Question about AOpen MX3W Pro-E (91.88210.241) Motherboard
I want know this is the memory typ compatible whit this type of motherboard.
    Sergeant:
  • 185 Answers
DDR2 ram is compatible with your motherboard,you can go to any local computer shop and can ask for DDR2 ram
Posted on Jul 22, 2010
    President:
  • 2,678 Answers
PC133
Is this motherboard usb 3.0 compatible
I should hope to shout, and turn about!
(Don't ask. Just something I picked up somewhere)
http://www.chiligreen.com/shop/configurator.asp?typ=24&serie=469&id=11810&shopid=4642201513&extid=3890832_176179_54366382
6 USB ports that utilize the USB 2.0 technology, 2 USB ports that utilize the USB 3.0 technology.
Regards,
joecoolvette
Mar 27, 2013 | Foxconn Computers & Internet
What type of ram (memory) is compatible with the gateway 4000676 motherboard
The memory that can be be use is DDR1 400mghz and can be expanded to 4gb.
For more detail of the specs, go to this site................ http://support.gateway.com/s/PC/R/1008835/1008835sp3.shtml
Hope that helps!
Nov 10, 2011 | Gateway (4000676) Motherboard
Upgrading memory
pc 800-45 is also compatible. you can get that one.
Dec 18, 2008 | ASUS P4T-M Motherboard
When choosing a memory for your PC
In the manual of your motherboard you can see what memosticks suported and compatible on the motherboard
If you dont have the manual but know the name of the motherboard you can find same info on the producers site
If you want me to link you you need to tell me name on your motherboard
Good luck
Dec 08, 2008 | Asrock 775i65GV Motherboard
Sistem crash
if you know what motherboard you have find the manual on the internet and you will be able to see exactly waht kind or ram you can get (i'd suggest Kingston)
Oct 16, 2008 | PC Chips M909G Motherboard
Acer Aspire Memory problem
The read speed of your new memory is not compatible with your motherboard. It is a higher rate than allowed. The reason why it works when you have one of your old chips installed is because your PC will automatically drop the higher rate chip down to the one that is working. The reason it does not drop both new chips down to a suitable rate is because it has nothing to guide it like your compatible chip does. Always check the MHz on RAM chips and compare that with the acceptable rates listed on your motherboard specs. The good news is you can probably sell those chips and have money left over when you find upgraded compatible memory that is sure to be cheaper since it is slower.
Apr 11, 2017 | Acer Aspire T650 (AST650UC3601) PC Desktop
Which type of memory?
Not required to put the same memory. Any card will do as long as it fits right :)
May 13, 2008 | ASUS A8V-VM SE (MB-A8VVMSE) Motherboard
400 MHz Memory card
Please see this link for the types of memory compatible with your ASUS motherboard:
http://www.crucial.com/search/searchresults.aspx?keywords=p4v8x-mx%20
Dec 06, 2007 | Intel D101GGC Motherboard
Ram support for intel 845 motherboard
Ok. So you've defined the Intel 845 chipset on your motherboard.
But is it the 845 or 845G chipset?
Click HERE for the specifications of the Intel 845 chipset.
Click HERE for the specifications of the Intel 845G chipset.
Peepnklown is only HALF right.
The Intel 845 chipset does NOT support PC133 memory.
The Intel 845G chipset DOES support both DDR and PC133 memory.
The difference?
The 845 has a single memory controller for DDR memory.
The 845G has two memory controllers. One for DDR and one for PC133.
Although you're going to need DDR memory as it is FASTER and less expensive than the older PC133 memory. (Believe it or not.)
I do NOT recommend using Corsair's ValuSelect memory on this chipset. I have two boards with the 845G chipset and that type of memory does not allow the board to boot.
These boards typically come with DDR266 (PC2100) modules installed.
I would go ahead and buy DDR333 (PC2700) memory for it. The board you have may not utilize the full speed of that memory, but will use tighter memory timings if the RAM is clocked down by the board. This will result in better efficiency of memory use by the processor.
Think of it as giving the motherboard "breathing room".
I could recommend PNY memory for the most basic compatability. (Not that they manufacture their own RAM modules...) Or perhaps Nanya, Infineon or Microtek.
Look for memory compatability lists for your particular motherboard module online. You could also use PNY's memory configurator on their website.
Click HERE for PNY's memory configurator.
Good luck.
Cyryl
Nov 10, 2007 | Intel Motherboard
Compatible Memory
if your motherboard is a DDR Ram supported type memory it should be able to take DDR 2100 or higher as most DDR is backward speed compatable, but it may be incompatable with certain types of ram or may need two of the same speed in each slot. Pc 266 is the double data rate of pc133 which in DDR terms is pc 2100
Apr 19, 2007 | Syntax SV266M Motherboard
AOpen MX3W Pro-E (91.88210.241) Motherboard Logo
73 people viewed this question
Top AOpen Computers & Internet Experts
Michael Galve
Michael Galve
David
David
Alun Cox
Are you an AOpen Computer and Internet Expert? Answer questions, earn points and help others
