Question about Sony DSC-T70 Digital Camera
My camera isn't connecting with my laptop.is there any software cd to install the camera???i want to copy my photos in my laptop.please help me
  • 624 Answers
Hello and Welcome to FixYa!
You can download the Software/utility through Sony's E-Support Portal. I've provided the link below, you need to select the Operating System and then all the available downloads will be shown. The Software used to share transfer photos is called Picture Motion Browser.
If you think I was of help, your token of appreciation in the form of rating will be esteemed.
Concerned, Nooh
P.S : Download Page Link
Posted on Jul 22, 2010
I cannot get my photos to download to my new laptop via the cable. I was use to placing memory card in photo/copy machime. My manual mentions a [pc] connection by default in the set up. must i go into...
For every camera, or memory card reader, you should install some software. When you use a memory card reader, most of the time the modern operating systems od have drivers at hand, but if you are still using an older operating system (like XP or older) you have to do the instal of the driver yourself. Most of the time the software is delivered with a memory card reader, and it is always deliver with a camera.
Some photo editing software can download direct from a camera, that is when the correct drives are available. Check the box where your camera came in, if you still have the CD with the camera software. Sometimes you have 2 CD's, one with the Manual. (PDF) and one with the software.
Feb 01, 2014 | Leica C-LUX 3 Digital Camera
Download photos to computer
If you used a SD card in your camera then just pull that card out (when camera is off) and plug it in your laptop or use USB SD card reader and then you can copy all the images in the SD card in your computer hard drive.
If you used camera internal memory then you need to install a software called Kodak EasyShare provided with the camera in a CD. If you don't have the CD, you can download this software from kodak website. Now install this software and then connect the camera with your computer using the USB cable provided with the camera. Make sure you have batteries in the camera. When you have plugged the camera, turn on the camera and kodak easyshare software will detect the camera and let you browse the photos in the camera memory.
Jun 01, 2011 | Kodak EasyShare One Digital Camera
How do i get photo.s off my camera onto my computer
You must have received a cord or wire that connects the camera to your computer. You 1st need to install and software that was provided to you in a CD along with the camera. Once you have installed the software, connect the camera to the computer with the cord. When ever you connect your camera to your computer it will run the software and give you an option to copy the photos. Or you will need to manually run the software and transfer the photos.
Or
You can remove your memory card from your camera and insert it into a card reader if you have one and transfer the photos.
Jan 14, 2011 | Computers & Internet
Sir,s i lost my cd software of ditital camera ,s i 1236 please give me driver or software of same device thanks
You do not need special camera software. When you connect the camera bu USB and put it on to the download setting, go to Start and click My Computer. The card will appear as a volume such as D: or E: Click on that and on any folders within other folders until you see your photos. Select all and COPY (right click and copy). Then go to your desktop and create a new folder and PASTE your photos there. Make sure to save an extra copy of the folder on a CD or external hard drive..
If you prefer you can take out the card from the camera and connect the card with an SD card reader (a small device to accept the card and connect it by USB to the camera). Some computers already have an SD card slot in the side.
Another method highly recommended is to install the great photo editing and sorting software picasa. Download it free from picasa.google.com and use its IMPORT function when you connect the camera or card reader. Good luck.
Nov 24, 2010 | Cameras
USB upload error from Panasonic DMC-TZ4 to my laptop (Thinkpad T)
Are you trying to copy your photos off the camera, or use it as a webcam?
If you are trying to copy photos, then make sure the camera is in the correct mode, eg: playback mode. if the problem still occurs then try a different USB socket on the computer. If that doesn't work then possibly the USB socket on the camera is damaged (this is a common fault). I would suggest getting a SD card reader that stays connected to your computer full time, take the SD card out of the camera and plug it into the SD reader. That is a more reliable solution.
Sep 27, 2009 | Panasonic DMC-TZ4 Digital Camera
Error message when I try to download photos to my laptop
Did you install the drivers from the CD which came with your camera???. The drivers must be installed, before you can connect your camera to your laptop. If not follow these steps in sequence
1- Use the CD to install the drivers. If you do not have the CD, please go to fuji web site and download it. Here is the link
http://www.fujifilm.com/products/digital/download/01/index.html
2- After installing the drivers, connect your camera to your laptop, turn it on and follow the screen to install the drivers.
3- After it is finished (ready) , click on start, then computer. If the drivers was installed correctely, you would see an icon with all or part of fuji Finepix s9000. Double click on that icon.
4- You would see one or more folders, which contain all of the pictures and/or videos stored in your camera.
Now you could download, copy, delete etc all of your stored pictures.
GOOD LUCK!!!!!!!!!!
Jun 15, 2009 | Fuji Finepix S9600 Digital Camera
How to Recover/download Software CD for NV-GS35; Panasonic VFF0264-A; MotionDV STUDIO 5.3E LE for DV
I have panasonic Digital video camera model NV-GS25GC
I need driver for windows7 for it thnk you
Dec 24, 2008 | Panasonic NV-GS25 Mini DV Digital...
Transfering to my desktop
does your cam comes with an installation cd if it does install the software and follow the instructions. If you do not have the cd and you saved the photo on a memory card simply connect a card reader to your pc and copy it directly from the memory card
Dec 12, 2008 | Sony Cyber-shot DSC-W50 Digital Camera
Need installation software
You don't need any special software.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or, despite what I said first, you can use any photo management program such as Picasa.
Organize edit and share your photos
Oct 29, 2008 | DXG Technology DXG-328 Digital Camera
I lost the cd to install the software installation in the computer - model Fuji FinePix A345 Digital Camera
With most recent computer systems, you don't really need the software that came from the camera manufacturer.
  • Connect the camera to the computer using the USB cable that was included.
  • Put the camera in the mode for viewing pictures already taken (not sure if necessary).
  • Turn on the camera.
  • At that point, the computer should recognize the device.  It may take a few moments to configure itself properly.
  • Then the computer should make the camera available just as if it were another disk drive (or flash drive).  You should be able to drag or copy photo files from the camera to the computer.  You will first need to navigate through the directory/folder structure of the camera -- the photos are not in the root directory.
Hope this helps.
Sep 20, 2008 | Fuji FinePix A345 Digital Camera
Sony DSC-T70 Digital Camera Logo
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
