What doeas it mean DOS ftp session in binary mode?? and how I can do that please help
    Brigadier General:
  • 3,917 Answers
Yes you can transfer files using the DOS ftp commands. To know in details please go through the article mentioned bellow.
http://kb.iu.edu/data/acet.html
Let us know if you have something more to know else accept the suggestion.
Thank You for contacting Fixya.com
Posted on Jul 22, 2010
  • bits2009 Jul 22, 2010
    thanks for that,
    but can you tell me why whatever command I put in the ftp, command line in the cmd
    this message came to me eventhough me ftp server is connected
    Connection closed by remote host
    please help
Corrupt rar/winrar Archive
Maybe is uploading to the FTP site using ascii transfer type, once on the FTP connections, you should use binary type.
that is done with the command bin:
The following FTP Command will set the file transfer mode to BINARY (the binary mode transfers all eight bits per byte and must be used to transfer non-ASCII files). ) and display the information.
ftp> binary 200 Type set to I. ftp
May 06, 2015 | RARLAB WinRAR
I need help, my internet explora is not fonxoning
it depends on what operating system your using and how capable you are using DOS (command), in addition load my computer and where it says my computer in the address bar just type, http://www.google.com and search firefox or chrome.
right the dos way try this,
in run (or search) type command or cmd,
when it loads type c: \
this will take you to c:
then type this
ftp ftp.mozilla.org (you will be asked to login)
(user name anonymous and password as password)
Then type
cd /pub/firefox/releases/latest/win32/en-US
then type
bin
when switched to binary mode type
get "Firefox Setup 25.0.exe"
then after download is complete, (there is no bar and dos appears to be crashed but it's not just wait and then you'll get confirmation that the download is successful) type
quit
if for any reason it says connection timed out or failed, just type quit and start again (sometimes you have a few minutes as an anonymous user, so be quick) (ps your not hacking)
ok now goto mycomputer and select your hd (c:\) the firefox setup 25.0.exe file is now there, double click and install, congrats you now have firefox installed.
try it out and see if it works, if it doesn't get back to me.
ps type everything as is CASE SENSATIVE, ie Firefox not firefox!!
If FTP in dos(command) wont allow connections then you have an internet problem
All the best
Jul 31, 2013 | Microsoft Computers & Internet
My home built computer rig asus p5n-e sli has an issue where any downloaded large compressed file (say over 2 gigs) is "corrupted" upon decompression. CRC errors and such. I've run memory...
If you are attempting to open the file from a network / modem it is likely the network either is encountering collisions or other errors during the data transmission. Note: if the file is being sent through a session such as FTP or Telnet it is possible that it may not be sent properly. If the file is a text file, the file must be sent as either ASCII or TEXT mode. If, however, the file is a program or non-text file, it must be sent as a Binary file.
Oct 08, 2011 | ASUS Computers & Internet
How to get from dec. to binary
If you're already in decimal mode, press SHIFT BIN to switch to binary mode.
To convert a number from decimal to binary, press MODE 4 to switch to BASE-N mode. You'll find yourself in decimal mode. Enter the number to convert, press =, then press SHIFT [BIN] (the log key) and see the number in binary. To convert another number, press SHIFT [DEC] to return to decimal, enter the number, press =, then press SHIFT [BIN]. An analogous process works for hexadecimal and octal as well.
To return to "normal" use, press MODE 1 for COMP mode or MODE 2 for complex mode.
Mar 12, 2011 | Casio FX-115ES Scientific Calculator
Problem downloading files up to 100 mb
Well, here's a bit complicated, yet effective method that just might reduce your downloading headaches... Let's say you're connect to the Internet using a 28.8K modem and that your Internet service provider lets you telnet to their server. Of course, your provider's server can download files much faster, so the idea here is to download the file to their server at high speed, split it, and retrieve parts at the highest speed you can to your provider's server. Generally speaking, this method not only is a faster way to download files, but it is also a more reliable method since you'll be downloading many smaller files rather than one large file.
First, find out the FTP address of the large (larger than 16M for example) file that you want to download. For example:
ftp://ftp.x.com/bigfile.zip
Telnet to your Internet service provider's server.
telnet x.com
From within the telnet session, download your file to your provider's server. Following is a "screen shout" of a sample file transfer on an UNIX compatible server. Blue/bold text represents your input.
ftp
ftp> open ftp.x.com
Connected to ftp.x.com.
220 ftp x.cpm FTP Service (Version 2.0).
User (ftp.x.com:(none)): anonymous
331 Anonymous access allowed, send identity as
Password: my_address@x.com
ftp> binary
200 Type set to I.
ftp> get bigfile.zip
200 PORT command successful.
150 Opening BINARY mode data connection for bigfile.zip
226 Transfer complete.
ftp> quit
221 Thank you for using x.com! Once the file is download to the server, the next step is to divide the file into smaller pieces so that you will not waste too much time downloading should your Internet dial-up connection go down.
split -b 2000b bigfile.zip
You're almost there! Now simply log off from your telnet session and start downloading (from your provider's server to your computer) smaller files (not the bigfile.zip) which the above split command (on most UNIX compatible machines) created.
