Question about AEG 24 in. Favorit 60830 Free-standing Dishwasher
How can I reset an i30 (flood control) error?
AEG 60860 dishwasher: how can I reset an i30 (flood control) error?
Thks
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 174 Answers
You have to mopp up any water in the base of the machine. this can be caused by a leak . a sagging pressure pipe to the pressure switch can do it as well. you can tie it up to stop the sag. its at the front behind the plinth area.
Posted on Jul 22, 2010
Error code i30 (leak). How to fix it?
Hello friend, I appreciate your inquiry!
Based off my understanding your dishwasher is displaying an error code of I30. An I30 error code means this could be an issue with your aqua control. I would suggest performing a reset on your dishwasher and you can do that by flipping the household circuit breaker off for at least ten minutes. If you continue to receive an I30 error code after the reset I would recommend having a professional technician out. This will help you avoid any unnecessary part purchases. Hopefully this information is helpful to you. -Matt
Dec 13, 2015 | Electrolux Dishwashers
I have an AEG F55002ViOP dishwasher. It's making a strange grinding sound and showing error code 30. Can anyone advise how to solve this please.
Error "i30" means that water remains in base because leakage or overflow. In this case, in order to prevent flooding, drain pump running continuously.
When we talk about AEG dishwasher, drain pump works even the power is turned off (must be connected to the wall outlet, otherwise anti-flooding system will not work).
The noise what you heard during operation indicates that something is blocking the drain pump.
Remedy: you should first remove the water from the bottom of the dishwasher and determine leakage then check why the drain pump makes noise.
If you work around the dishwasher, you always take care that appliance must be disconnected from the power supply.
Good luck.
Dado
Oct 11, 2014 | AEG Dishwashers
How to fix anti flood error on F60860
Remedy: you should first remove the water from the bottom of the dishwasher and determine leakage.
Dado
Sep 28, 2014 | AEG 24 in. Favorit 60870M Free-standing...
I30 message on aeg favorit 50879 u
Activated Anti-flooding system, means water leakage in the buttom of dishwasher. Could be also: faulty Anti-flooding microswitch, floating sensor (styrofoam) blocked mechanically, wiring diagram, electronic.
Dado
Jun 17, 2014 | AEG 24 in. Favorit 40850 Free-standing...
How to fix code i30
Dado
Jun 01, 2014 | AEG 23 in. Favorit 86070Vi Built-In...
How to connect incoming power cable live and neutral to AEG FAVORIT 60860 dishwasher?
I think it is best to connect power cable directly to the interference filter where is normally connected.
The interference filter is connected in the terminal board parallel to the mains feed. See below pictures:
Dado
Apr 07, 2014 | AEG Dishwashers
Error code i30 what is it
Dado
Apr 07, 2011 | AEG 24 in. Favorit 80860iW Built-in...
Hi. I'm getting an i30 message on my dishwasher. This is an anti-flooding protection.How do I reset it? The waste filter was a bit blocked, it's all clean now. Cheers
depends on the model. some have a float switch in the base just removing the water from the base will reset it. othr models have alock out valve removing water pressure from the water valve can reset it. although blockages in a side tank lh side can be more complicated.you say its electrolux. aeg have a similar problem where a thin hose from the sump to pressure switch sags . tie up the pipe fixes it.
Aug 06, 2010 | Electrolux Dishwashers
Got an AL4 error on my AEG 64800
al4 is tripping of anti flood float switch in base of machine. look for a leak mopping out the base resets the switch
Jun 19, 2010 | AEG 18 in. Favorit 64800 Free-standing...
AEG Favorit 40850
yes its the flood sytem control underneath you might have a leek like i did it was the heater leaking
replaced it and now its running ok its a eay job to replace
Jul 02, 2007 | AEG 24 in. Favorit 40850 Free-standing...
AEG 24 in. Favorit 60830 Free-standing Dishwasher Logo
6,222 people viewed this question
Top AEG Dishwashers Experts
Paul Carew
Mike
Are you an AEG Dishwasher Expert? Answer questions, earn points and help others
