Question about Ice Cream Makers
Trying to find parts for Danby Ice N Easy DIM1524W, I need to get a new water bucket. (Part # DIM 15.13)
I purchased the ice cream maker without a user guide. Is one available?
Are you looking for operating instructions or recipes? Recipes available everywhere ... really. Operating? Here is what you do: Get some ice cubes ... crush them with a hammer ... you will need a lot ... the finer crushed the smoother the ice cream. Put the mix in the metal container and put about 4 -6 inches of ice in the bucket with some water. Put about 1# of rock salt on the ice. More ice ... more salt ... more ice ... more salt ... more ice ... more salt until the bucket is full. Start the machine. Your ice cream should be ready in about 1/2 hour. When the machine stops cranking ... remove the mixer from the can. If you can stand it ... let the ice cream sit in the container for 1/2 hour ... the longer you wait the better the batch. But who can wait???
The ice cools the water, the salt reduces the temp of the water to cause the mix to freeze.
I hope this helps you ... this is how we make home made ice cream every summer ... what a special treat for the kids ... young and old alike.
Thanks for your question @ FixYa.com
Mar 18, 2011 | Rival 8605-M 6 Quart Ice Cream Maker
Doesn't freeze consistently
Here is a tip that will give you the information you are looking for...
Ice Cream Maker Parts, Instruction Manuals and Recipes
http://www.fixya.com/support/r5322664-ice_cream_maker_parts_instruction
heatman101
Jul 13, 2010 | Rival 8704 4 Quart Ice Cream Maker
NOT FREEZING PROPERLY
If your outer bucket is leaking down the liquid brine solution it won't freeze properly. The rival buckets are bad about leaking. You might try pre-conditioning the outer bucket before making your attempt at freezing. Just fill the bucket to the weep hole with water and let it sit for about half an hour, then pour out all but about 4 inches of it and start adding ice and salt.
Jul 04, 2010 | Rival 8550-X 5 Quart Ice Cream Maker
I need an instruction manual for my Deni 5000 ice cream maker
Are you looking for operating instructions or reciepts?
Find receipts via Google.
Operating instructions:
place the mix into the can with the paddle inside. Place the can into the bucket. Attach the motor or crank as appropriate.
Crush some ice (aboout 5 pounds) and pack about 2 inches around the base of the can with the can in the bucket. cover this ice with rock salt. Put two more inches of crushed ice on top - spread more rock salt (the smaller the ice, the smoother the mix). Continue this process until you are at the top. Make sure the drain is clear, start cranking (or motoring. When the motor stops, unplug it. Cover all with a heavy towel for about 30 minutges (if you can stand it) If for some reason the motor doesn't stop - you didnt put in enough salt. Expect to use about 1/2 of a 5 pound bag.
Remove the towel - the motor - the top - the paddle. Give the paddle to the kids with a couple spoons. Dig in for the adults.
I sometimes add a quart of water but you dont have to.
The ice makes the water cold - the water provides the freezing power, the salt lowers the freezing point of the water - the extra water might speed the process a little bit ... maybe not
Enjoy your delicious home made ice cream.
(BTW - the paddle does not move ... the can spins around the can causing mixing.
a
Oct 14, 2009 | Deni 5000 Scoop Factory 1.5 Quart Ice...
How long does it take to make ice cream?
Not long at all, maybe 20 minutes.
Jun 02, 2009 | Ice Cream Makers
Danby icemaker not pumping water
I have the same problem, the ice shovel was catching and not moving forward to shovel the ice, this stopped the ice maker. i have cleaned off the surplus plastic from the molding process (on the underside of the shovel) and this so far has cued the problem.
Jul 16, 2008 | Ice Cream Makers
Cracked Bucket
try ebay or go to the products website and see if they sell that part.
Jul 07, 2007 | Rival 8806 6 Quart Ice Cream Maker
Ice Cream Makers Logo
267 people viewed this question
Top Ice Cream Makers Experts
Dennis Boxerman
Andrew Taylor
Andrew Taylor
Are you an Ice Cream Maker Expert? Answer questions, earn points and help others
