Question about Toro Garden
I have a toro 3150 greensmaster and when we put the reels down to start cutting they sometimes don't start or shut off part way across the green, what can cause this
2 Suggested Answers
  • 10865 Answers
SOURCE: i have a toro greensmaster 3200D. model 1996? i
Hello. Here is a link whereby you can download a free manual. http://openpdf.com/ebook/greensmaster-service-pdf.html
please rate my answer as very helpful. thank you. Joe
Posted on Apr 20, 2010
HOW DO I PUT THE TAPE THROUGH THE REEL TO REEL
Reel-to-reel decks usually run left to right. Put full reel on left hub, take-up reel on right hub. Feed tape across read / write heads, and between pinch roller and spindle. Take end of leader tape, wind carefully around take up reel until it is secure. Press play.
Nov 30, 2015 | Audio Players & Recorders
Why does my car shut down while driving?
There might be a problem with the alternator, specifically the diode trio that is inside the alternator. Have your charging system checked. You can do it yourself if you have a voltmeter. Start car and check voltage across the battery terminals. You should get 14.5 volts or higher.
Sep 24, 2015 | Cars & Trucks
NAD 3150 cuts out
Hello. Slapping and it working is a tail sign that there is a loose connection, bad solder point, loose wire. When a circuit board gets hot, solder joints separate and an opening occurs in the circuit. Open it up and get a visual. Look for cold solder joint, make sure all the connectors are secure. Good Luck
Feb 13, 2014 | Audio Players & Recorders
The blades will not engage when the knob is pulled....toro 50
.... burning rubber smell? Sound like you have done a cutter belt.
May 27, 2012 | Toro Garden
I need a toro impeller model no 51553 or 51587
The impeller for your Toro blower is part #98-3150 and is available from www.partstree.com for about $20 plus shipping. To avoid shipping charges, find your local Toro dealer. Go to www.toro.com to find your nearest dealer.
An exploded parts view is also provided on partstree.com's website. This should make it easier to see what has to come apart for the impeller to be replaced.
Nov 12, 2010 | Toro "Toro" Super Blower/Vac
I have a toro LX 500 Riding Mower with Kohler Courage 22 motor. I was cutting grass and it started hesitating and eventually shut off. It will start but only runs for a bout 30 sec to 1 min before it shuts...
When you had the fuel filter off, did gas flow freely from the hose? Sounds like maybe the tank has dirt in it blocking the fuel line. Other than that, maybe there is dirt in the carburetor bowl.
http://www.mylawnmowerforum.com/forum/
Aug 09, 2010 | Toro Lawn Mower With Toro Power Tools
I have a toro greensmaster 3200D. model 1996? i think. I am looking for a manual for this machine
Apr 20, 2010 | Garden
Tascam 38
Usually the tension of the take-up reel keeps the shut-off arm taught and everything works. If the shut off arm falls down, the recorder stops. Is that what's happening?
Inadaquate (or NO) take-up tension can cause this; so can WARPED take up reels. Another possibility: if you play a lot of old tapes, the groove in the shut-off arm collects dirt and oxide, so the tape - as it goes through it - jams, and the take-up reel can not overcome the tension. The arm "falls down" and shuts off the machine. Also SOME tapes (which were "cut down" from 2"
tapes) are poorly ****, and will jam some machines.
This is what I do for a living, so if these suggestions don't work, give me more information, and I'll solve your problem.
Jan 01, 2008 | Audio Players & Recorders
Some tapes will start and immediately shut down
the vcr is on threshold of belt life. try replacing (or cleaning with alcohol) the take-up reel belt. The vcr has a built-in time-out feature to protect the video tape. if it takes too long for things to happen, shut-down occurs.
Aug 30, 2007 | Toshiba M655 VHS VCR
Garden Logo
667 people viewed this question
Top Toro Garden Experts
Joseph Mueller
Joseph Mueller
lnbn1975
Mike Squire
Are you a Toro Garden Expert? Answer questions, earn points and help others
