My washer is not completing its cycle and the display is saying E20. Any ideas?
  • 12,061 Answers
E20. I have read that it's a problem with the pump, or drain hoses
remove the 2 screws on the bottom and the front access panel comes off
pump is on the right, remove hoses from it, remove pump from machine then remove whatever is in the pump
Posted on Jul 22, 2010
Frigidaire gallery series keeps saying E20 and the clothes are still very wet at end of cycle. What can I do to fix this problem?
Thank you for your inquiry, B.paddock!
From what you have described your Frigidaire washer is displaying an "E20" code and once the cycle is completed the clothes are still wet. Typically, an "E20" code stands for the water is not pumping out fast enough. You should check your drain hose to make sure they are not restricted or clogged. If your hose is fine it could be a possible issue with your main control board or drain pump. I would then suggest contacting a professional technician for proper disassembly of your washer and replacement of the electrical components. If you do not have a professional connection you can visit your manufacturer's website to locate a technician in your surrounding area. I hope this information is helpful. -Matt
Feb 23, 2015 | Frigidaire Washing Machines
My washer is displayin e20 it starts the cycle then stops and displays e20 and it doesnt empty
Unplug it and WAIT 30 min. then replug it to reset the board. this will work most of the time when it does not work any more throw the washer out and buy one that has knobs on it as the part to fix the washer costs more than a new one. DO NOT buy washers and dryers with digital displays or touchscreen controls as they are not cheap to fix. Once again the parts cost more than a new washer. Pokey Delaroderie
Oct 21, 2012 | Washing Machines
Says E20 quits washing or spinning,end of cycle beeper goes off and says E20?
This error is caused by a clogged drain filter located under the drum assembly.
Jul 30, 2011 | Frigidaire ATF6000ES Front Load Washer
E20 showing on display, machine still got water in
E20 is related to the pump and as you say a strange noise is there I would check the filter for foreign objects.E90 is normally a communication problem between the main programmer and the display module.There may have been a fault in the pump which has caused a fault at the Programmer.That model was first produced in 2002 but it is worth checking pump and filter first.If you find anything in filter then clean it out and give it another go the E90 error may have been a glich.Best of luck.
May 04, 2010 | Zanussi FJD1666W Front Load Washer
E20 fault display
E20 is a fault either in the filter/pump or drain.
The water must be drained thru. the little hose by filter or get machine to back door and undo filter plug and drain onto back step its quicker.With filter out see if any blockages,shine torch up in filter hole turn to spin/drain and see if pump blade spins if not then get long screwdriver and turn blade to free if no joy pump has to come out to free,hopefully this will work and refit plug and check for leaks.Then try again.
Good luck.
Apr 19, 2010 | Zanussi ZWF1420W Front Load Washer
Washing cycle does not complete and I get error E20 with beeps
The E20 error means that the thermistor resistance has drifted or the temperature scanning sequence is incorrect. The ambient temperature could be below freezing.
Check the thermistor and associated wiiring for correct resistance and operation and replace if required.
Dec 28, 2009 | AEG Lavamat 72640 Front Load Washer
Error E20
zanussi error E20 suggests a pump/draining problem. remove pump/filter and clean it all out. its located at the end of the drain hose at the bottom of machine. power off. it might need replacement.
Nov 01, 2009 | Zanussi ZWF1430W Front Load Washer
AEG Lavamat Turbo 12830 - error code E20
Hi
E20 means there is a bolckage in there
remove filter and clear any debris in there and check impeller is turning ok.
regards
Mar 21, 2009 | AEG Lavamat 16810 Front Load Washer/Dryer
E20 message
Hi Helenw,
The error message E20, simply means the filter plastic cage which is located behind the trap door bottom right side of the machine is full and needs to be cleaned out.
All the fibres and lint gets trapped in here and prevents the waste water from escaping, hence Error code E20.
Regards,
David
Sep 12, 2007 | Zanussi WJS1265W Front Load Washer/Dryer
Washing Machines Logo
37 people viewed this question
Top Washing Machines Experts
