Question about Amcor Refrigerators
I have an XL 500 amcor,it does not cool probably. I had gas filled up last week and for a few days it was ok, now it is again heating up. The technician who filled up gas did not find a leak.
5 Suggested Answers
jumptrout51
  • 3361 Answers
SOURCE: Not cooling, unpluged for few hours, it worked fro couple of weeks, stopped cooling again 2 days ago, I unplugged for few hours, It is working now
Your defrost system is bad. Replace the defrost thermostat and defrost heater in the freezer.
Posted on May 26, 2009
  • 212 Answers
SOURCE: Refrigerator Side Not cooling
you right but your problem lies in the defrost cycle. your units defrost timer, defrost thermostat or defrost heater has failed. defrost thermostat and heater are located on the evaporator. both can be ohmed out. when the ice builds up on the evap. your cold air can not be transfered to the fresh food side. make sure the fan on the evaporator is running
Posted on Jun 24, 2009
  • 2671 Answers
SOURCE: Maytag MZD2766GEW side by side refrigerator fridge not cooling
you have a defrost problem, could be bad adaptive defrost board,t-stat heater,when you open freezer door listen for fan if fan is blowing check the t-stat,look at it and see if it has a buldge on it,sometime you can see this and tell it's bad,you'll need a meter to read out the heater and other parts to see whats bad,might be a good idea to call a tech to do this,when you find problem you have to melt everything out again
Posted on Oct 31, 2009
GodBlessU
  • 3513 Answers
SOURCE: My Amcor Wine MV150 stopped cooling
Please check the following link ,hope this will be helpful for you since the product is no longer available...
http://www.winecoolerexpert.com/amcor-wine-cooler-refrigerators.html
Let us know if you want something else please accept the solution.
Thank You for contacting fixya.com
Posted on Apr 11, 2010
Amcor amb 12000e, starts to cool and after a few minutes the unit "shudders" and starts to heat. Not sure why, please advise. Thank you
You are almost out of freon... call a service co... DO NOT run this unit until you get it charged.
Jun 19, 2017 | Amcor Heating & Cooling
Our Lakewood 5101 oil heater gets warm, but over the last few days, it is not getting hot like it used to. It seems like it has slowly been getting colder over the last week or so. I can feel the heat...
Appears you have a heating element issue. Many of these elements are segmented for temp control. If one part goes fubar the heater will work but not put out the heat it used to unless you replace the element with a new one that has no burnt out sections.
May 03, 2017 | Lakewood 5101 Oil Filled Radiator Heater
Two weeks ago i was driving my Sierra pick up deisel 6.5 liter and all of a sudden it felt like my turbo surged and and the engine quit. I was able to pull over and restart it after a few turns and it...
sounds like the fuel driver module is on it's way out
mounted on side of fuel pump square box black in colour held on with 4 screws
and silicone style gasket
i havs replace quit a few over the years runing a fleef of small bus with 6.5 diesel engine
May 25, 2011 | 1992 GMC Sierra C3500
Hi I have an Amcoraire aos121hx mini split, it worked great last summer and this past winter. Haven't used it for a few months and now when I try to get cold or heat it gives a P8 error?
Check the gas pressure by depressing the Schroeder valve under the cap where the gas pipes enter the outdoor unit. you have probably lost some or all of your gas
Apr 21, 2010 | AmcorAire UCHW-H12AF2 Split System Air...
Combi boiler will not fire up for hot water or heating.
check tops of spindles at radiator valves for leaks easy repaired set pressure to .8bar setting at 1.5 may be make overpressure and blow off through high/pressure releasese valve
Nov 30, 2009 | Water Heaters
Central AC unit not cooling
If you have access to your piping system you may use a soap bubbles to test the pipe connection. the leak gas will blow the bubbles if there is leaking. But if your system is out off freon gas, you can not use this method. just try it check the connection first put the bubbles around it.
Jun 04, 2009 | Heating & Cooling
Amcor 12000-E air conditioner will not emit cold air. all filters are clear and hose is vented to outside. I'm about to boil
Hi, I'm new here but have the same model. Is your A/C new? Is your "Mode" set to "Cool" rather than "Fan"? Is the temperature set below room temperature? If not it will just run as fan. Lastly is your water reservoir full? Probably not the problem as the unit will shut off. Looks like you posted this a couple weeks ago, hope you figured it out.
Tim
May 07, 2009 | Amcor ALTL-12000E Portable Air Conditioner
2000 Audi A3 1.8T rough idle / car shaking on acceleration
it honestly could be your sway bars or a track bar in between the tires. as far as the lack of power it could be your fuel filter being clogged or dirty
Mar 11, 2009 | 1989 Chevrolet Camaro
Refrigerators Logo
173 people viewed this question
Top Amcor Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you an Amcor Refrigerator Expert? Answer questions, earn points and help others
