Question about Microwave Ovens
We have a Frigidaire Microwave Oven Model #FMV145K53 with F3 displayed. Is this a keypad issue if so is it worth repairing?
MicrowaveSvc
  • 9098 Answers
SOURCE: micriowave key panel
On a GE microwave F3 means you have a failed keypad.
We replace these for customers nationwide with our guaranteed $39.95 service.
If you might want to replace it yourself, I have uploaded a handy guide with pictures showing you what's typically involved. It's here.
Please feel free to contact me directly if you need more help.
We're happy to help and we appreciate your thoughtful rating of our answer.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Posted on May 24, 2008
rickzilla
  • 706 Answers
SOURCE: GE microwave f3 code
You have a shorted touch pad.. here is a link for a replacement.. http://www.pcappliancerepair.com/model-display.php
If you open up everything and examine the touch pad, you may see something that is causing the short and fix it, oherwise, you'll have to remove and replace it.. Hope this helps..
Posted on Sep 13, 2008
SOURCE: Microwave spacemaker oven shows f3 on display and won't start
f3 problem
Posted on Oct 04, 2008
MicrowaveSvc
  • 9098 Answers
SOURCE: F3 meaning ?
"F3 Shorted key panel (touch pad), will occur if a shorted key panel is detected continuously over 60 seconds"
You have a shorting membrane keypad. If and when an oven is coming on or doing anything by itself, this is very dangerous and can result in a fire.
So until it is repaired, please leave it unplugged or leave the door open when it's not in use, and please do not leave it running unattended.
If you (or someone you know) might want to replace it yourself, I have uploaded a handy guide with pictures showing you what's typically involved.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
If you would like to have us do this repair for you, we do that for $39.95 plus part costs.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Feel free to contact me directly (and please remind me of your model number) for more information & help.
prototech@usa.net
Posted on Jan 12, 2009
SOURCE: Frigidaire F3 problem
thank you, problem resolve....bought new micro
Posted on Mar 23, 2009
HOTPOINT COUNTERSAVER PLUS RVM 1435 DISPLAY READS F3
"F3" on a GE / Hotpoint microwave means you have a shorted membrane keypad.
On RVM1435-series microwaves, the membrane keypad is not available as a separate part, so you would have to order the control panel frame assembly which comes with a new keypad.
In this case, you simply move your circuit board into the new frame. That is a simple do-it-yourself job.
You can find helpful exploded view diagrams and order parts by entering your full model number (RVM1435XX###) from the tag on the oven here.
Then you unplug the keypad (as per the photo below) and move the circuit board into your frame.
Some connectors on the relays have a lock:
Nov 23, 2011 | Hotpoint RVM1435 Microwave Oven
My GE microwave is beeping and the display says F3
F3 on a GE / Hotpoint microwave means you have a shorted membrane keypad.
We would need your model number to give you more specific info, part ordering info, and en estimate if needed.
Simply contact me here with your model number and symptoms for free help.
On some models, the membrane keypad is peeled off and a new one stuck on.
In other models, the plastic frame must be replaced, and it comes with a keypad already installed.
May 12, 2011 | General Electric Microwave Oven
I have a whirlpool microwave oven over the range. Model GH 5184xps-4 when I press start, it comes on for one second then it shows a code -F7- and stops
TOUCH PANEL & MICROCOMPUTER BOARD TEST FOR WHIRLPOOL....
The microwave oven may be provided with a self diagnostic routine that can be operated
through the touch pad keyboard. To enter the self-diagnostic routine:
1.While pressing the CANCEL keypad:
a) Open the oven door.
b) Unplug the microwave oven for 2-seconds and plug it back in.
c) Release the CANCEL keypad and close the oven door. You will see the following display.
CHART
NOTE: The humidity sensor test results will appear on the display after 8-seconds.If the tests are successful, "OK " will be displayed. If one or more of the tests fail, "ERR " will be displayed.. 2.When a keypad is pressed, a number according to the test chart will be displayed. When no keypad is pressed, a blank "O" (square) is displayed...
POWER FAILURE & FAILURE CODES
Power Failure: After a power failure, the WELCOME screen will be displayed.
F2 Keyboard Failure: Refer to the Tech Sheet and conduct a touch panel continuity test.
F3 Humidity Sensor Failure: Refer to the Tech Sheet and test the sensor.
F6 Microwave Relay Failure: Check the microwave relay.
F7 Microcomputer Board Failure: Change the microcomputer board.
Hope helps.
Apr 12, 2011 | Whirlpool Microwave Ovens
My microwave oven stop working. buttons will not work and an error code F3 come up on display. Could you tell me what this could be?
F3 is a shorted key you need a new keypad control panel. For the JE2160 series countertop model this should be the part#WB27X10681
Dec 06, 2010 | GE JE2160 Microwave Oven
GE countertop microwave shows "F3" on display, won't work
F3 on a GE means you have a shorted membrane keypad.
There are two ways to fix this model, either replace the membrane keypad which is a lot of work (handy guide with pictures) or to replace the complete controller.
It's probably not going to be economical even to repair it yourself if you or a friend want to. It depends on the model:
JES1334WD001
JES1334WD01
JES1334WD02
JES1334WD03
JES1334WD04
I looked up parts prices for the -02 verison.
ref # 38 part number WB27X10554 membrane keypad $69.71 here (compared to $112.50 direct from GE!)
ref # 42 part number WB07X11076 complete controller assembly $131.01 here (compared to $196.25 direct from GE!)
prototech@usa.net
Microwave Oven Control Panel Repair Nationwide
Jun 02, 2010 | GE Microwave Ovens
Key pad lockout and load beeps
Since it's a basic counter top microwave, this may not be worth repair when you consider the cost of a new comparable unit.
The part number of your keypad is
WB27X10624 and you can get it here for $51.37 plus shipping.
Dec 27, 2009 | GE Countertop Microwave Oven
Lights turn on and off, keypad is out of control, F3 Code appears in the display.
We regularly repair such control units for customers nationwide by mail in about a week or so with a one-year guarantee.
Feel free to contact me directly (and please remind me of your full model number) for pricing and more information & help.
William E. Miller
prototech@usa.net
May 13, 2009 | Microwave Ovens
Mar 22, 2009 | Frigidaire FMV145K Microwave Oven
F3 Error on Display
F3 on a GE / Hotpoint microwave means you have a shorted keypad.
Direct spraying of cleaners on the keypad and steam from the cooktop can damage the controls.
Always spray non-ammonia cleaner on a soft cloth (not a paper towel which can scratch) and gently wipe the keypad.
If it will not successfully dry out, it will need to be repaired.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
If you would like to have us do this for you, we do that for $39.95 plus part costs.
William E. Miller
prototech@usa.net
Sep 07, 2008 | GE JVM1870 Microwave Oven
Oven error -f3-
In most cases that code means you have a shorting keypad.
If you could post the full model number, I'd be happy to point you to the best source in case you or a friend want to replace it yourself.
Otherwise, we regularly repair these for customers nationwide for $39.95 postpaid plus thew cost of the keypad.
Details of our service and critical safety information and disassembly information is at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
Feb 11, 2008 | Kenmore 66312/66319 Microwave Oven
Microwave Ovens Logo
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
