Question about Intex Automatic Salt Water System for Above Ground Saltwater Pool
First year with 18' by 52" pool with the krystal Klear pump is there any other chemicals beside salt I need to add to the pool Bromide etc
    President:
  • Intex Master
  • 1,378 Answers
Thank you for posting your question here on Fixya.com.
Chlorine generators cause pH to rise over time. You will need to balance the pH from time to time using acid. Use a test kit to determine when the correct time is to treat the water. Generally speaking, once the pH is getting up near 7.8 you should add enough acid to drop it back to about 7.2 - 7.4.
If this answer does not fix your problem, please comment with additional details prior to rating the answer. Positive feedback is appreciated once your problem is solved!
John
Posted on Jul 22, 2010
I have a Intex above ground Pool 18 feet by 9 and 52 inches deep. How do I over winter this pool?
no you cant keep an above ground pool full water unless you live in a warm climate area that dont feeze
Oct 19, 2014 | Intex 18 X 52 Ultra Frame Pool Set with...
We have a Krystal Clear Saltwater System Model CS8110. We are first time pool buyers. We set up the pool last week and despite several "boosts" the chlorine level is very low. The pool store...
You should always follow the instructions on the manual .. I have a 18X33X4 oval and had to start with over 350 lbs of salt and ran the pump without the chlorinator for 24 hours to properly disolve the salt. Then, I started with 12 hrs pump cycle with 10 hrs of chlorination in between the 12 hrs. Keep checking the chlorine level and adjust time from there. Currently at temperatures of 85 to 100, I run the system at 10 hrs pump with 8 hrs chrlorinator and water is Crystal Clear... In the 2 years with the intex system, I have not added any chemicals to my pool. I once had an issue when the water level went low while I was on vacation, when I came back, the chrolinator had turned off due to low flow and my pool water was green.. As soon as I re-started the cycle, a few days later, Crystal Clear again... NO CHEMICALS OR SHOCK added.... Hope this helps....
Jul 15, 2011 | Intex Automatic Salt Water System for ...
What is the best model filter pump for an 18' X 48" intex metal frame pool?
No doubt about it the Intex Krystal Clear Deluxe Saltwater System & Filter Pump. No more chemicals to add and no more money to spend. Just buy salt. Could not be easier. I own one myself. http://www.intexcorp.com/saltwater_02.html
May 31, 2010 | Intex "" Metal Frame Pool Set (56998e)...
My pump is coding salt level too high. Any
Drain water and add fresh. There is no other way to lower salt concentrations.
Jul 31, 2009 | Intex Krystal Clear Model 635 Pool Filter...
Cant figure out where to put chlorine/chemicals
add chlorine to the water in the pool you might try a pool supply store for information reguardind ph of your pool and how to mix chemicals
Jun 21, 2009 | Intex Krystal Clear Model 635 Pool Filter...
Intex Automatic Salt Water System for  Above Ground Saltwater Pool Logo
291 people viewed this question
Top Intex Pool & Spa Experts
avionik99
Level 1 Expert
Jay Finke
Jay Finke
Mike
Are you an Intex Pool and Spa Expert? Answer questions, earn points and help others
