Question about Tommy Bahama Rlx1004 Relax Beach Cruiser watch
I cannot get to change the time on my digital watch
How to set digital part of the watch
[PDF]4 Button Digital Watch - Dakota Watch
https://www.dakotawatch.com/PDF_FILES/Digital.pdf
In normal time mode, Hold L2 for 2 seconds to alarm time set mode, then L2 again to normal time set mode, the second digits begin flashing. Press R2 to reset the seconds to "00", press R1 to switch to the minute digits. Press R2 to advance the minutes. Press R1 to switch to the hour digits.
how to set time in digital watch - YouTube
? 1:13
https://www.youtube.com/watch?v=4FmHYMeXbDA
Oct 26, 2011 - Uploaded by Vedant Sen
https://www.youtube.com/watch?v=u_H5I3H15R8 ... how to setyour digital watch {UPDATED} - Duration: 1:20. by Vedant Sen 3,424 views ... The 10 Greatest Wrist Watches of all Time REVISED FOR 2014 - Part 1 - Duration: ...
How To Change The Time On Most Digital Watches - YouTube
? 8:40
https://www.youtube.com/watch?v=kBvaePDtEUU
Jun 27, 2012 - Uploaded by Pitskate
How To Change The Time On Most Digital Watches. Pitskate ...How to change / set time on Armitron watch, 45/7004. - Duration: 2:02. by ...
Jan 05, 2016 | Watches
Please can u show me how to change the time on this watch.
Set the time on your Baby G by switching to time mode. The button on the bottom left-hand side of the watch is the mode button. Pressing it once to will set the watch to time mode. The time digits will begin to flash.
  • 2Start by adjusting the seconds. Press the button on the top-right side of the watch once. The second digits will start to flash. Press the bottom right-hand button until the correct second time is displayed. Hold down the button to cycle through the digits. Once the correct time is displayed, press the bottom left-hand button and the digits will stop flashing. Press the bottom left-hand button again to set the hours.
  • Sponsored Links
  • 3Follow the same procedure to change the hours setting. Set the time and date by cycling through the digits in the following sequence: seconds, hours, minutes, year, month and date.
  • 4Press the bottom right-hand button to set the seconds to 00. When the second display is between 1 and 29, the digits will change to 00. If the display is between 30 and 59 seconds, the seconds will revert to 00 and one minute will be added to the minutes display.
  • 5Change from an a.m. to a p.m. setting by pressing the button in the middle of the bottom of the watch when any of the time display digits are flashing.
  • Nov 03, 2012 | Watches
    The watch shows time in digital plus has hands on it like a regular watch the digital shows one time and the hands show another
    Hi jessestaton,
    All you would have to do is change the time from either the digital mode or the anolog hands , you can choose one which is incorrect and try to change it.
    Now to change the analog clock's settings , you would have a button which you can manually rotate and set the time, this is how you would be able to recognise that it's for the anolog time modification.
    If you need to change the digital time , all you have to do is find out buttons that are present on the watch , and then try to change the time.
    Note:- If you find a circled knob , remember that could only be for anolog time change as digital time is never changed using such knobs or screws , but have seperate button for that function.
    In case you have any queries, feel free to get back.
    Hope this helps ..:)
    Jun 12, 2011 | Watches
    How to change the time display
    Click on my profile (escapement), then click on Tips and Tricks. There you will find link to all NIKE watch manuals.Rate me, please.
    Mar 31, 2010 | Nike Triax CV10 Wrist Watch
    Can't adjust the date on a digital watch
    These are the instructions for the AD0721. They might apply to your model, too. I hope this helps:
    http://img261.imageshack.us/img261/6784/manualr.jpg
    The analog setting of the watch takes place by pulling out the knob (kind of tough) and adjusting, like a regular analog watch. The analog and digital displays are will NOT stay in sync, unfortunately.
    Good luck.
    PC
    May 26, 2009 | Watches
    How do I set the time on my digital nike presto watch?
    KEEP YOUR FINGER ON THE BOTTOM LEFT HAND BUTTON. WHEN IT STARTS BLINKING PRESS IT AGAIN. USE THE OTHER BUTTONS TO CHANGE TIME
    Apr 03, 2009 | Nike Presto CEE WT0001-607 Wrist Watch
    Change Time in Giordano digital Chronograph watch #1143
    KEEP YOUR FINGER ON THE BOTTOM LEFT HAND BUTTON. WHEN IT STARTS BLINKING PRESS IT AGAIN.USE THE OTHER BUTTONS TO CHANGE TIME.
    Feb 03, 2009 | Casio DW290 1V Classic Alarm Chronograph...
    Daylight savings time change without auto change in watch
    Use this page to download a copy of CASIO watch manuals in PDF format. To download a PDF file, enter the four-digit (or three-digit) module number marked on the back cover of your watch.
    http://world.casio.com/wat/download/en/manual/
    You will need a pdf reader on your pc, you will find all instructions in there.
    Mar 10, 2008 | Casio G7500G-9V G-Shock Vibration Watch
    Setting time on Seiko watch 7N43
    Mike 1935 if your watch has hands only & no digital display the crown where you set the watch pulls out half a click to set the date and should pull out a little further to set the time try that.
    bjbc I am assuming your seiko watch is a digital watch. Try holding in the top rt button if its the watch I think it is it should change to 12yr time.
    Mar 09, 2008 | Watches
    Changing the time on an LCD Digital Watch
    Press mode continuously for about 2-3 seconds then release
    Press mode again so that the seconds are flashing
    Press ADJ + ST/STP at the same time
    Adjust what you need to adjust and move between minutes and seconds by repeating the ADJ + ST/STP
    Malcolm S
    Feb 29, 2008 | Watches
    Tommy Bahama Rlx1004 Relax Beach Cruiser watch Logo
    622 people viewed this question
    Top Tommy Bahama Watches Experts
    Arturs Kalnins
    Arturs Kalnins
    Marvin
    Marvin
    Are you a Tommy Bahama Watch Expert? Answer questions, earn points and help others
