Question about AquaVac Tigershark Plus Robotic Automatic In Ground Pool Cleaner
How do I remove the broken impeller fan to replace it with a new one
Replacing impeller
Remove the back cover of the motor to expose the plastic fan. Find the c clip that holds it on the motor shaft. Remove the nut that is on the front side of the impeller. I used a vise grips to hold the shaft from spinning on the side where the fan was. A small 2 or 3 arm puller hooked under the front shoulder of the impeller and that is all you need to do.
Feb 26, 2013 | Hobart AM14-253 Free-standing Dishwasher
Nitro 51 Wall Climber. Purchased in 2009 now out of warranty. Impeller is broken all that is left is the stump. Purchased new impeller but no guidance on how to replace. Impeller replaced under warranty...
Hold the 'nub' with pliers and remove the nut holding it in place. Lift the nub straight up and off the motor shaft and install the new one in reverse order.
John
May 24, 2011 | Smartpool Nitro Robotic Cleaner and Caddy
How to remove the impeller from a Masport Onga HJ200 pump to access and replace the seal between the pump and the motor.
The impeller is screwed on to the motor shaft; to remove it you need to hold the motor shaft at the fan end so that you can unscrew the impeller - normal right hand thread. Holding the shaft can sometimes be quite difficult so a good suggestion would be to remove the fan cowl along with the fan, this will enable you to secure the shaft with a small pipe wrench or similar. Once you have the impeller removed it will be possible to ascertain what steps need to be taken next - you may need a new shaft sleeve as well as a new mechanical seal assembly.
Good luck,
Mike G
Aug 25, 2010 | Garden
How do i replace an impeller on a 5.7 merccruiser inboard /outboard engine
There Is a Impeller On The Sea Water Intake Side Driven By A Fan Belt At Front Of Engine ,
Remove Cover Pull Out Impeller Check Key Fit New Impeller And Gasket
Aug 03, 2010 | Boating
Dishwasher is not draining
Your dishwasher pump ejects the water. The pump is usually mounted directly to the motor, then attached to the bottom of the dishwasher. You can reach the pump from inside the dishwasher, but first you need to remove the lower rack, the spray arm, and the spray arm support.Look for an impeller--a round plastic fan blade-type of device that spins around. This is the wash impeller, which forces the water through the spray arm. Beneath the wash impeller is the drain impeller, which is similar in size and shape to the wash impeller. The drain impeller pushes the water toward the drain port. These components make up the pump. If any of the pump components are defective, you need to replace them.
Thank you !!
Jun 04, 2010 | Frigidaire 24 in. FDB750RCC Stainless...
Replace Kirby legend II fan (impeller blade)
In order to replace the fan you will buy a 2 or three piece lexan fan kit containing the fan a spacer and shaft.
You must remove the carpet head and then looking from the back of the machine you will find a series of philips screws on the outer edge of the fan housing facing towards the front, several of which may be partly covered by the motor housing. You will remove the forward facing screws to allow the housing to separate and reveal the fan.
If you are lucky there will be a sideways hole through the impeller shaft allowing you to slip a nail through to help twist the saft to unscrew it while holding the fan .
The shaft will turn off revealing a threaded motor shaft with spacers which the broken fan will slide off revealing a second spacer at the back . Be sure to replace these spacers in the same order when re-assembling the unit. Secure the shaft hand tight. Post back to advise if you need further help
Oct 07, 2009 | Kirby G4 Bagged Upright Vacuum
Pump disassembly
I removed the impeller on my DW761UQB. The instructions were molded into the plastic pump housing. This is how I DID MINE: Remove motor mount screws. Remove the chopper screw (screw only goes into impeller, not motor shaft). Remove chopper and rotate/remove strainer. Place socket or wrench on impeller tip and place another wrench on rear of motor's plastic fan. Unscrew fan from impeller shaft ( threads are LEFT handed, turn CW). Once fan is 'backed off' of the impeller, CAREFULLY pry the motor/fan from pump housing (impeller is attached to motor shaft via splines). Don't crack the delicate plastic pump housing. Mine was stuck, but separated with moderate force. Now remove the impeller/seals from the pump housing. This worked for MY above mentioned model, I don't know what other models it applies to. I am not a pro.
Sep 25, 2008 | Dishwashers
Fan replacement
http://reviews.ebay.com/KIRBY-VACUUM-REPAIR-HOW-TO-REPLACE-THE-FAN-IMPELLER_W0QQugidZ10000000003711302?ssPageName=BUYGD:CAT:-1:LISTINGS:3
I'm assuming you mean to replace the impeller fan...if so this site has step by step instructions...
hope this helps!!!!
Jan 27, 2008 | Kirby Ultimate G Bagged Upright Vacuum
Has no suction
I just went through the same thing.  Your fan or impeller is probably broken off the shaft and no longer on the motor shaft.  My local repair shop wants $9 for the impeller and $29 to replace it. You will have to take the thing apart and put on a new fan or impeller blade and I'm still trying to do that to my vac.  I think I will have to heat the nylon impeller with a hair dryer to get it onto the shaft and then tighten the left hand nut. My vac is held together with torx screws so add a torx screwdriver to the price if you don't have one and want to do the job yourself.
Aug 19, 2007 | Eureka Whirlwind 4383 Upright Vacuum
AquaVac Tigershark Plus Robotic Automatic In Ground Pool Cleaner Logo
Top AquaVac Pool & Spa Experts
Thomas Perkins
Thomas Perkins
Steve Slater
Jay Finke
Jay Finke
Are you an AquaVac Pool and Spa Expert? Answer questions, earn points and help others
