Question about HP LaserJet M1522nf Multifunction Printer (CC372A)
I installed a 36A toner into an hp CB436A and my printer is displaying memory error
    Sniper:
  • 56 Answers
It is actually the same. As you can see both end in 36a. The supply error might show a numeric code: 10.1000. If that is your case try to get the toner replace, specially if the toner is generic. That is caused by a defective chip in the cartridge.
Posted on Sep 08, 2010
Hp laserjet m1120 mfp say supply memory error what can i do
Is a chip cartridge problem, If the chip has an orange plastic top, take it out.
If not work, replace the chip or simply replace the cartridge(CB436A).
Jul 30, 2011 | HP LaserJet M1120 MFP All-In-One Printer
I am receiving error 10.1000 supply memory error
10.1000 Supply Memory Error
A specific print cartridge has a missing elabel.
Reinstall the print cartridge.
Turn off and then turn on the product.
If the problem is not solved, replace the cartridge(CB436A)
Jul 22, 2011 | HP LaserJet M1522nf Multifunction Printer...
Hi im ali ( 10.1000 supply memory error ) for printer hp laserjet m1522nf please say me what im do it thanks
Hi Ali
Probably the printer no recognize the toner cartridge. Check the chip on toner cartridge (if have if there is an orange plastic, remove it. If not replace the toner cartridge for a new one."CB436A")
Good Luck
Jul 04, 2011 | HP Hewlett Packard LaserJet 3000dn Printer
Hp laserjet m1522nf 10.1000 supply memory error
First check the toner cartridge orange plastic on the chip (the orange plastic protect chip, whe you insert a new cartridge toner, remove it). If not plastic on it jump to the next step.
Replace the cartridge toner (CB436A) for a new one.
Jun 28, 2011 | Office Equipment & Supplies
Hp laserjet P3005n gives memory test error when powereds
I am assuming that the printer is giving a supplies memory test error in which case it is a faulty micro chip on the toner cartridge. If this is the case then you need to replace the toner cartridge.
If the printer is not displaying supplies memory error, but actual memory test error then the problem is in the memory on the Formatter Board. The formatter board in these printers are prone to faults.
If your board has an added memory stick, I suggest that you remove it after turning off the printer and then power on again and see if the error is still displayed.
Jun 10, 2011 | Office Equipment & Supplies
10.1004 SUPPLY MEMORY ERROR ON IMAGING DRUM Unable to read the supply data. Re-install the supply. If the error reappears, contact support.
Memory Supply Error 10.00.00 The printer is unable to read or write to the print
cartridge e-label, or the e-label is not on the cartridge.
Basically what is happening is the printer cannot read the small chip on the toner cartridge. The chip is located on toner cartridge as it is inserted into the printer. 1 - Make sure the toner is firmly seated into the printer. 2 - Power cycle the printer with the toner out of the printer. Install the toner back into the printer. 3 - Install another toner cartridge. 3 - Verify that the e-label connector is firmly seated in connector
Contact a local HP Authorized Service Center for further assistance.
Jul 03, 2010 | HP LaserJet 2840 All-In-One Printer
My hp 2480 has an error message 10.1004
the #10 error codes are supplies memory errors, it's saying toners installed don't match what's in the memory. Could be dirty contacts or generic toners.
Sep 29, 2009 | HP LaserJet 2840 All-In-One Printer
Loading 36A cartridge
open the toner cover, take out the old, pull seal off new cartridge if applicable, put in the new cartridge, close cover
Apr 07, 2009 | HP Office Equipment & Supplies
Toner refill
IMPORTANT: This will most assuredly destroy your printer. The toner cartridge must be completely rebuilt with new seals, also. This is why the cheap replacements occasionally leak toner. That toner powder gets down in your printer & onto the fuser. This will cause the fuser to have different temperatures along its path, ultimately rendering it useless.
I strongly suggest that you buy a genuine HP toner refill.
Jan 21, 2009 | HP LaserJet 1005w Printer
HP LaserJet M1522nf Multifunction Printer (CC372A) Logo
161 people viewed this question
Ben Johnson
