Why does laptop stop working through adaptor after battery flat
    Problem Solver:
  • 8 Answers
I put my dell2600 away for two mounth,today i try to turn it on no rresponce even with the adp. cord plug in. need help
Posted on Mar 27, 2011
  • 734 Answers
Hi There,
Your battery charger/adapter connects to the DC Power Jack to power your laptop and charge the battery. Since the charger/adapter does 2 things, there are 2 "cells" inside it to do those 2 different things. It's not uncommon for one or the other (but not both) to fail. So, often just purchasing a new charger/adapter solves the problem you're having. It appears that yours is continuing to charge but has stopped "adapting" AC current to DC current to power the laptop directly.
Posted on Jul 22, 2010
2 ac adaptors have stopped working on acer laptop
Take the battery out. Unplug the charger from the computer. Press the On button for 30 seconds. Then plug the charger in. If it works, then put the battery back in and you're in business again.
If it still can't work, perhaps the charger you bought is a dead one, just contact the seller to get a replacement one after all you have used it for about a few minutes. If you don't believe in that seller, just contact them for the refund and go to other vendor for a new adapter. I recommend the following one for you:
http://www.chargerbuy.com/replacement-acer-aspire-5739g-ac-adapter-19v-4-74a.html
http://www.chargerbuy.com/replacement-acer-aspire-5738-ac-adapter-19v-3-42a.html
Oct 26, 2012 | Lifetime Acer Aspire 5738PG Replacement...
My toshiba Satelite A200 is hang when AC adaptor is insert
Inserting AC adaptor while computer is working on battery power, may indicate that an arcing occurred and cpu got wrong data to stop sequential operation. You may have to turn on AC adaptor, after it has been inserted into your laptop while using battery power.
Feb 08, 2012 | Computers & Internet
AC Adaptor not working in laptop
the problem is in your laptop...maybe it damaged too when you plugged your old adaptor. you should check your laptop for a repair...maybe it needs to replace tha spare parts that may have been damaged.
Dec 01, 2011 | Computers & Internet
Laptop does not work off mains and battery does not charge
Just check the power connection from the AC going to your laptop if the power adaptor of your laptop are working. Note; you only know that the power adaptor was working if the LED (Light Emiting Diode) was light because the power adaptor are have the LED to see it that they are working normally. If the power adaptor working normally their was a problem of the power supply inside your laptop and need to be repair by the electronic service center. But if the power adaptor are not working the problem are in the power adaptor. I recommend that you replace your power adaptor and bring it to the computer store to check its type and model it is because only same type or model of that power adaptor to be replace.
May 19, 2010 | Dell Inspiron 6000 Notebook
I have a new e627 used only once before today. Battery connection was partially out and screen indicated low battery. After five minutes screen went black and now I cannot power up.
Maybe your battery is totally drained.
Try to connect the AC adaptor of your laptop and plug it to the wall outlet and let it charge for 3 hours or more. When you plug it on the wall socket, it won't show the laptop's led blinking since it was totally drained. But after 3 minutes or more, it will start to show the blinking led to indicate charging. When blinking stops led light disappears, it is fully charged and ready to use.
Remember: Do not use your laptop while it is plugged in to save your battery life. When at home, remove the battery while it is fully charged and plug the AC adaptor directly to the wall outlet. It will still work without the battery as long as it is plugged directly to the wall socket.
Feb 23, 2010 | Computers & Internet
My v2000 will not come on at all? I have it plugged in with the adapter and it's like there is no power to it at all?
check power supply adaptor and batteries if they are supplying enough power, if you can borrow a power adaptor and spare battery try replacing them with one your notebook has.
if it works then your adaptor and batter are out, normaly if the adaptor stops working the battery would have died down too as you would have not noted till the notebook totally died down.
Dec 07, 2009 | HP Compaq Presario V2000 Notebook
My HP laptop cannot be switch on problem with virus
do a power drain
1. shut down the comp
2. unplug the ac adaptor
3. take out the battery
4. without any power connect to the comp
    press and hold the power button for 60 seconds
5.after 60 seconds plug the battery
6. plug the ac adaptor
7. turn on the comp
Oct 20, 2009 | HP Pavilion dv6000z Notebook
Battery light turns off when ac removed
one of the led's has burned out, deal with it! (Windows has a indicator all on its own btw.)
Sep 27, 2009 | ASUS Eee 4G Notebook
Dell Inspiron 5160 won't charge.
wow, ive never seen a computer know what type of adapter is plugged into it... it definately sounds like a power system problem. three parts to this- the adapter, the battery, and the motherboard of the laptop, since that is what interprets and passes on the power from the batter/outlet to the rest of the parts of your computer. we're hoping it isnt the motherboard not recognizing your power subsystem...
but you took a good guess to replace the adapter. you want to make certain the old adapter-- the voltage etc that's written on it in plastic somewhere- that it matches exactly with your replacement adapter. (You just cant plug these thing into any computer it fits into, they have different requirements sometimes, even though theyre all laptops). If it does, then yes, I would assume it's the battery.
Try taking out the battery and running straight off the current, can you do it? Technically, you shouldnt need the battery, it will just act like a desktop computer.
You can get a reasonable aftermarket latop battery for 100-135 bucks, chinese. Compare it to what your manufacturer wants to charge you for a replacement.
BTW- youre out of warrantee, right?
Feb 02, 2009 | Acer Aspire 5100 Notebook
Computers & Internet Logo
78 people viewed this question
Alun Cox
David Payne
David Payne
