Question about GE (PSS26MSRSS) Side by Side Refrigerator
I have a GE side by side refrigerator that isn't keeping steady in temperature in either side consistantly, and hasn't almost since the day it was delivered. I understand that a faulty 'thermistor' could be to blame. Where exactly can I find this part inside my unit? It is GE model # GSL25JFTABS
    President:
  • 1,430 Answers
The thermistor is located under a cover on the inside of the fresh food section . It is usually a small vented cover on the side, it could also be on the back wall. From the diagram it appears yours is under the cover where the light is. You should have between 15.5k- 16k ohms at 72 degrees. There is also a thermistor in the freezer section but is unlikely the problem. Here is a link that should help http://appliancehelponline.com/sxsfreshthermistor.html
you can also enter your model # for diagrams and illustrations
Posted on Jul 22, 2010
Ge pss26sgpass keep in defrost error code bc ?????
That is actually a "tc" error code.
This error means that the display board isn\'t communication correctly with the temperature control sensors which is why it\'s giving the error. It may stop cooling so you need to keep an eye out. Either way, try to unplug the unit for 5 minutes (don\'t plug it in early it\'s hard on the compressor). Plug it back in and see if the error goes away. If it doesn\'t, you need to order and replace your display control board because it\'s just not working correctly unfortunately.Here is the board to order.
Dec 01, 2012 | GE (PSS26MSRSS) Side by Side Refrigerator
Temperature Cycles Inconsistently in Freezer and Fridge
Possible thermister our main board. Would need take readings at the board to see what the themisters are reading. If they check good then issue would be in main board
Aug 20, 2012 | GE Monogram Side by Side Refrigerator
I have a GE side-by-side refrigerator/freezer that's not maintaining cold temperatures. I was told to replace the defrost thermostat which I did and it seemed to work for about a week or so. But now it's...
If the refrigerator isn’t cooling at all the motherboard is a good possibility burnt marks or not. If the fans are not running it could be a defective fan, motherboard or both. Take a look at this page http://www.appliance-repair-it.com/refrigerator-fan-motor.html
If the refrigerator isn’t defrosting properly, after a few days the freezer coils will get blocked out with heavy frost. There are four things that will cause this, defrost thermostat, defrost heater, evaporator thermistor and the motherboard. This page should help http://appliance-repair-it.com/GE-refrigerator-repair.html
Jul 17, 2010 | GE GSS25JFPCC / GSS25JFPWW Side by Side...
The freezer side of our Samsung SR-2026CVW is unable to hold a steady temperature, and some times the temperature rises to 0. Unpluging the mains for a few moments seems to cure the problem for a short...
you do not say how full/empty you keep the freezer.
pad out empty spaces with any spare foam (stops air movement when you open door) could be faulty temp sensor...or auto defrost sensor .......rare.
Feb 08, 2010 | Samsung RS2630WW Side by Side Refrigerator
Monogram refrigerator can't keep temperature constant
We need to look behind the rear panel in the back of the freezer and need to look at the mother board on both sides. Will need to unplug and begin. Let me know, Sea Breeze
Aug 18, 2009 | GE Profile PSW26P Stainless Steel Side by...
Freezer temperature is not consistent
No recall that I have on my listing for that model. Keep in mind that the refrigerator goes into a defrost mode that lasts up to 30 minutes. It happens anywhere from 10 hours to 60 hours of operational time. When this happens, it's not uncommon to see 20 ° temperature. If you check it again an hour later, it should be back under 10 °. Also, double check to be sure the condenser coils are really clean. That alone can also cause this sort of symptom.
Oct 24, 2017 | GE Refrigerators
Refrigerator not keeping cool
Your coils could be clogged with debris. i had the same problem. You can go to home depot and get a specific brush that you can use to clean out the coils. They are either behind the fridge, or under the fridge. Do it on a regular basis, cause that can cause the compressor to burn out. I am not an expert, but that worked for me
Feb 13, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
GE Profile Arctic Side x Side Refrigerator PSC23MGNA
if you were able to do the test... check the compressor unit, also the do check on the electrical relay of the ref.
Jul 01, 2008 | GE Profile CustomStyle PSC23MGSWW 36" 22.7...
GE (PSS26MSRSS) Side by Side Refrigerator Logo
382 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
