Water drops are flowing in the indoor unit of samsung split ac. It is happening from the date of installation. There is no dirt block in drain pipe or the filter. Water coming from the drain pipe is small quantity. Water drops coming inthe indoor unit increases during hot summer and it decreses during winter
  • Heating & Co... Master
  • 1,997 Answers
Likely have a restriction or rise in the tubing going through the wall. as stated, could be condensation. if it's happened since the day it was installed why have you not called the installing contractor? not easy to remove from wall and inspect piping without risk of copper damage or Freon leak, recommend calling a professional
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
Posted on Dec 30, 2017
  • 2,581 Answers
I feel the water drops are condensation caused by cold air when its warm weather. There should be a catch basin to catch it and it should dry itself out in a while if not is there any place you can put one in yourself. Maybe just wrapping the pipe with a towel could help. the pipe is cold and it could cause water to form. I would try to insulate the pipe with pipe wrap. You can buy it at a hardware store. See what happens.
machtcl1
  • 61 Answers
SOURCE: Only blows hot air inside
Set thr thermostat to AC instead of HEAT.
Posted on Jan 02, 2009
carldc3
  • 82 Answers
SOURCE: LEAKING SPLIT TYPE AC
drain line is more and likely stopped up
Posted on Jan 23, 2009
SOURCE: Samsung 1.0 ton(split) AC stops working during 36-37 degree C.
i believe you have a high pressure switch on your condenser that is going bad .it is a switch that has two red wires connected to it inside your outside unit
Posted on Feb 11, 2009
SOURCE: ac split unit indoor an ouydoor unit electrical wiring diagram
machine off
Posted on Apr 25, 2009
  • 36 Answers
SOURCE: pipes frozen on outside of unit, inside unit does not work
sounds like the compressor relay is stuck in the 'on' position .... hence the compressor will not turn off .... to fix it you will need to turn off the main power (unplug) and take off the front panel then look at the circuit board normally the largest relay on the board is the compressor relay ... sometimes you can snap off the cover or break it off at times and clean the contacts ,give it a little spray with some contact cleaner or lub like wd 40 and that should be it .... alternative to this is just changing the circuit board all together ....
Posted on May 19, 2009
Why does my split ac unit leak inside the house?
This happens when the drain pipe is too high, or kinked. The pipe must be lower then the drain pan in order for the water to drain. This is a common problem.
Jul 27, 2014 | Sanyo Heating & Cooling
The indoor unit of my 1.5 T , 2 yr old split ac is making noise like cracking of ice or plastic whenever the compressor is tripped or restarted. I've noticed water leakage (splash) from indoor un
indicates dirty evaporator fins that are icing up
that will overload the compressor and trip it
the ni oise you hear is the ice breaking up and the splashing is excessive water in the blocked drain that cannot run outside
get in a technician to clean and service the ac
Nov 24, 2017 | Heating & Cooling
My Mitsubishi Split air air Con leaks water (condensation) when operating. Every month or so I have to clean the water tray of water and blow out the drain pipe. It appears that on indstalation the...
Please note the drain line should be always downwards to flow water freely. Now you lift the indoor slightly from down locked, and take drain line out through any side of indoor. Now just after 6 or 9" after make hole (levelly down) and insert to outside. Or From outside, existing drainline can be run down words. Thanks.
Feb 26, 2011 | Mitsubishi MS09TW Air Conditioner
How do we fix the split unit a/c where water is dripping from the inside unit?
It is possible that there is dirt accumulation if the filters have not been cleaned for a long time making the condensed water to flow out. Also if the indoor unit is fitted with a tilt to the front this can happen as the drain of the collected water flows out. Also the drain tube must not be damaged as it might cause the leak. So remove the front covers and check these problems areas.
Jan 06, 2011 | Heating & Cooling
Water leaking from the indoor unit of my split type ac
dear sir
i think there is in indoor unit filter is dirty it,s need to clean and after reinstall there . water drain hose/pipe is block it.s need to clean.i hope after that your problem will be solve .
hope answer the question
thank you
please vote!
Oct 01, 2010 | LG Heating & Cooling
I have problem regarding water tapping in indoor unit of split a.c.
dear sir /madam
please do every week clean your split type a/c,s filter it,s main coz who responsible for block the drain water line and after that split indoor drain ac unit drain water from inside of the unit , try to find out the drain water line of indoor unit of air conditioner the make clean it and also check it i mean keep some fresh water for make test its drain line it have been open or not if water is going easily then ,it,s ok
it,s up tp you if you think you can do it or contact to it,s technician for do solve this problem.
thank you for using fixya for get solution
please vote!
Jul 07, 2010 | Whirlwind FH-778 Air Conditioner
Water flowing inside the room thru indoor unit
blocked drain
low gas charge
cracked drain pan in head unit
Apr 21, 2010 | LG LS-K1830CL Cool Mini Split Air...
My air conditioner unit is spitting out water when I turn it on. How can I fix this?
You have to recheck your installation. The unit should be installed in such a position the condensed water runs out to the drain pipe and goes out. Please first adjust the position and ensure that the front grill portion is kept higher than the rear portion allowing water to flow out to the drain pipe.
Remove the drain pipe and clean it so that there is no dust or insect blocking the free flow of drain water during condensation.
The above would enable your ac unit to throw cool breeze and not water!
Jul 10, 2009 | Heating & Cooling
Water leakage from internal unit of split AC
Draim pans do get dirty and partialy block drain pan. If possible take a shop vac and gently **** out the drain line. This will pull the restriction out of the line and help clean drain pan. Rusty
Jun 05, 2009 | Heating & Cooling
LG LST243C-2
- Check your air filter at the indoor if clean.
- Check your evaporator fins if clean.
- Check if no icing in your evaporator and outdoor pipes.
- If your air filter and evaporator fins is clean and icing is present then your unit is under charge.
- When your indoor drips check your drain pipe if there are water comes out. If no water drain from your drain pipes then your drainage is restricted.
- Flush your drainage with water using your garden hose to flush out dirts from your drainage.
Jan 14, 2008 | LG LSC121PMA Split System Air Conditioner
Heating & Cooling Logo
198 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Marvin
Marvin
