Question about Advantech ADAM-4520 (ADAM-4520-D2) Serial Adapter
RS 485 S7300 SIEMENS CPU MPI (MPI Protocol) CONVRETER TO RS 232 PANEL COMMUNICATION WITH PRODUCTS WHICH AL do To make
2 Suggested Answers
SOURCE: 485 to 232 conversion
<Dear Sir can ADAM-4520 transparently converts 485 to 232 as it does for 232 to 485>
Yebo, yes it can. Thanks for calling me sir.
Posted on Dec 04, 2008
Tip
Options for Adding Serial Ports The serial port is prevalent on PC's ...
The serial port is prevalent on PC's as well as scores of industrial, scientific and consumer devices, making it a convenient starting point for communications. Since RS-232 itself is only suited to short connections (50 ft. max.) many applications require that it be adapted to fit requirements. RS-422, typically used for extending RS-232 communications, provides full duplex communications between two devices. It can also provide one way communications from one master to several slaves. RS-485 communications standard allows cable lengths up to 4000 feet. It also provides very high noise immunity. Multidrop connections up to 32 different nodes can be made over a single twisted pair cable along with a signal ground connection.
This article summarizes the choices a system designer has when adding a serial (RS-232, RS-422, or RS-485) communications device. There are many different ways to add additional serial ports to your Desktop PC, Palm, or Laptop PC. USB, PCMCIA, PCI and ISA are some of the methods that will be discussed.
The Universal Serial Bus (USB) provides a high data rate and Hot Swap connection for PCs, providing an easy connection to a wide variety of multimedia and network USB devices. Generally considered to be for home or office use, USB is finding its way into Industrial applications.
PCMCIA Serial Ports are yet another way to add serial ports to a PC that has PCMCIA Slots available. Most Laptops today offer only one (if any at all) DB9 type serial ports. A PCMCIA Serial Card is a good way to add a serial port (or ports) to any laptop that is low on available serial ports (RS-232, RS-422 or RS-485).
PCI Cards are becoming more popular as a way to add serial ports to desktop PC's. PCI type slots are becoming the "norm" in standard PC's today, and PCI Serial Cards are an excellent way to add serial ports. The standard Desktop PC may only come with one serial port standard (if any serial ports at all). PCI Serial Cards use Software Drivers to address the ports to the PC.
ISA Cards are yet another way to add serial ports to the older desktop PC's. ISA type slots are becoming scarce in standard PC's today, but are still an excellent way to add serial ports. The ISA Cards are typically addressed using dip switches and shunts or jumpers to set IRQ's for each port. No Software Drivers are required with ISA style serial cards.
Palm OS PDA's may be connected to RS-422 or RS-485 data circuits using Palm adapters. These adapters offer total portability for collecting data and field service chores. The Palm device and the adapter will usually slip into a shirt pocket. Some models use the PDA's connecting cable, some include a cable and some are cradles that allow the PDA to nest in place and connect directly to the Palm base socket. PalmTerm Freeware allows you to transmit and receive data from the Palm serial port.
on Sep 12, 2010 | Computers & Internet
RunCo VX1000c RS-232 communication codes
Hi Kevin,
The manual for the RuCo VX1000c is available at http://www.aboutprojectors.com/pdf/runco-vx-1000ci-manual.pdf
The RS232 codes and protocols are towards the back of the manual. According to the manual, the PFP connects to the projector using a CAT5 cable.
HTH.
Jan 02, 2013 | Office Equipment & Supplies
All lights are on the control panel. The message reads"6700 REVC" can't turn anything on or off.
Most likely a problem in the RS-485 communication between inside and outside Circuit boards.
Email Jandyrepair@gmail.com for Help
Aug 09, 2011 | Jandy Aqualink Rs4 One Touch Control...
I´m looking for a typical
For connecting a RS-232 port with a RS-485 port you need a signal level adapter since they work with different voltage and signal types, RS-232 uses unbalanced signals and RS-485 uses balanced signals, if you want to build your own adapter please check the following schematic as a reference:
Feb 21, 2011 | Computers & Internet
NCR 7875 Scanner/Scale Communication problem with PC
You need another cable (the metrologic cable doesnt work with the same configuration) and set the button in the interface card to rs-232 and program the scanner-scale with the programing tags.
Dec 04, 2008 | NCR 7875
Want to connect to my computer
What connector/interface does your PC has
9-pin or 25-pin connector
If it has 9-pin connector: use the following:
DB-9 RS-232 Serial Connection
or
DB-25 RS-232 Serial Connection
If it has 25-pin connector: use the following:
DB-25 Serial Connection
or
If you are configuring the computer to use an RS-422A serial port, you need a special cable. Contact the computer or printer network manufacturer to see if an RS-422A cable is available. If no cable is available, contact your computer manufacturer for your computer pin assignments and have a cable constructed.
The default configuration for the serial port on the printer is for RS-232C serial communication. To set the printer to use RS-422A serial communication, change the control panel Serial Menu’s SERIAL setting to SERIAL=RS-422.
Oct 29, 2008 | HP LaserJet 4 plus Printer
Jun 27, 2008 | Advantech ADAM-4520 (ADAM-4520-D2) Serial...
Advantech ADAM-4520 Serial Adapter
The ADAM-4520 is a converter between RS-232 and RS-485/RS-422
Look on this link for the FAQ for the ADAM-4520
http://www.advantech.com.tw/support/sr_detail.asp?SR_ID=1%2D1ZFWI0&SEARCH_TYPE=FAQ
But to answer your question about converting from 9,600 baud to  19,200 baud, I'm not sure I understand. The device should support those data rates. It all depends on what you need to do.
Oct 30, 2007 | Advantech ADAM-4520 (ADAM-4520-D2) Serial...
Advantech ADAM-4520 (ADAM-4520-D2) Serial Adapter Logo
577 people viewed this question
Top Advantech Computers & Internet Experts
Rajendra Singh
Rajendra Singh
Stan Ford
Mishan Kasiparsad
Are you an Advantech Computer and Internet Expert? Answer questions, earn points and help others
