Question about Digi-Tech Audio Players & Recorders
Diditech AA-0470 Amp with DigitechIR-1810 Infra red remote extender
Hello , I am having trouble with the volume control with the above combination.I am playing music from my PC through a Digitech AA-0470 Amp to 4 outdoor ceiling speakers in my patio in which i am using Digitech IR-1810 Infra Red remote extender kit for volume control.When raising or lowering the volume by the remote , the volume keeps raising or lowering once toy have taken your finger of the remote. and also by moving the adhesive Infra red diode(part of IR-1810Kit) over the infra red reader on the amp(for the remote)the volume goes up or doen by its self also , causing the lights on the amp to flash between the inputs Ee.g btween tape . phono , tuner etc on the front of the amp.Can you help please..
Regards Karl Oliveri
Email-koliveri@bigpond.net.au
eagle338
  • 4889 Answers
SOURCE: do u need an amplifier and a mixer if using a computer for party music
you will need an amp for extracting more power outta your speakers...Also you will have better control on bass, treble and other settings...So if you want to feel the sound you might need an amp....and a mixer of course if you wanna mix it up!
Regards,
Eagle!
Posted on Nov 04, 2007
SirHanz
  • 145 Answers
SOURCE: Connect 5 piece Sony seperates stereo system
OK, this is pretty easy to do. First connect your leads from the component outputs(i.e., tape, cd, phono, etc) to the recievers corresponding input for the device. Then connect the recievers outputs to your equalizer, if it is a seperate eq. Then the outputs of that to your amplifier, then your speakers to that. Be sure all of your wires are connected with the proper polarity. These instructions may be a little different for your exact setup but basically follow the same order minus any device you dont have.
Posted on Feb 04, 2008
  • 4 Answers
SOURCE: I need to connect my turntable to my reciever via Pioneer GR-470 pre-amp
no need for phono, you can go to radio shack and get a selection switch to make things easier.
Posted on Oct 14, 2008
SOURCE: My Logik L22LID628 tv has
We have had two of these tvs break within 2 days of purchase, in our case both times it seems to be a backlight failure. Did you wall mount your tv? If so when you take the base off it leaves a hole in the casing leaving circuitry visible. I think it's very easy to damage the ciruitry.
Posted on Nov 03, 2008
  • 328 Answers
SOURCE: wiring car amp up
the rem wire is for switched power from your head unit usually most after market stereos(head units) have an output for the rem wire.......if not use the power antenna wire from the back of the radio (usually blue or blue white) as for the input you need to use one or the other low or phono
Hope this helps..Good Luck!
Posted on Dec 15, 2008
HOW DO I SET UP MY Digitech 1500, TO CHECK MY aa & aaa BATTERIES ?
http://www.instructables.com/id/Testing-batteries-with-multimeter/
Jan 27, 2018 | DIGITECH Music
Tip
How to connect an iPod to a Tritton AX720 Touch
<p>While the Tritton AX720 headset is designed to communicate with other users play games on Xbox 360 and PlayStation 3 game consoles, can also be used to play music from your iPod to surround improving the sound. The kit comes with AX720 Controller in a row to adjust the volume of the headset to adjust, and in combination with an audio cable to connect the controller online for the iPod Touch. Unfortunately, since the iPod Touch is connected to the controller in-line, you cannot communicate with other users if you play a game simultaneously. <br /> <p><br /> <p>1. Connect one end of the stereo audio cable to the door on the right side of the controller online. <br /> <p><br /> <p>2. Connect the other end of the audio cable stereo headphone port at the bottom of the iPod Touch. <br /> <p><br /> <p>3. Connect the headset cable into the headset jack is located on the back of Tritton AX720 amplifier. <br /> <p><br /> <p>4. Connect the power cord from the power amplifier of the port, and plug the adapter into an outlet. Press the power amplifier, which is found on the front of the unit. <br /> <p><br /> <p>5. Press the "Play" button on the iPod Touch to play the music to start. Slide the wheel on the right side of the in-line volume controller to adapt the music to hear. <br />
on Aug 05, 2011 | Computers & Internet
Tip
Midi files - no sound. Windows XP
If other formats of audio files like MP3 - Wav etc. can be played on the computer, but not MIDI files:
