Question about JVC C-13910 13" TV
Hernandez030763@yahoo.es JVC C-13910 Tv I need IC Regulator and B+ (FlybacK), if is possible its characteristics.
  • 298 Answers
The flyback for JVC C-13910 is listed below. Do you have the location number for the IC Regulator?
JVC C-13910 Flyback T1522
Posted on Apr 22, 2008
Sir, can you help me, about my tv Model av-s21x1 jvc, problem is no light on picture tube. I measure supply voltage B+ at the flyback and also measure at horizontal transistor B+ is present, But at the...
Have you got horizontal drive?
There was a favourite quick repair on these TV's with that problem. The line driver coupling transformer had dry joints and in two cases the line oscillator/processor IC was poorly soldered and also one with the Xtal un soldered.
Hope that helps.
Dec 13, 2010 | JVC Televison & Video
Tv has no picture
try adjust screen in flyback, if you see a white line in bottom, the vertical ic have cold solder or is bad.
Apr 28, 2010 | JVC AV-27530 27" TV
I HAVE A JVC AV27D302: THE PICTURE IS FOLDED OVER
For how many years this TV with you? Most tv now a days after few years of using vertical IC solder started to dry(dry solder) you can try to re-solder or you may check also two capacitors (100uF/35V) for most JVC model has this symptom with this parts changes its electrical characteristics. If still problem persist replace vertical IC. Hope his helps, Good Luck
Feb 14, 2010 | JVC AV27F476 27" TV
Panasonic TV no sound no picture
THE REGULATOR IC STR ??? OR THE HOT TRANSISTOR MAYBE SHORTED
Aug 23, 2009 | Philips 27PT543S 27" TV
Tv shuts off after screen goes red
Good Day sir, the reason why your tv act that way is the switching power supply. The power supply regulator, cannot supply the current needed by your TV. these can be caused by several factors. a faulty switching regulator, low power, or filter capacitor leaking, check the voltage across the VCC after the regulator, if possible the switching transistor. and the ic that controls the pulse they are usually near each other. for safety reasons, better consult your service personnel. hope this helps. if you need more assistance, do let me know. thanks
Jul 28, 2009 | Televison & Video
Tv shutting off timer light blinking
Your TV is in the protection mode. First, locate the horizontal output transistor. This is found very close to, or next to, the horizontal output transformer (also known as the flyback). The flyback should be on an aluminum heat sink, or on the side of the metal chassis. Disconnect or unsolder two of the three legs of the transistor. Measure it with your meter, or plug in the set with the light bulb attached across the fuse.
If the transistor is shorted, or the light bulb doesn’t glow bright anymore, replace the transistor and plug back in. If the light bulb glows bright again, you must replace both the flyback and horizontal output transistor simultaneously. In some cases this will fix the set, but sometimes there are multiple problems with a set.
Go to where the flyback is, and start measuring the diodes and capacitors on the flyback itself. If you don't find any shorts there, it could be a shorted vertical output IC, a shorted sound IC, a shorted disc capacitor in the Hi Voltage/sweep circuit, or in rare cases, a shorted capacitor or tuner.Feel free to ask and post whatever the result of your troubleshooting..
Hope this may help;
Regards,
VOTIT
DON'T FORGET TO RATE
Aug 30, 2008 | JVC AV-27D303 27" TV
Hi Buddy,
I can,t help you out Here.
Televisions are not my speciality. I repair X-Box Consoles-PCs And Laptop Computers. You Might Try Ginko.
He may be able to help you out Here.
Mike @ Compurepair.
Apr 24, 2008 | JVC C-13910 13" TV
TV won't turn on
Check supply at BU508 COLLECTOR. IF SUPPLY DROPS BELOW 100V LOT IS FAULTY. CHANGE LOT.PROBLEM SOLVED
Aug 22, 2007 | Philips TS3259C TV
It sounds but cant' see the imagen
You need to find out why the set is blanking the video. In order of being common: 1. AKB circuit. AKB circuit is seeing a very unbalanced crt and blanks the video. To fix replace the crt. 2. Loss of vertical deflection. 3. Problem on the data or clock lines. If you can change channels and the volume, this is ok. 4. Loss of h-sync return pulse to the micro or jungle ic.
Mar 19, 2006 | JVC C-13910 13" TV
JVC C-13910 13" TV Logo
65 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
