Question about Epson WorkForce 310 All-In-One InkJet Printer
Cannot clear a paper jam error message and there is no paper jam. This multifunction Printer/Scanner/Fax was excellent for about two months of limited use. It now displays an error message: Paper is jammed, Turn off, Lift scanner bed and remove jammed paper. There is no paper jammed, and the error cannot be cleared. Tried unplugging power and restarting. The paper jam error message also locks out the use of the scanner and fax.
1alexh
  • 484 Answers
SOURCE: Paper Jam error will not reset after removing jammed paper
In many cases, you must use compressed air in a can, and blow out the insides of the printer. These printers use photoelectronic eye technology to tell you when there is no paper left, or other supplies are used up. But unless you clear that out by blowing air through and past those sensors, they do not reset. The paper dust continues to block the sensor which makes it report that there is no paper, that there is a paper jam, etc.
Try clearing it out that way.
-a.
Posted on Jul 02, 2009
  • 112 Answers
SOURCE: unable to receive fax from HP LaserJet 3050
Please make sure the machine is set for auto-receive in machine set up and make sure the phone cord is plugged into the line jack on the machine. If this machine is not on a dedicated phone line the machine (rings) should be set to pick up before the answering machine does.
I’m happy to help further over the phone at https://www.6ya.com/expert/eric_7148ad2a373711a3
Posted on Aug 28, 2009
  • 28 Answers
SOURCE: paper jam message does not clear
Fiend your solution direct from EPSON. Here is your solution...
http://www.epson.com/printer/prob676ijt65/solution
takiqq14
Posted on Sep 04, 2009
SOURCE: keep getting the error message "Paper jam"
mine does too! help
Posted on Sep 18, 2009
  • 10 Answers
SOURCE: Paper Jam E error won't clear even though I have
If The error message still appear it is a sendor issue and you need to take your printer to a service center
Posted on May 07, 2010
Lexmark s450 printhead not moving
Try to check for any obstructions inside the printer. Something could be blocking the paper path and the printhead from moving.
Sep 15, 2012 | Lexmark Interpret S405 - multifunction ...
I have a Epson stylus CX9400fax a piece of paper is jammed way inside the machine, I can't even see it to try and get it out! I've tried turing the machine on/off numerous time (still not expelling the...
If paper is jammed, a Paper jam message will appear on the control panel display.
Follow these steps to clear the jam:
  1. Gently pull any jammed paper out of the output tray or sheet feeder.
  2. If the paper is stuck inside, turn off the Epson Stylus CX.
  3. Open the scanner, remove the jammed paper and torn pieces, close the scanner, and turn the Epson Stylus CX back on.
    alert_note.gif Note: Be sure to check the far left of the carriage area when checking for jammed paper. Paper that is jammed there may be hidden from view.
If paper jams inside the Automatic Document Feeder, clear the jam as follows:
  1. Open the Automatic Document Feeder cover and remove any jammed paper.
  2. If necessary, lift the document cover and remove any paper that has jammed inside.
  3. Press OK to clear any messages on the display screen.
Jun 02, 2010 | Epson Stylus Multifunction Inkjet Printer/...
When printing photos on glossy Kodak paper the error message " paper jam reload" appears.
Some printers are not able to or having difficulty feeding glossy photo papers at 230 gsm and above, try using photo papers below 230 gsm.
Jan 13, 2010 | Epson Stylus Multifunction Printer/...
Message shows "Paper jam" but there is no paper jam
try turning off the printer for about 10 sec. to clear its memory and turn it back on.. then print again
Oct 19, 2009 | HP Photosmart C4250 Multifunction Photo...
Paper jam went try to sent a fax
Step1
Turn the printer off and on to see if it can automatically clear some or all of the jam. Many printers provide an error-code listing on the front panel display for the area where the jam occurred. If your printer shows an error code, be sure and check the printer manual to see if that identifies the area of the printer where the jam occurred.
Step
Turn off the printer.
Step
Remove any paper trays. Inspect them for wrinkled or damaged paper.
Step
Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
Step
5
If necessary, remove the toner or ink cartridge. Place it in a bag or away from light to avoid damaging it.
Step
6
If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly (see A). The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
Step
7
If the paper does tear, try rotating the roller gears manually to free the paper (see B). Don't force anything, though.
Step
8
Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
Step
9
If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
Mar 30, 2008 | Lexmark X4270 All-in-One Multifunction...
Paper jam
hi this is some small pieces of paper which had gone inside in ur printer when u prints. this one have to contact printer engineer to clean the printer
Mar 02, 2008 | Lexmark X8350 Print, Scan, Copy and Fax...
Brother Intellifax 2820 repair + automatic document feeder + sensor
Brother Error Codes
RAM clear (most models)
Quickly press function * 2 8 6 4
Display should read maintenance
Press 0 1 for a full ram clear, or 9 1 to retain user data
Display should read reinit for a few moments then redisplay maintenance
Press 9 9 to exit the maintenance mode
Other maintenance mode switches:
01 ram clear (see 91 below)
02 scanner initialize (feed a white sheet, then a black sheet)
05 white level
09 print test
10 modify soft switches
11 print configuration list
16 panel test
19 CML test
20 signal test
21 tonal test
23 filter RX
54 scan edge
55 scanner area
66 test print memo
75 display drum life (if enabled on laser models)
76 reset drum life counter (laser models)
91 parameter initialize (user programming remains intact)
95 protection
B2 error = scanner or power supply error
Brother 950/980: On copy or transmit they may produce black pages. Prone to bad scanner (CCD). Brother may provide a replacement CCD at no charge to the original owner. Sometimes leaving the unit unplugged for a few hours will solve the problem temporarily.
Brother HL600 series laser printer toner will work in the laser fax & multifunction machines (part number TN100HL = TN100PPF). Drum units may be interchangeable as well (?).
Brother 1350/1550/1950: Problem: Record paper jams. Solution: Replace upper shoot. P/N UF6058001. Although there seems to be nothing causing the jam, the upper shoot gets stress marks on the ends. Replace even though it is not broken.
Thermal Transfer Machines: Only one side of the page is printing. Caused by the printhead latch being cracked. The latch is blue in color there is one on each side of the printhead, replace both latches
Nov 06, 2007 | Brother MFC-7220 All-In-One Laser Printer
Epson WorkForce 310 All-In-One InkJet Printer Logo
551 people viewed this question
Top Epson Office Equipment & Supplies Experts
Inky Fingers
Inky Fingers
Clive
Clive
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