1. Open the "Controle panel".
2. Open "Sounds".
3. Under Tab - Volume - activate "Advanced".
4. If the "SW Synth" is Muted - remove the "V" in the box.
5 If the volume is set to minimum - increase the Volume.
You should nov be able to play Midifiles - with sound.
(above routine is for Windows XP)
Enjoy your music !!!!!
on Feb 13, 2011 | Computers & Internet
How can I get instruction manual for digitech xc0430 weather guage ?
Hello!
Please kindly check - here is the list of Digitech devices. Hope you can get here the one you need or a similar one.
https://manualsbrain.com/en/brands/digitech/popular_categories
Oct 20, 2017 | DIGITECH Music
I have this remote to a Iview 3500stbii converter box, wont turn chanell or volume,flashing light only
Check the remote control for its infra-red emission. Check it with fresh batteries. Check by pressing all the buttons on it; and see whether all of it generates infrared signal while pressing. If it is found OK, check and replace the infrared sensor inside the TV. If you wish to get some details; check the site linked here. It has details about how to check a remote control; by one among the post. Pull up older posts. If the remote control is found OK; check and replace the infra-red sensor inside the TV. Contact any service technician.
http://electro-medical.blogspot.com/
Dec 29, 2016 | Televison & Video
User manual for digitech audio AA-2014
not sure if this link will help you to find the manual you are looking for.
http://manualswarehouse.com/manuals.htm
Dec 23, 2016 | DIGITECH Music
Sound volume when remote button is pushed will not stop up or down unless another button on the remote is pushed. Volume works fine when buttons on the TV are pushed.
Check the remote control for its infra-red emission. Check it with fresh batteries. Check by pressing each button on it at a time; and see whether all of it generates infrared signal while pressing. If it is found OK, check and replace the infrared sensor inside the TV. If you wish to get some details; check the site linked here. It has details about how to check a remote control; by one among the post. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ If the remote control is found OK; check and replace the infra-red sensor inside the TV. Contact any service technician.
Jun 09, 2015 | Toshiba 32C120U
My digitech 4 harmoniser is cutting out, have sent for a new power supply adaptor to see if this is problem any other ideas?
Most likely it is the power supply, but if you have a unit that uses the same voltage, you may want to try it. Another possibility would be the power input jack or where it is soldered to the board. If you're not comfortable working on those elements and the PS doesn't work out, take it to the shop.
Mar 06, 2015 | Digi-Tech Digitech Vocalist Live 4...
Foehn &amp;amp;amp;Hirsch 19" T.V can't get any services. Has anybody ever heard of this make.
Check the remote control for its infra-red emission. Check it with fresh batteries. Check by pressing all the buttons on it; and see whether all of it generates infrared signal while pressing. If it is found OK, check and replace the infrared sensor inside the TV. If you wish to get some details; check the site linked here. It has details about how to check a remote control; by one among the post. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ If the remote control is found OK; check and replace the infra-red sensor inside the TV. Contact any service technician.
Jan 05, 2015 | Televison & Video
Onkyo RC-738M remote control mute does not work and volume control is intermittent. How to fix?
If the remote control is found OK; check it with set it up to an other set-up code said for your TV. If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common set-up codes to check with TVs and other devices are given, in the order of the "device's brand name list" in alphabetical order. Pull up older posts. Surf the site with patience. Surf the sites by type in the brand name to your set, in its search box.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Dec 05, 2014 | Onkyo Televison & Video
537 people viewed this question
Top Digi-Tech Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Digi-Tech Audio Player and Recorder Expert? Answer questions, earn points and help others
