FixYa.com
Tags:
Panasonic RF-544 Radio
Panasonic Table AM/FM Radio Model RF 544
By Horner - usenet poster
Hello all,
         I have the the above mentioned radio. Though the audio sounds
         great during the day,  (Must have quite a good AF bandwith)
          At night the problem of 9Khz whistle raises it ugly head.
        Anybody got an idea to modify the radio (switchable) to
        narrow its bandpass so that I can more enjoy listening at night?.
Regards,
Mitchell
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Aug 10, 2005
Not Rated (0)
Jimmy NY
Jimmy NY - usenet poster
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
Thanks Phil. Doesn't seem to hard to make up.  I'll delete the switch as far
as the notch
select is concerned.  Now where did I put that veroboard :)
The only other pain in the but is radio 2 (1611KHz)  which I can here softly
in the background
spaced apart at the IF frequency (455KHz).
Guess I can't really get rid of that because the TX site is only about 1 KM
away
Cheers,
Mitchell
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
Not Rated (0)
Hart
Hart - usenet poster
Rating: 0%, 0 votes
On Sat, 21 Feb 2004 09:43:58 GMT, "Mitchell McCreath"
Hello Mitchel,
For fun, in addition to the notch filter you could add a simple manual
RF gain control. Find the AGC line and with a suitable potentiometer
resistor arrangement (trimpots either side of the control pot) alter
the AGC voltage slightly.
You  could fit a 3 position switch to have.
Normal AGC (original circuit without mod)
Manual RF gain no AGC
Manual RF gain with  AGC
Easy to do with a signal generator to help you but
you could just muck about without one just for fun.
I am assuming you have a circuit diagram for your
radio, if you can't get one easily and cheaply then
forget my suggestion.
Regards,
John Crighton
Sydney
Solution #3
Not Rated (0)
Chandler
Chandler - usenet poster
Rating: 0%, 0 votes
Don't know about that model, but in general you could make a 9kHz notch
filter out of one or two op-amps.  Then wire it into the receiver near the
volume control connections.
Peter
Solution #4
Not Rated (0)
Gary10
Gary10 - usenet poster
Rating: 0%, 0 votes
"Mitchell McCreath" <mmou @bigpond.net.au>
 **    This site should give you a few ideas.
   http://www.geocities.com/rbruc ecarter/amaudio.htm
...........   Phil
Can you Help with these Personal Radios problems?
Personal Radios
manual for Audiovox AXR48 crank...
Audiovox AXR48-hand crank radio Answer This...
Personal Radios
Audiovox AXR48- find manual?
I can't find a manual for my... Answer This...
Personal Radios
Need replacement earpads for...
Hi, folks....My radio is a few... Answer This...
Personal Radios
Radio display out on 2006...
The sound system on my Harley... Answer This...
Personal Radios
sound driver
download sound driver of... Answer This...
Repair Service
Find Personal Radio Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
