Question about Akai CFTD2011 20 in. EDTV-Ready LCD Television
I was using another tv. When I re-hooked my Akai tv, the picture was only black and white. How do I get it back to color?
  • 484 Answers
First you try to re run the connection of the television.
Then you check if your television is on pal or ntsc or any other settings that supports color on the television.
After checking that, you can also go to the color settings from the menu of the television and try to fine tune or set color on the television.
Take care
Posted on Jul 22, 2010
  • athena42 Jul 23, 2010
    I cannot find the color settings for my Akai tv Model CFTD2011.
Dvd playing hooked up to an old t.v. plays in color when i hook it up to my lg tv it plays in black and white?
My DVD player only plays in black and white - TOSHIBA FORUMS
forums.toshiba.com/.../My-DVD-player...plays-in-black-and-white/.../47...
39L1350U) and am trying to hook up the DVD player. ... My DVD player only plays in black and white ... My DVD player is an old Sony. .... Was using and S-Video connecting cable to the TV. ... suggested to use VIDEO instead of COLOR STREAM, I changed that in the TV menu, plug the red and while at the back of TV where ...
No Color When My DVD Player Is Hooked Up - Community ...
community.insigniaproducts.com/...DVD-Players/...Color...My-DVD-Pla...
Jul 14, 2014 - I hooked up my DVD player and I have no color. ... you need to use the connections on the left side of the TV or on connections on the back. .... is turned on, which can cause this black and white image issue you're having. ... If the Player shows correctly on a different TV with the same hook up, and different ...
The picture from a disc player displays on the TV in black ...
Jan 17, 2016 | LG Televison & Video
My tv picture is bouncing up and down
may be there is a problem in setting of ur colours
Jun 07, 2008 | Akai PDP4206EA Television
I hooked up the dvd but I get a picture but no sound
audio cables need to be hooked up as well not just a video cable.
usually red and white and clearly colored on the output side of the dvd player and the tv. input is on the tv output is on the dvd, also if you are using a fiber connection (optical sound) you will need a fiber cable from the dvd to the tv.
Jan 31, 2010 | Akai PDP4294 42 in. EDTV-Ready Plasma...
TV in black and white
I did the same thing... the wiring is hooked up wrong...If you are not using HD then use the side hookup...Probably a better way but it worked for me..
Mar 05, 2009 | Philips 47PFL3603D LCD TV
I am trying to connect an akai dvd player to directv, please help
ruettab,
good day. to connect your any DVD player to any TV screen always remember this color code
from DVD back part:
yellow = video out
red/blue/green( in a row) = component video out ( this can only be used for screen with component video inputs)
Black = digital audio ( rarely use unless)
Red and white (in a row) = Audio output (left and right audio)
where to connect from TV screen.
Locate where A/V INPUTS (audio/video socket) from your TV screen, you can see it either at the BACK/SIDE or somtimes in FRONT of TV screen , having marked as "AV1"AV2"AV3' .
Once you found TV input, you must first have RCA cable (color code cable to connect player to screen) then connect the RCA cable at the back of your DVD player, simply follow color code
RCA yellow marked cable = DVD yellow socket
RCA RED and WHITE marked cable = DVD RED and white socket (second row for your player)
then connect the other end of the RCA cable to TV screen, first select which input where you gonna place the DVD player ( either AV1, Av2 or Av3 if do have multiple inputs)
once decided which INPUT to connect the player.
ex. if you select AV1 as input there would be 3socket on its row (yellow/red/white)
now connect the other end of RCA cable to the screen by following the same color code:
RCA yellow cable = TV screen A/V1 input yellow socket
RCA RED and White = TV screen A/V1 input red and white socket.
cheers,
mark
Jan 31, 2009 | Akai DVD-3850S DVD Player
Black and white picture
you have the cables hooked up the wrong way
Nov 09, 2008 | Mitsubishi WS-55809 55" Rear Projection...
Lg 32lc2r, only showing picture in black and white
Make sure that the color control level is set to the default or 50% to start with. This should be in the Video menu.
The colour for the tuner and for the encoded base-band video uses a circuit area called the colour demodulator. It is possible that this cirucuit area has failed and needs servicing.
Jerry G.
Jan 08, 2008 | LG 32LC2R 32 in. HD-Ready LCD Television
Componet 1 and WII
First of all, make sure that you have the colors of the component cable matched correctly. You can switch the Pr and Pb cable and still get a picture although in the wrong color.
Secondly, go to the TV menu... the menu should still be in color. If it is in B/W then you might have a hardware issue. Try adjusting the custom color setting so that you get a blue picture or red picture. There is an option for adjusting the color called "blue mute" it should give you a perfectly blue picture. If you still don't get any color than it is a hardware issue. It could be the Main Board or the Control Board.
It was the Main Board in my case.
Oct 07, 2007 | Akai PDP4206EA Television
NO Picture in Color except for PIP
have a tech check your tv the color circuit needs to be looked upon.good luck
Apr 29, 2007 | Akai PT5492S 54" Rear Projection...
Akai CFTD2011 20 in. EDTV-Ready LCD Television Logo
23 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Marvin
Marvin
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
