Question about Dryers
I have a lg dryer model dle7177rm dryer will turn on and you can select cycle but the start button and all other option buttons have no effect
    President:
  • 2,267 Answers
There might be different possibilities, the internal fuse might not be providing power to the motor or the motor is burnt. You should also check and make sure the belt is good if applicable.
Posted on Apr 22, 2008
  • Jaime Hernandez Apr 22, 2008
    Check the lid switch as well. If defective the dryer won't start.
    Genius:
  • 1,142 Answers
Try to reset the power first and see what happens
  • Maanita Chadha
    Maanita Chadha Apr 22, 2008
    It blows fuses or trips the circuit breakerElectric
    dryers use 220 volts or two power lines of 110 volts each. Some
    components in the dryer need only 110 volts; the heating element
    requires 220 volts. So it's possible for one part of the dryer to be
    fine and another part to have a short circuit. Short circuits can be
    caused by the heating element, the main power cord, or any other part
    of the internal wiring. To decide where the problem lies, unplug the
    dryer, then:
  • If
    the circuit breakers or fuses remain on and/or intact when the dryer is
    unplugged, it's likely the problem is with the dryer. Contact a
    qualified appliance repair technician.
  • If the circuit
    breaker trips or the fuse blows when the dryer is unplugged, it's
    likely the problem is with the house wiring, fuse box, or circuit box.
    Contact a qualified electrician.
  • Maanita Chadha
    Please dont forget to rate FIXYA
    THANKS
    • Dryers Master
    • 19,396 Answers
    Probably you need to change the control board
    My lg dryer want start up it just clicks three times when I press the start button
    On older models the selection switch starts to wear out, click both the selection switch and timer switch around in a full circle & try starting again. If it is an electronic model, try unplugging it and let it sit 10 seconds then plug it back in and see if it reboots properly. A power outage or brown out may have effected it.
    Nov 12, 2016 | LG Dryers
    How do I turn on bell on my dryer
    From the Whirlpool user manual:
    (OPTIONAL) Your dryer may have an End Of Cycle Signal. The
    signal is helpful when drying items that should be removed
    from the dryer as soon as it stops.
    On some models, the End of Cycle Signal is fixed.
    On other models, the End of Cycle signal is part of the
    Start button and is selectable. Turn the PUSH TO START
    button to ON or OFF. The signal will sound only if the
    selector is set to On.
    Jan 22, 2016 | Dryers
    Samsung Steam Dryer has power but only displays a flashing smiling person. The dial will not turn and will not start cycle??
    Maybe you press lock button, simply unlock it again try this one
    ? What is the "Child Lock" function?
    • If you press the "Child Lock" button (Spin+Option button) longer than 2 sec during operation, this
    function is selected.
    • If once this function is selected, no change can be done until the end of laundry.
    • Press the "Child Lock" button (Spin+Option button) longer than 2 sec to cancel the function
    Jan 19, 2015 | Samsung DV419AEW 7.4 Cu. Ft. Electric...
    My LG Tromm dryer will power on but has one ligh on with two other flashing on the option select button. It won't start any run cycles.
    Most likely you have a control board problem. All those issuse point to the only thing that effects all those parts/functions of the dryer. This is about a $100 part. Call Sears parts and get a quote or go to http://www.searspartsdirect.com. Labor to replace will be in the $80-120 price range unless you bring it to a repair shop which could be cheaper.
    Feb 15, 2014 | Dryers
    The Dryer says Control Locked how do I fix it
    Which brand/model of dryer do you have? For most dryers, you need to press and hold either one button or a pair of buttons at the same time to toggle the lock on and off. Frequently the correct button or pair of buttons will be indicated with a small padlock or child's face. Some LG dryers are nice; the button is labeled Lock/Unlock. Press and hold the button for 3+ seconds until you hear a beep and see the alert go off. The Whirlpool Duet (and the Kenmore equivalent) require you to press and hold the End of Cycle button for 15 seconds. On at least some Frigidaire dryers, press and hold Select and Options for 10+ seconds.
    The control lock prevents someone from changing the settings or starting the dryer running when it shouldn't.
    If the appropriate steps for your washer fail, try unplugging the dryer for a while. If the lock remains enabled, the control panel isn't communicating properly with the board. Either the panel will need replacement or the board itself.
    I hope this helps.
    Jun 16, 2013 | Dryers
    DLE7177RM dryer will not come on. I have 220 coming out of the wall.
    There can be many reasons why your dryer will not start or turn...
    The most common causes are the belt breaking or jumping off, or the motor going bad...
    Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
    Dryer Repair - The
    Dryer is not Turning
    Dryer Repair - The
    heatman101
    Dec 15, 2010 | LG DLE7177 Dryer
    We were just moved by a moving company and my dryer worked the day before they moved it. Now, my LG DLE7177RM won't power on at all. We had our maintenance come and check the outlet, that's fine, we bought...
    Sounds like damage was done to the control panel during the move. You will need a qualified LG tech to test the controls and see if the power button was broken during the move.
    Oct 03, 2010 | LG DLE7177 Dryer
    Lg Model DLE7177RM It turns on and the dials
    I have this dryer. They said fuse to motherboard, but had to replace entire motherboard. Cost to repair with part and labor approximately $250.00.
    Jul 30, 2009 | LG Dryers
    Need to initiate cleaning cycle
    to enter the cleaning cycle:
    Select the RINSE & SPIN button.
    Select Low SPIN SPEED'
    Select Warm/Cold WATER TEMPERATURE.
    Select the 2ND RINSE Option.
    Push the END of CYCLE SIGNAL button 4 times within 5 seconds to start cycle
    Jan 11, 2009 | Kenmore Elite HE4 Electric Dryer
    LG DLE2532W Electric Dryer doesn't allow adjustment of drying options
    it may be possible the contol is bad can you change the settings at all
    Feb 07, 2008 | LG DLE2532W Electric Dryer
    Dryers Logo
    Top Dryers Experts
    Richard Roth
    Richard Roth
