Question about Whirlpool Duet GHW9150P Front Load Washer
Duet washer ...no electric getting to washer. first dash was lit up but nothing workrd after unplugging machine and replugging machine, even the dash did not lightup. Outlet is fine and grounded.
  • 1,557 Answers
Sounds like the in line main p.c.b fuse has blown as most new models use i.m.c fuses rather than glass or ceramic fusses you will need to have it looked at by a service pro. if it is the fuse demand it be replaced not the whole board unless the second fuse blows then there is an in board problem and the whole p.c.b will have to be replaced.
good luck
Posted on Jul 22, 2010
Control lock on duet washer GHW9250ML1 is flashing, nothing working even after unplugging. When replugged, light starts to flash again and nothing else.
Here's what the Duet tech sheet says to do:
1. Press PAUSE/CANCEL button on the touch-pad twice.
2. Drain the unit, then check that the Drain hose and Drain Pump
Filter is clear of foreign objects.
3. Check/ Replace Touch-pad/LED assembly.
4. Check harness connections.
5. Check the CCU.
Oct 25, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Was Flashing 02 and f and now flashing 022
Hi
The F22 stands for the CCU/Touch pad error. In other words, the keypad has lost connection with the control board behind it.
Follow the steps:-
unplug the washer
take off the console
check the connection between the touch pad and the CCU board
make sure that nothing looks corroded or burnt
make sure that nothing is pinched or bent
unplug and replug wiring harness and connections form keypad to the CCU board
Please get back to us if you have further query or else please accept the solution.
Thanks for contacting fixya.com
Sep 02, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Control lock light is on and nothing else will respond, and this continues even after unplugging/replugging. help!
Hello & Welcome to FixYa
This is a common issue with Whirlpool Duet washer however; your whirlpool duet washer needs a reset to resolve the control lock problem. Press and hold the END OF CYCLE /CYCLE SIGNAL button for 15 seconds to reset the control. Please get back to me if you have any other questions.
Kevin
Jul 31, 2011 | Maytag EPIC MFW9700S Front Load Washer
The 'Control Locked light' is on and the washing machine will not do anything. I even unplugged and replugged the unit. It will not operate. It is model #GHW9150PWO BOUGHT IN 2005. Thank...
I had that problem before go to the front of the washer and go over to the End of cycle signal and hold the button for 3 seconds that should unlock it I hope this helps
Jul 06, 2011 | Whirlpool Duet GHW9150P Front Load Washer
The door lock stays lit and when I go to turn it off nothing happens. None of the controls work.
First you can try unplugging for about fifteen minutes or so. If that doesn't do it then it is your safety switch on your washer.
May 06, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet Front Loading Washer Won't Turn On
MY WASHER WAS DOING BASICALLY THE SAME THING. I HAVE A WHIRLPOOL FRONT LOADER MODEL #GHW9460PL0. MY HUBBY REMOVED THE 3 SCREWS FROM THE BACK OF THE WASHER, UNPLUG IT FIRST, AND TOOK THE TOP OFF. WE THEN CAREFULLY UNPLUG THE WIRES AND REPLUGGED THEM BACK IN 1 BY 1 SO U WONT GET THEM MIXED UP. WE THEN TRYED IT, AND THE CONTROL LOCKED LITE STAYED LIT. HE HELD THE SIGNAL CYCLE BUTTON IN FOR 3 SECONDS AND THE LIGHT WENT OUT. WE THEN TRYED RUNNING A CYCLE AND SO FAR SO GOOD!! GOOD LUCK!
May 26, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Our wash machine will not spin after draining the water.
if this is really the old 9150 version then f21 is a ccu communication error with user interface. likely ccu is bad. 5d is not a error code.
bearings will make noise when out. unplug wait 1 min the reconnect power. If this doesnt work open top cover and check connections on ccu in rear. (unplug and replug). then buy new control. if your machine is newer duet (wfwxxxx) then f21 is different. (pressure sw) tech sheet on bottom front cover.
Apr 26, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Door locked & nothing happens Whirlpool duet wfw8300sw01
hi there,
sounds like the machine has no power at all.
there was no need to break the lock.
unplug the machine
check connections from the touchpad to the CCU board
make sure nothing is corroded, burned, bent or pinched
unplug and replug the wiring harness
plug the machine back in and try it again.
let me know if this works.
Sep 26, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150PWO
You must press in the control lock for a few seconds to disengage it I believe. Try unplugging and replugging the the unit if that doesn't work.
Dec 17, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
192 people viewed this question
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
