Question about HP Office Equipment & Supplies
Hp CM8060 error code 49 4C02 - HP Office Equipment & Supplies
  • 154 Answers
This error is typically due to some sort of data corruption. If this is happening on a single file, it could be that file. It could also be related to the individual software sending the print job, bad print commands or invalid. Although rare, a bad cable or connection can be to blame.
First step is to restart the printer, clear all jobs with the Stop button, restart printer again. Then try printing from another program, such as txt editor. If ok, then print a different file from original software, if ok, then print original file.
If failure is with final print, the file is corrupted for printing, recreate file.
If failure is with original software see if there is any updates.
If failure is there directly after restart, try updating printer driver (this is not be a bad idea anyways).
If none of this works, it may well be a formatter board issue, requiring technical service.
Posted on Mar 05, 2009
Hp color laserjet 5500 error 59 ck printer error
list of error codes
http://www.printertechs.com/printer-troubleshooting/hp-error-codes/195-numeric-error-codes-50-59-hp-laserjet
HP COLOR LASER PRINTERS 4600, 5500 ERROR 59.3, 59.4 1. A fuser motor error. 2. Replace the fuser drive assembly. 3. Replace the D.C. controller board.
Jan 04, 2017 | HP Office Equipment & Supplies
Tip
Here is information about HP Laser printer error Codes
This site:<br /> <br /> <a href="http://www.all-laser.com/aerror-code/">http://www.all-laser.com/aerror-code/</a><br /> <br /> <a href="http://printertechs.com/tech/error-codes/error-codes-index.php">http://printertechs.com/tech/error-codes/error-codes-index.php</a><br /> <br /> <a href="http://h30434.www3.hp.com/t5/Printer-All-in-One-Install-and/HP-error-code/td-p/31465">http://h30434.www3.hp.com/t5/Printer-All-in-One-Install-and/HP-error-code/td-p/31465</a><br /> <br /> <a href="http://www.fixyourownprinter.com/reference/errorcodes/hp">http://www.fixyourownprinter.com/reference/errorcodes/hp</a><br /> <br /> <br /> Hope this sites will help you.
on Mar 15, 2011 | Office Equipment & Supplies
Hp laser jet pro 400 m401 printer 59.A0 error
i have nOt used this site before but i believe they do have a description of the error code you describe. it said problem is defuser or main motor error, heres the link
HP LaserJet Error Codes 50 59
Apr 20, 2016 | HP Office Equipment & Supplies
What does error code 168 mean?
what make and model printer is it?
Feb 14, 2016 | Office Equipment & Supplies
Cm8060 with e2.3a8e error print firmware any ideas how to resolve
It is an ink cartridge/firmware error. Whichever cartridge you replaced recently is the problem (most likely bonding agent or black) Turn on machine with all cartridges out, when fully boots up go in to Administration and then Time Scheduling and change the month to January, hit save and then turn off machine (still with cartridges out). Reboot and put in each cartridge one by one as it asks but make sure cartridge you just replaced that caused issue is a new and different one and discard the one that caused issue. When all cartridges are installed run 10 copies then change the date to current.
Feb 15, 2010 | HP Office Equipment & Supplies
I Have Fault Codes on the Display.
Problem solve someone tried to print a PDF file which lodged the fault our It Dept deleted the print spool and Re-set the printer all ok.
Jan 14, 2010 | HP Color LaserJet 5550hdn Printer
49,4c02 error to continue turn off then on
I would try clearing your print que as it could be a corrupt print job and disconnecting your network cable and reboot the printer, make sure you have the latest firmware. hope this helps
Nov 24, 2009 | HP LaserJet 4700 Printer
HP CM8060 Error code C1.132A
2 possible causes for this are Carriage stall and paper on drum at SN57 Carriage 2 Pen Protection sensor. Some MFP's can experience intermittent motor stalls due to maladjusted upper right front door latch when minor movements cause the door actuator to open the door switch . this can then show up as a carriage stalled. also check for carriage 2 binding and that the aerosol hose and snorkel are seated properly.Check the plastic sensor actuator for damage and contamination. last chance could be Pen Pocket 4 PCA (A19).
Apr 18, 2009 | HP Office Equipment & Supplies
Hp laserjet 4650n
Hi 123sha:
49.XXXX
PRINTER ERROR
To continue
turn off then on
A critical firmware error has
occurred that caused the
processor on the formatter
to abort operation. This type
of error can be caused by
invalid print commands,
corrupt data, or invalid
operations. In some cases,
electrical noise in the cable
can corrupt data during
transmission to the printer.
Other causes include poorquality
parallel cables, poorconnections,
or home-grown
programs. On rare
occasions, the formatter is at
fault, which is usually
indicated by a 79 Service
Error.
1 Press CANCEL JOB to
clear the print job from
the printer memory.
2 Turn the printer off and
then on.
3 Try printing a job from a
different software
program. If the job
prints, go back to the
first program and try
printing a different file. If
the message appears
only with a certain
software program or
print job, contact the
software vendor for
assistance.
4 If the message persists
with different software
programs and print jobs,
disconnect all of the
cables to the printer that
connect it to the network
or computer.
5 Turn the printer off.
6 Remove all memory
DIMMs or third-party
DIMMs from the printer.
7 Remove all EIO devices
from the printer.
8 Turn the printer on.
9 If the error no longer
exists, install each
DIMM and EIO device
one at a time, making
sure to turn the printer
off and on again as you
install each device.
10 Replace a DIMM or EIO
device if you determine
that it causes the error.
Try new network card
pdouglasss
Jun 18, 2008 | HP LaserJet 4650 Color Printer Manual...
1,673 people viewed this question
Seeker5211
Seeker5211
