Question about Xerox WorkCentre M-24 Color Copier
When I print or copy anything the workcentre 24 prints too far to the right about 1 or 2 inches. I have replaced the fuser cartridge but no better.
    President:
  • 2,072 Answers
Sounds like the registration clutch has failed.
Posted on Aug 02, 2010
Sharp line on print, even all new drumbs
Is it on prints and copies? Or just prints or just copies.
There are 4 likely causes if the line is on both prints and copies. 1 The transfer belt has a scratch on it. 2, The Transfer belt cleaner, called the IBT cleaner is worn, or the fuser has a cut in one of the rolls. Also the 2nd BTR roll located on the left hand door may be damaged.
If the problem is only with copies, then the scanner glasses or mirrors are dirty.
Mar 26, 2011 | Xerox WorkCentre M-24 Color Copier
The copies are dirty, with black long tracks!
I would suggest either a fuser problem, If all Colors affected, or the Black Toner Cartridge. The Below chart may help isolate which component is malfunctioning. Repetitive image defects Measurement Component 24.7 mm (0.97 inch) Developer sleeve (Print Cartridge) 26.7 mm (1.05 inches) Charge roller (Print Cartridge) 32.9 mm (1.3 inches) RS roller 37.7 mm (1.48 inches) Transfer roller (ETB) 54.5 mm (2.15 inches) ETB rollers (ETB) 56.6 mm (2.22 inches) Fuser sleeve (Fusing Assembly) 62.8 mm (2.47 inches) Pressure roller (Fusing Assembly) 75.4 mm (2.97 inches) OPC (Print Cartridge)
Jan 13, 2011 | HP Color LaserJet 2600n Printer
I have a Xerox XD100 black and white copier and it is showing J1 on the display. Wondering what is wrong with it?
J1 is the toner cartridge. Needs to be replaced, printer will not print with a cartridge that is empty.
You can try resetting the Workcentre. Power on, hit "C" then the far left button back and forth 4 times, then enter 14 (like you were going to make 14 copies) hit print. Should clear the code. But if the cartridge is empty the code will return,
Dec 07, 2010 | Xerox WorkCentre XD100 All-In-One Laser...
When printing, the toner does not completely get distributed. Consequently we are left with a "white" line through the print on the right-hand side. The white begins about 7/8ths inches in from edge and...
It can either be the toner cartridge itself, or the fuser.
Try a full cleaning, and if that does not help at all, you will have to replace the toner or fuser or both.
Apr 07, 2010 | Dell 3100cn Laser Printer
Far right side of the text or picture missing on Dell 3100cn.
Refer to the following table
Cause
Solution
How common*
Contamination in the laser path
1. Clean the laser path. (Remove the laser/scanner assembly and clean the lens.) 2. Replace the laser/scanner assembly
8
Defective fuser.
Replace the fuser assembly
Lack of toner or faulty toner cartridge.
Redistribute the toner in the toner cartridge. If the problem continues, replace the toner cartridge.
7
Sep 30, 2009 | Dell 3100cn Laser Printer
Color printed copy appeared unbalance, one side is light.
Please do the following
1) Take the Ink cartridge out and shake it well.
2) Wipe the print head with a tissue to eliminate all dried ink particales.
Once dont please insert the cart ridge again and try printing
Please rate the fix
Feb 14, 2009 | Xerox WorkCentre M-24 Color Copier
Streaks in prints
What I would do is remove all cartridges, wipe the belt w/clean cloth use an air can to clean the machine, check the drum on each cartridge see if there is something, it could be there was a change in Voltage and it burnt the drums. change 1 more toner cartridge to see if that color goes away, if it does then you will know if the drums are the problems.
I've had a problem w gen toners doing the exact same thing, so I had to OEM and it went away. Good luck>
Feb 02, 2009 | Xerox WorkCentre M-24 Color Copier
Black horizontal lines across pages
If they are the same distance apart every time then suspect the problem to be caused by the components in this order First the drum that is in the print or xerographic module, the charge and cleaning roller are located in that module also. So I suspect that first.its .Located above and to the right of the toner cartridge. Secondly it could be the roller on the toner cartridge, that would occur probably every 1 1/2 to 2 inches apart, the drum would cause the defect about every 3 inches. It less likely could be coming from the fuser, and if the fuser was causing that you should also have a lot of jams. There is also a transfer roller on the right hand door that could be causing it, but that would be exceptionally rare.
If the lines are random and have no consistant spacing, I would suspect the power supply then the laser.
Oct 28, 2008 | Xerox WorkCentre M20i All-In-One Laser...
Xerox WorkCentre M-24 Color Copier Logo
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
