Question about Video Game Consoles & Games
I have a sega mega drive with all the relevant pieces but i cant tune it into the tv
  • 4,102 Answers
Hi. is the lead from mega drive a rf socket that goes into the arial socket on the telly and does the lead have a switch on it?
Plug the rf lead from md into areial socket on telly
then put telly on channel you dont use i used 0 or 9 but use any.
then turn mega drive on
then press setup on tv
enter channel settup then you need to go through the procedure of tuning channel in its best doing it manualy its like when you tune a channel in make sure md is on then keep changing the frequency one way or the other could take few minutes then when you get it on the telly save this setting on the channel you want to use ok.
If it dont work then the chances are the lead is damaged this is often the case with these consoles as the are not made that well so if no good then replace if necesarry.
If your unsure on tuning your telly then give me make and model then i can talk you through the process ok
Posted on Apr 22, 2008
I am trying to connect a Sega Mega Drive 2 to a UK 19" LCD Freeview tv. I can't get a picture from the Mega Drive. How can i tune it in?
Make sure that you are selecting the right input option, and that your Sega Megadrive is a PAL version.
Mar 07, 2011 | Sega Genesis Console
Can't find the frequency for the genisis 1 sega megadrive, I have the RF converter but I've tried doing auto search and manual, just cant find it...
Hi some new TV'S may not have the frequency of these old consoles i recommend purchasing a AV cable which is can be found at http://www.gameoz.com.au/store/sega-mega-drive/mega-drive-accessories/sega-mega-drive-1-av-cable.html
No tuning in a channel and better picture Quality
Apr 24, 2010 | Sega Genesis 2 Console
Ive got a black sega mega drive but cant seem to locate a channel.. am i doing something wrong with the wires
you need to have an old-ish tv...and you need to choose one channel,any one and tune it in...you need to keep going untill you either have a black screen or the game youve inserted..
TURN YOUR MEGADRIVE ON WHILE TUNING
if youve done that and you still dont have it it might be the wire
Mar 02, 2010 | Sega Megadrive Black Console
I just aquired a sega megadrive 2 with all leads but no instructions. can you tell me how to set it up please? Michael
First plug the power plug into the mega drive and turn it on (there should be a red light showing that the megadrive is on)
Plug RF lead into the back of the mega drive and TV and make sure the switch is set at the megadrive side and not the ariel side, if you have a switch.
Now turn off mega drive, put a game into the slot and and then turn the console on.
Select a channel on your TV and tune it into the mega drive.
This should work.
Mike
Jun 13, 2009 | Sega Genesis Console
How do I set up a sega genesis?
here we go
This is a step by step with testing set up for the sega mega drive
first plug the power plug into the mega drive and turn it on (there should be a red LED light)
plug RF lead into the back of the TV and make sure the switch is set at the megadrive side and not the ariel side, if you have a switch. (or you can buy scarts from www.retro-cache.com)
Select a channel on your TV and re-tune it into the mega drive. (on some TV's the tuneing is around the C36 area if that is any help)
If you tune into a blank screen than turn the mega drive off, remove the game, clean it and replace the game and try again.
Oct 01, 2008 | Sega Genesis 2 Console
Cant get picture on tv from sega mega drive. concerned might be missing a part
Ok i have many sega systems and to connect a sega it sometimes depends on what version of the sega mega drive you have i will tell you how to connect your sega after you've already plugged in your power adapter. If there is a plug on the back of your sega that says RF out then you should have a TV out/ antenna in adapter. One end goes into your sega and the other TV out should go into your TV then if there is already an antenna in your TV unplug it and and plug it into your TV/ antenna adapter where it should say something like antenna in. Don't worry if you have cable or directv it will still work it just might be slightly fuzzy because of the old technology. If you dont have the RF out then you should have a plug in the back that says AV out and all you do is do the same thing only the TV/ antenna adapter you should have should be able to plug into the AV out plug. Any other concerns about your sega, like how to connect your sega CD to your sega console, or most of its other products just let me know and if this doesnt work let me know, thank you.
Mar 07, 2008 | Video Game Consoles & Games
Video Game Consoles & Games Logo
152 people viewed this question
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
