this problem i can't afford to buy new cartridges. suggest me some ideas and procedures to
May 08, 2011 | Canon Pixma iP2700 InkJet Photo Printer
My canon PIXMA iP 4000 does'nt write out the colours, only black.
Use the Canon software to check the ink-levels in the COLOUR cartridge. If empty, replace it.
Use the Canon software to run a few "print-head-cleaning" cycles, to unclog any ink-jets that are not spraying ink onto the paper.
Feb 22, 2011 | Canon PIXMA iP4000 InkJet Photo Printer
My Canon Pixma IP1980 print has lines and color is not even, to much green.
I have refilled my canon iP 1980 printer catridges and I am currently encountering 2 problems:
a) The notification telling me that the ink is running low wil not dissapear.
b) There are lines across my documents when I print them. Those lines resemble those that occur when the ink is running out. however, I have already refilled it twice and am quite sure that the catridge is now full.
Please help--your advise will be greatly appreciated.
Jun 09, 2010 | Canon PIXMA iP1800 InkJet Photo Printer
Put new black canon 3-e ink in canon Pixma ip 5000 black line of print have a white horizontal stripe through center. I don't seem to have a repair utility t o clean heads and align. Mac OS 10.4.11
The clean heads option should be in the Preferences/Maintenance tab where you go to do other things, e.g. alignment, ink counter reset, etc. If you cannot see this, you mmay need to reinstall the driver for the printer. You could also ask Canon. Finally, if the catridge is a refill or compatible, try a genuine Canon black cartridge.
Apr 25, 2010 | Canon PIXMA iP5000 InkJet Photo Printer
I have refilled my main black ink cartridge on my canon pixma ip 3600, my printer won't acknowledge the refilled cartridge, is there anything I can do about this?
This is because the ink cartridges has a memory chip.It monitor ink levels.Press and hold the resume button for 5 seconds.This operation releases the function for detecting the remaining ink level of the above ink.The printer shows empty cartridges but it will printing.
Nov 03, 2009 | Canon PIXMA iP3000 InkJet Photo Printer
Black and Colour Ink Low Messages - Canon MP180
You have to look online for the canon tool to reset the ink counters. When you refill these cartridges you have to run this program in order to re-use the cartridges.
Jul 03, 2009 | Canon PIXMA MP170 All-In-One InkJet...
Ip 1200 Pixma Cannon Printer Cartridge Installation Problem
i want to download the driner of canon pixma iP200
Oct 11, 2008 | Office Equipment & Supplies
How to Override Ink Level Gauge When Using Refilled Cartridges
This maybe in the manual under ink tank replacement, most cannons have this, but keep in mind that sometimes the ink feed tubes to the print head get clogged and then the printer will report no ink at all, these cansometimes be cleaned by soaking them in acholol
May 28, 2008 | Canon PIXMA iP3300 InkJet Photo Printer
The ink absorber is full for pixma 1880
This is the REAL working method of manually resetting Canon ip1880 - ip 1980.
1. Unplug the POWER cord.
2. Press & hold the power button.
3. Connect the power cord WHILE holding the power button.
4. Keep on holding the power button for about 30 seconds.
5. Release the power button. The printer should be turned off.
6. Turn the printer on and that's it!
NOTE: You have to do this every time you turn on your printer. Or you will get the waste pad full error.
Hope this helps.
vulmec.wordpress.com
Jan 15, 2008 | Office Equipment & Supplies
Canon PIXMA iP2000 InkJet Printer Logo
107 people viewed this question
old marine
old marine
