Question about Microsoft Wireless Laser Mouse 6000 v2.0
The laser on the mouse is not working even with fresh batteries. I use the right button and the mouse moves in a "square" shape and then stops.
Try using both buttons on the receiver and at the buttom of the mouse the one with the ))). When clicked simultaneasly they switch the wireless on/off.
Posted on Aug 12, 2010
  • 1,557 Answers
I dont think it would be the led ( pass laser) as they last yrs i think you will find its a blown crt in the mouse i would replace it.
Posted on Jul 22, 2010
My lexma cordless laser mouse stopped working it
I know it may sound simple but did u change the battery?
Aug 19, 2013 | Laser Lexma G Plus Mouse M231
Hi i am using a PA3745U-1ETB wireless laser mouse with my toshiba qosmio f60. my mouse is no longer working but the keys(click) and scroll button work.when i reconnect the batteries the cursor will move a...
1) Try to download and install a free driver updater software, e.g. http://www.innovative-sol.com/drivermax/index.htm - let it scan and update all your missing drivers - it may fix USB general problems if this causes also the mouse problems.
2) If it doesn't help - then there might be problem with the laser beam of your mouse (check the laser beam while the mouse is still moving, and then compare it with the beam when the mouse has stopped moving, maybe the laser beam is out). In this situation - bring it to the warranty repair service or ask for replacement from your seller.
Mar 07, 2011 | Toshiba Computers & Internet
Cheked batteries, usb correctly installed but cursor doesn't move
Reconfigure both the mouse and the USB router.
mouse - there should either be a button on the back that you press in, or a small whole that your perhaps prod with a pin (like you get on the back of a ps3 pad) But in most cases its a small button (circular in shape)
Usb - There should be a button on the mouse, on my mouse the LED light itself is the button.
Some mouses usb's slot onto the back of the mouse, sometimes this reconfigures them. Anyway try what i said it should start working.
Feb 03, 2011 | Microsoft Wireless Laser Mouse 5000
My Logitech MX 1100 just stopped working out of the blue. The red battery light on top is blinking, so even though I've only been using this for a couple weeks (and the batteries were fairly fresh) I...
I had the same problem, brand new battery, the indicator light still blinking red. I finally got mad enough to shake the mouse kinda hard, and it worked. I then removed and replaced the old batteries in, it started blinking red again, but it worked after I gave it a couple of hard side by side shake. I do notice that there's something moving inside the mouse. It could be a connector that got loose. Hope this fixes your problem
Sep 25, 2010 | Logitech MX1100 LASER Mouse
Won't move anywhere on the screenhow do we know if we need to replace the mouse
Is it a wireless mouse? If so you may need to replace the batteries and re-sync it with the receiver unit. If it is a chorded USB mouse you may want to try a dif. usb port and see if that works. If it is a PS2 mouse you may need to replace it.
Usb - Flat square shape
PS2 - Small round shape.
Jun 19, 2010 | Compaq PS/2 3 Button Optical Mouse...
My Gigaware optical mouse's cursor won't move
Sounds like the laser failed. Return it for replacement.
Mar 16, 2010 | Ultra Max Gigaware Wireless Laser Mouse
My mouse was just working and all of a sudden it stopped, I changed the batteries, reset the small button on the bottom and also pushed the button on the plug in portion. Help Allen
I have a miscrosoft wireless laser mouse 6000, and it also stopped working on my laptop. I changed the battery, still not working. I tested the battery in another device, and it was good. I moved the mouse to another computer, and it did not work. The light on the usb connector was lit. [No changes at all to my laptop.]. It seemed like there was no power to the mouse, and I looked at the contacts inside the mouse. The contact just inside the battery opening appeared to be bent down away from the contact on the battery tray. So, I pulled it up a little so it would connect when the battery drawer closed, and (after tweaking it a couple of times), it finally worked!
Dec 08, 2009 | Microsoft Wireless Laser Mouse 6000 v2.0
Nano mouse will not movethe cursor
Do you have the Nano 2007 model, or the Nano 2008? Procedures are different. The following link should help you:
Link 1 (resynching mouse)
Make sure you have fresh batteries and they are aligned correctly. If it still does not work, download the latest version of SetPoint and reinstall the softwrae after uninstalling it first.
Jun 26, 2009 | Logitech VX Nano Cordless Laser Mouse
Magnifier doesn't work
Try going to Control Panel and click on the mouse icon. Then the mouse properties will appear showing the mouse. In the left column,move your cursor over the right side button click on the drop down and select magnify. Hopefully it will now work.
I had to move the magnify function to the left button because it was to sensitive on the right.
Nov 27, 2008 | Microsoft Wireless Laser Mouse 5000
Optical mouse quit working on my notebook
Look in device mgr and make sure port is "always on"...accordianman
Jan 21, 2008 | Computers & Internet
Microsoft Wireless Laser Mouse 6000 v2.0  Logo
221 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
