Question about Intex Easy Set Pool 15x36
How do i empty the 15" intex pool, I cant locate the drain plug everyone keeps talking about?
  • Intex Master
  • 8,404 Answers
Forgetaboutit. Put a hose into the water and siphon out the water.
Posted on Jul 24, 2010
Do I have to empty my pool to replace the side supports on an intex above ground pool
they keep the wall up. so, I would suggest to empty the pool.
Mar 08, 2015 | Intex Pool & Spa
HOW TO CLOSE THE INTEX 30 INCH ALUMINUM POOL?
get a small submersible pump much like a water fountain uses.
Aug 18, 2014 | Intex Metal Frame Pool - 12 Ft x 30 In
I am getting a error code of 92 on my intex swg. I have put 4 - 40 lb bags into a 15 x 48 pool and brushed the bottom to distribute the salt evenly. I left the pump on for 24 hrs and then set the swg for...
I installed a new Intex ECO 8110 unit on my 15' above ground, steel sided pool. After about 10 hours of use I had the "code 92' high salt alert that shut the system down. I knew that my salinity wasn't high because the local Pinch A Penny pool store does free water analysis and i was given the okay just a week prior. We had also received a bit of rain in the interim so I knew that the alert was false.
Here is how I fixed the problem (so far).
1. Turn your unit off.
2. Disconnect the power cord from the outlet and wait for 2 minutes.
3. Unscrew the retaining nut at the electro-cell connector and unplug the connection.
4. Rotate the plug 180 degrees to reverse the polarity of the plug and re-connect to the electro-cell.
5. Reconnect the power cord to your receptacle.
6. Turn the unit on, wait for the green light to burn steady.
7. Monitor for the next 5-10 minutes.
My unit has worked flawlessly for 3 hours. If i receive another "code 92" alert i will repeat the procedure which will result in bringing the unit back to its original polarity.
Jul 01, 2011 | Intex Automatic Salt Water System for ...
Cloudy water after running system for 15 hours
yes ... do you have filter media insyalled and the proper amount of salt installed?
Jul 03, 2010 | Intex Automatic Salt Water System for ...
Do I have to drain my 24 ft round above ground pool to install an intex salt-chlorine generating system? I have just opened he pool and the ph and chlorine levels are where they should be.
no need to drain go to the intex web site and look up your pool size for the starting amount of salt you need.
After ading it run your filter for at least 24 hours before trying to generate use this web site and click on the english version for pump 8110 once it downloads go to page 13 14 15
to find the salt amount you need
chlorinehttp://www.intexcorp.com.hk/proifv/proifv_dl_client.jsp?source=intexstore
Jun 06, 2010 | Intex Automatic Salt Water System for ...
I had boughten a intex pool from a garage sale and the pool is fine but the filter is leaking water everywhere and all the water that is in the pool keeps coming out.
if it has hose clamps tighten them if the area that is leaking has o rings (they can become brittle and leak water) you can purchase them at local harware store
If it is a cracked housing they can be purchased at intex.com
call them up and order your parts
Jul 12, 2009 | Intex 15' X 42" Easy Set Pool Complete...
I have a intex pool
go to intex.com and watch the video
I bought an Intex 15' x 42" above ground pool at a garage sale. No instruction or DVD were included. How is the skimmer set up?
Plug the inlet & suction openings with provided plugs
Hook up the hoses.
Release vent screw from the top of the filter housing.
Remove hose plugs.
Start pump
when water comes out filter housing vent - close it.
check for proper flow.
Thanks for using FixYa - a good rating is appreciated for answering your FREE question.
Jul 08, 2009 | Intex 15' X 42" Easy Set Pool Complete...
Intex Easy Set Pool 15x36 Logo
124 people viewed this question
Top Intex Pool & Spa Experts
avionik99
Level 1 Expert
Jay Finke
Jay Finke
Mike
Are you an Intex Pool and Spa Expert? Answer questions, earn points and help others
