I want to change my printer settings to print on the full page, not have these 5mm margins all the way round. can someone help? I have a Kyocera FSC5015N
    New Friend:
  • 48 Answers
It sounds like you want to print what is called "full bleed" which means that you print from one edge of the paper to the other edge with no margin. Unfortunately your printer can't do this. It is a limitation of the design of the printer that is common to most laser printers. You have two options, either print with the 5mm margin all the way around and trim the paper or get a printer that has a "full bleed" option.
Henry
Posted on Apr 22, 2008
Why doesn't everything shown in preview appear on the printed page?
You need to look at your margins. Many times the screen preview extends beyond the margins. Many devices depending upon your print driver will not always print the same as on the screen. Change your margins to .5" on the document and then check the print. If you live in Southeast Florida Advanced business computers is a great source for help. Computer network repair, printer copier maintenance repairs, copier printer leasing and supplies.
Apr 06, 2016 | Kyocera Taskalfa 300ci With Feed, Print,...
Tip
Top margin, header page, the print is changed (lowered).
If you print and the top margin is altered (low), look at the figure below.
excuse my English.
on Oct 25, 2013 | Kyocera Mita FS-1030D Laser Printer
Not printing straight
Check the paper guides in the trays closely to make sure that they are set correctly.
Sep 14, 2015 | Kyocera Office Equipment & Supplies
I have a lexmark pro 901 and it suddenly just started to print blank pages. all the ink cartridges were replaced and is full, but is still just print blank pages. what is wrong?
It's because of your page set up.
If you have very small margins this will cause it.
Also Headers and Footers even though you haven't put anything in them
the printer and the word processor will allow for them.
Set up your page with a [or the metric equivalent] margin all round.
Set the Header and Footer margins to zero or remove the ticks.
When you do a printer set up remover the ticks [or however it's shown]
so the Headers and Footers are not included in the printing. In Case You Still face Problem and Need Online Assistance Then Please Follow Us For On : Lexmark Printer Support
Feb 27, 2014 | Lexmark X2250 All-In-One InkJet Printer
Kyocera Mite KM-1510 printing on half pages instead of full pages
It sounds as if the paper size at the machine is set incorrectly. Try checking to ensure you cassette or bypass if that is where you are printing from is set correctly.
Feb 16, 2010 | Kyocera Mita KM 1510 Laser Printer
Cannot print avery labels, get message the margins of section 1 are set outside the printable page, or will run thru printer , printing complete get blank page
I assume this error is occuring in Microsoft Word.
  1. Create a new document, with a full page of the label you are having trouble printing.
  2. To see the margin settings of your document, go to File > Page Setup (or Page Layout > Margins > Custom Margins for Word 2007).
  3. Click OK on the margins dialog, and Word will check the settings against your currently selected printer. If a margin is set outside the printable area (usually the bottom margin set to zero), you should see the warning message.
  4. Click the Fix button to have Word change the margins
    to match your printer. You should now see the Margins dialog with the new margin settings.
  5. Click OK.
One thing to watch for- on some inkjet printers, the printable area is narrower than the labels. This will cause the labels to shift to the right on the page and be misaligned when you print.
If the labels run off the right edge of the page display, or are misaligned when you print, an extra procedure is needed.
  1. Undo ([Ctrl]+[Z]) the new margin setting, or create a new page from the label template again.
  2. Select the entire table of labels ([Ctrl]+[A]).
  3. Right-click the table, and select Table Properties.
  4. Click the Text wrapping "Around" option, then the Positioning button.
  5. Change the Horizontal position to Center, Relative to Page.
    Uncheck the "Move with text" option. Click OK to the Table Positioning dialog, then click OK to the Table Properties dialog.
  6. Left-click (or press an arrow key) to "deselect" the table, then go into the margins dialog (see above) and allow Word to fix the margin settings again.
With the labels aligned to the page, rather than the margins, the new margin settings should not cause the labels to shift.
Once you have the margins set correctly for your printer, I would save the empty page of labels to use as a "template".
Jun 29, 2009 | Lexmark P3150 All-In-One InkJet Printer
Kyocera fs-3830 cutting off print on top of page
check the margin settings and outline settings because minor things worries us too much
May 01, 2009 | Kyocera Mita FS-3830N Laser Printer
I need to change the printer margins
Open the original document and use page setup and print preview (from the File menu) to modify the text until it fits on the page.
Otherwise, you may access the printer properties and preferences from the control panel, printers and faxes...
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Apr 24, 2009 | Office Equipment & Supplies
Huge Margin with Kyocera FS 1000+
If the FS-1000 prints too far down the page or leave too much top margin or leaves a gap at the top of the page etc (<- for google searches). This is a problem with the felt pads on the three solenoids/clutch electro magnets that are under the right panel (2 under the engine/button board, 1 under the inner plastic cover, sometimes 4 in total on other kyocera printers). They get compressed over time meaning the metal leavers come into contact with the solenoid meaning they are released too slowly. Simply replace the felt pads with .5mm cardboard or another non-sticky non-metallic material. Too thick and it prints too far up the page.
Sep 28, 2008 | Kyocera Mita FS 1000+N Laser Printer
Kyocera FS1010 first page only half printed
I found this solution. Worked a treat. I took the printer apart and applied felts to the solenoids (the felt normally used for the bottom of cup coasters).
See the Success post in this thread...
http://www.copytechnet.com/forums/kyocera/15980-kyocera-fs1010-delayed-printing-1st-page-2.html#post55451
This manual helped too...
http://www.freeprintermanuals.com/PM/Kyocera%20FS-1010%20Parts%20Manual.pdf
This is the post...
Success
A solution has been found. Thank you to Steveauh (Townsville)
Kyocera in their wisdom have used a foam insulator on the 3 solenoids that disintegrates over time regardless of use.
  1. Open the right side of the printer
  2. Disconnect all connections to engine board
  3. Remove engine board
  4. Remove plastic guard (white)
  5. remove all 3 solenoids
  6. Replace all pads on the solenoids that come up against stops
    Registration Solenoid has 2 pads (1 against the solenoid frame and the other on a stop arm, the others just the frame pad)
  7. Keep thickness to around .4 - .5mm Too thick on register arm will cause early printing.
  8. Reassemble
And that is it. The arms were being magnetically delayed due the metallic contact. It seems to be a regular problem in this chassis FS1000 to FS1030.
Jun 23, 2008 | Kyocera Mita FS 1010 Laser Printer
478 people viewed this question
jasbo
jasbo
