Question about Acer X193W LCD Monitor
How do you tilt up the monitor-it's pointing down
  • 6,826 Answers
Grabe the top and bottom of monitor with two different hands, then torque it up until it slides into the correct viewing angle.
Posted on Jul 22, 2010
  • mazel311 Nov 26, 2010
    that was easy. Thanks
Remove stand of dell monitor lcd stand
Set the face down on a soft surface (pillow). Look at the back of the stand and you'll see a round plastic plug. Using a small pointed tool, pop out the plug. Tilt the stand all the way down and you'll see a Philips screw. Remove it. Wa La!
Jul 10, 2014 | Dell Computers & Internet
How do I adjust the tilt function. It seems it is stuck
Tilting on most Monitors is designed to require some force to prevent it from slipping.
Gently yet firmly hold down the base of the monitor on the desk with one hand. Then place a second hand on the bottom of the screen and pull it towards you using even pressure. It will slowly move.
Please also keep in mind that your monitor may not be able to tilt much. If you need it to tilt further, you can buy an alternative stand for it.
Apr 07, 2011 | Samsung SyncMaster 740BX Monitor
Monitor facing ceiling want it to face me sitting upright
mcdevito75 here, You should be able to hold the monitor at the 9 and 3 O"clock position and simply use your hands to tilt the monitor to it"s desired position, look for any Locking type knobs on the back of the monitor Not the monitor itself but the base, the part the monitor is attached to, if so Loosen knob--s just enough to move monitor then re-tighten when done.
Jun 25, 2010 | HP L1950 LCD Monitor
Tilting Problem with monitor
Screen position adjustment
To optimize the viewing position, you can adjust the monitor tilt by using
both of your hands to hold the edges of the monitor.
The monitor can be adjusted to 15 degrees up or 5 degrees down.
Jun 06, 2009 | Acer 22" X223w LCD Monitor
Monitor Pivot won't turn for the monitor to tilt
If it is crt monitor rotate and tilt up or down. If it is Lcd just push to move front or back.There is nothing to be loosen.
May 04, 2009 | Computers & Internet
Our viewsonic monitor tilts forward. how do we tilt it back?
Hello again.
The ViewSonic VG1930wm has a height adjustment range of 3.2", TILT capabilities, and a swivel range of 360 degrees.
So yes your monitor should be able to tilt back and forth.  Most likely if you hold the base of the monitor, and press somewhere on the front at the top or bottom (do not press on the screen itself) then it should easily tilt back and forth.  Occassionally there is a switch you may have to hold while you push on the front-top/bottom of the monitor which acts as a lock for the tilt angle.
Hope that helps, and don't forget to vote/rate!
Height adjustment range 3.2", tilt, swivel range 360º
Mar 12, 2009 | ViewSonic VG1930WM LCD Monitor
Tilt lg monitor
Press down one of your palms against the base, then at the same time, pull the chin of the monitor upwards.
Dec 31, 2008 | LG Flatron F900P 19" CRT Monitor
X2gen MG19E monitor
The only way to adjust the tilt on these monitors is to loosen the screws that attach the stand to the monitor. We had to completely remove the stand from the monitor to get to these stand screws.
Feb 12, 2008 | X2Gen MG19MY 19" LCD Monitor
Screen tiled and i can't move it back
Try reseting the settings to factory defauts in the monitors user menu. You can get more details from the manual on this.
If reseting the settings doesnt work. Could you take a photo so we would have a better understanding of the problem :-)
Or do you mean the screen is fysically tilted? If parts are broken and you are unable to move the screen, then I cant offer much help, you could contact acer for support or to take it to a local pc shop for analysis.
Feb 08, 2008 | Acer AL2032WD 20" Flat Panel LCD Monitor
Acer X193W LCD Monitor Logo
181 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
