Question about Doro DECT 540 Cordless Phone
Only bass set going extra hand set not working
    President:
  • 1,932 Answers
This is because the extra handset might have not been registered with the base unit.The headset should be register to use the headset with that base unit.
To register the handset to base unit please follow the instruction:-
On registration the handset is allocated a handset number for use on the new base unit, the handset numbers are 1-5.
1. Press and hold
only bass set going extra hand set not working - d65e3ff.jpgon the base unit until 608a95f.jpgstarts flashing. Registration mode will remain active for approximately 3 minutes.
2.Press and hold both 19efd34.jpg together until you hear a long beep.
3.Select the base unit you wish to register by pressing the corresponding number button 1-4.
4. When PIN is displayed, enter the units PIN number (0000 for this model).
5. If the registration is successful the handset will return to standby mode in a few seconds.
Thanx
Posted on Jul 22, 2010
Are thee any Binatone handsets compatable as extra handset to add to Binatone symphony 3325 unable to get new handsets but main answering machine and handset are still working
with cordless phones the problem is that the hand sets have to be recognized by the base station ( paired) and unless you have the exact hand piece make and model this pairing and recognition will not happen
if you can get 2nd hand units for the 3325 base then the base will accept them ( any number of additions ) but if the hand piece is different it will not work
you you need extra hand pieces then it may be best to consider a new system where you can buy extra phones and chargers
Jul 13, 2016 | Binatone Lands Phones
Why is there no bass?
Not much info to go on here, but my thought would be you have blown the woofers in the speakers, or the crossover in the cabinet, that separates the highs from the lows. . If you can touch the woofers with your hand, spread you hand wide over one, and try to move the cone. If it makes a scraping sound , the speaker is blown. If not,the crossover is probably damaged.
May 05, 2014 | Cambridge Soundworks Audio Players &...
How do i get bass from my iva-d310
To get to the bass settings touch [SETUP] on the source main screen and on the next screen touch [i-Personalize]. Touch [>>] of BASS ENGINE. The screen will change to the Bass Engine setting screen. Touch left or right arrow or [>>] of the desired Bass Engine setting item (i.e. Bass Max EQ, Bass Focus, etc). Touch arrows or the adjusted screen of the selected setting item, and change the setting. When setting is complete, storing in memory is recommended. Touch [RETURN] when finished.
For more information go to manual, page 37 and 38: http://www.fixya.com/support/p199196-alpine_iva_d310_car_dvd_player/manual-2142
Feb 23, 2011 | Alpine IVA-D310 Car DVD Player
Hi, do you know if you can adjust the bass on a Sharp xl-hp505 micro component system (other than the preset settings)? I find the bass too loud. Thank you so much.
The manual mentions a couple of things that could account for excess bass, one being the Extra Bass button (X-Bass indicated on front); the other being the ROCK setting, which boosts bass.
http://www.retrevo.com/support/Sharp-XL-HP505-manual/id/285dj790/t/2/
Placement of the speakers relative to the room surfaces and the listening position can affect their perceived bass response. Experiment. Corners and close wall reinforce the bass, moving the speakers out from them would lessen it.
Jan 03, 2011 | Sharp XL-HP505 CD Shelf System
How do I get more bass out of the system?
To get a better bass output from the sub. The best place is in the corner next to a wall. Doing that is called corner loading. Like you put a firecracker on your hand you might just get burned,buy if you close your hand...you will have to goto ER. And it is not a boomy sub. Small 5 1/4" woofers.You wand good bass? Take it back and buy klipche. Great sound and bass for a decent price.Or go all out and buy the Bob's Sunfire sub. and tick off all your neighbors. that little thing really pounds. I own two. When I played twister, My celing in my new home cracked. I got picts. If you want something simple like the 321,try Kef instant home therei <<spelling. Has a 10" sub.Bought for my father. Sounds great. Just 2speakers DVD/CD/Radio unit and sub.Simple one wire hook-up. and speakers.
Hope you are able to use this info.
Todd
Oct 29, 2009 | Bose Cinemate Digital Home Theater System...
Low sound
im using sonyericsson k530i hand set.im not satfied with the sound effect of my phone.my question is ? can i increase sound of my phone.... ?can i add mega bass to the equalizer......
Feb 15, 2009 | Sony Ericsson K530i Cellular Phone
Popping noise while computer is powering down. Any suggestions?
Lower your main sound volume. Double click the speaker icon in the bottom right hand corner of your windows.(was it maxed out?)
go into control panel /sounds and select a lower bass setting in your sound settings. You usually have a choice of rock & roll ( lots of bass) opera setting, classical etc.. choose one with less bass.
Make sure your LINE IN is DISABLED. It may be causing this static feedback.
You may have blown your speakers by playing sound way too loud. You may need to buy new speakers.
Thank you and Good luck. *s*
Oct 24, 2008 | EliteGroup P4M800PRO-M478 Motherboard
Panasonic kx-tg7120e extra hand set.
with the hand set on the base, unplug the power then try plugging it again.
Jul 02, 2008 | Panasonic KX-T7730 Corded Phone
Cannot Set the Treble & Bass
I have an Alpine 9887 you have a different eq than just trebel and bass the only way to get you bass an trebel setings are to install the imprint stoftware now if thats the route you go it tunes your radio to what it thinks it should sound like it's for sound quality not for alot of bass been there done that I have the software but you need to take it to a good alpine dealer to have it installed good luck
Jan 05, 2008 | Alpine CDA-9887 CD Player
Doro DECT 540 Cordless Phone Logo
220 people viewed this question
Top Doro Lands Phones Experts
castletech
castletech
Greg Cann
Greg Cann
Gene Tuck
Are you a Doro Lands Phone Expert? Answer questions, earn points and help others
