Question about Zanussi ZX99 / 5 Bottom Freezer Refrigerator
I have a zanussi electrolux zx99/5w the freezer is working but the fridge isn't cooling down
    President:
  • 1,891 Answers
LOOK INTO THE FREEZER SIDE AND IF THE BACK OF FREEZER HAS ICE OR FROST BUILD UP / THE PROBLEM IS A DEFROST PROBLEM . The ice build up is blocking the air flow through the cold coil . the correction would be to repl the heater of the a d c control whitch controls defrost .. hope this helps ,mm
Posted on Jul 22, 2010
Where is the defrost timer in a Zanussi ZNB323W/ Electrolux/ ZNB323S fridge-freezer ? I can't find it?
The timer box is located in the compressor compartment to connect the timer to the electrical components which
defrost the battery evaporator (defrosting heater, thermal switches).
Dado
Sep 24, 2015 | Zanussi & Electrolux Fridge Freezer Handle...
Zanussi zrb324nwo fridge not chilling.freezer forming ice/frost
Sounds like a defrost component Dave Start by turning the defrost timer slowly clockwise until refrigerator stops running and then stop. Open freezer and look and feel. Is defrost beginning to melt the ice?
Fridge Freezer Timer
Genuine spare part for select models of Electrolux, Faure, Zanussi and Zoppas fridge freezers.
Defrost Thermostat
or the
Fridge Freezer Defrost Heater
If you have questions please let me know, Thanks John Tripp Appliance 911
Contact Me Here
Sep 22, 2014 | Refrigerators
How do I run a diagnostic test on my fridge freezer?
I would check the coolant pressure is correct. You may need the services of an engineer with the correct equipment and gas bottle.
Aug 11, 2014 | Zanussi & Electrolux Fridge Freezer Handle...
Zanussi zenb9950si
What is the beep for ? Temperature sensor ? Power sensor ? Door open sensor ?
Oct 30, 2013 | Zanussi & Electrolux Fridge Freezer Handle...
My electrolux ERN2820 is not working the light is on the moter is running but the freezer is defrosting and the fridge has lost it temp
Have you cleaned out the coils lately? Sometimes they become full with dust and will not cool properly. If the coils are clean, check that the fan is running. If the fan is running, maybe the compressor isn't. If the compressor is running and all else looks good it is probably low on freon.
Feb 03, 2012 | Electrolux ERN2820 Bottom Freezer...
I have a zanussi frost free fridge freezer and the fridge is not cold but the freezers fine
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Sep 01, 2011 | Zanussi Refrigerators
Zanussi fridge compartment has stopped cooling but freezer is ok
How to check everything
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp .
OR.
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
Aug 24, 2009 | Zanussi ZI918 / 12K Bottom Freezer...
Zanussi fridge freezer not cooling
no, its probably weak capacitors which provide power to switch the relay. Take the control board out and ask a friendly TV repair tech to change the capacitors
Jan 22, 2009 | Engel Freezer 22 Qt. Fridge/Freezer
sounds like the freezer evaporator has iced /frosted up and you will not get cold airflow through it. try a 24 hour defrost to clear it. then check fridge cooling.
Jun 03, 2007 | Zanussi ZEBF250W Bottom Freezer...
Zanussi ZX99 / 5 Bottom Freezer Refrigerator Logo
502 people viewed this question
Top Zanussi Refrigerators Experts
Charles T Nevin
Charles T Nevin
Colin Stickland
Colin Stickland
Dan Webster
Dan Webster
Are you a Zanussi Refrigerator Expert? Answer questions, earn points and help others