Once you have all the files, simply merge them and you got a good copy of the original bigfile.zip. If you're using DOS or Windows, you can merge files using the following command (assuming that bigfile.zip (16000 byte file) was divided into 8 2000 byte files named xaa to xah):
copy /b xaa xab xac xad xae xaf xag xah bigfile.zip
Don't forget to log back into your Internet service provider's computers and delete temporary files (bigfile.zip and xaa..xah) once you've made sure that your downloaded copy is in good condition. Doesn't sound like the above steps could make your downloads faster or more reliable? Well, in most cases it does; specially if the file you're downloading is rather large. The reason why this method could possibly be faster is because you can download files from your provider's computer to your computer faster than from most remote sites. Of course, the reason for reliability is that downloading many smaller files makes it possible to resume a download without wasting as much time as resuming a larger file download would.
************ALTERNATIVELY***********
You can use FRESH DOWNLOAD.Fresh Download is an easy-to-use and very fast download manager software that turbo charges downloading files from the Internet, such as your favorite freeware/shareware, mp3 files, movie files, picture collections, etc. Unlike any other similar utilities, this software is 100% free, no charges, no banners in the software (whichsteal your bandwidth), no spyware.
Apr 13, 2009 | Arris Touchstone 450a (CM450) Modem
Cannot upload pictures to an ftp site
You would open ports 20 and 21, and that would allow FTP transfer in passive mode. (Windows DOS FTP client does NOT do passive mode - so don't use that for testing)
Mar 18, 2009 | D-Link Xtreme N DIR-655 Wireless Router
FTP
In what way? FTP sessions are controlled by you and the input you place into the CLI (Command Line Interface).. Here is a page with the basics, on how to create a session and the commands to use to manipulate it:
http://www.cs.colostate.edu/helpdocs/ftp.html
DG
Dec 24, 2007 | Computers & Internet
SCP problem
What have you done to resolve this issue since your post? My instinctive knee jerk reaction is that the FTP format was incorrect. Meaning, an FTP'd file can be set for either an ASCII (7bit, 8th bit being used for error control or internationalization (extended character sets or codepages) OR a binary (all 8bits are significant) transfer. My guess is one of two items, either the wrong FTP parameter was supplied (or defaulted) in the transfer which corrupted the file, OR the FTP server re-interpreted the FTP file which stripped off some bits. Either way, you are left with a non-functioning card and a file that doesn't actually represent the original binary file. I wonder if you had previously set a management address to your SCP prior to this, or is this a newly powered up card? My first thought would be, if the card doesn't come out of "test" mode in one hour, I'd remove it, let it rest a few minutes, then reinstall. If the "test" led keeps flashing, I'd hook up your PC (and serial port) to atempt communication via the management address web interface(assuming you had set an IP earlier). If no communication occurs, I'd try to set an IP via the CLI, despite the "Test" flashing. Then attempt the web interface. The chances of this working are slim, but hey, you can't make it any worse. Otherwise, your only other option is to call Paradyne at 1-800-870-2221, (since they can burn you a fresh EEprom) ZT3000 "Beta tester of "0"s and "1's"
Aug 07, 2007 | Paradyne SCP 8417 (8417-b1-000)
Directions to use Casio FX-115W
This is described in the manual (link below) on page E-52 http://ftp.casio.co.jp/pub/world_manual/edu/en/fx-115ES_991ES_Eng.pdf Also see example #083 in the appendix : http://ftp.casio.co.jp/pub/world_manual/edu/en/fx-115ES_570ES.etc_Appendix.pdf
Jul 23, 2007 | Casio FX-115W Plus Calculator
Open Questions:
Which 5 Things missing your website? 1. Social Media Links Social media has become the foremost popular and best type of communication. With the recent announcement from Facebook that over two Billion individuals log in daily to use their website, it might be ludicrous to not faucet into this medium to achieve out to a wider audience vector-free-social-media-icons By using a simple to use social integration tool, websites will easily add this feature to share a message with their social circle quickly. 2. Clear decision to Action Buttons As shortly as you get a visitor to your website, it needs to be captivated to perform a relevant action. It may be a Call us Now button or a Sign-Up form for a free service trial, asking the user to act instantly. Netflix It should make sure that these buttons have the proper aesthetic attractiveness and appear at the correct time while not annoying the end-user. 3. Responsive web design The use of smartphone and tablets has quickly increased since 2012. Marketers corporations'and corporations'and firms} are currently paying shut attention to the present platform wherever fifty-eight of companies have a core mobile promoting team. responsive In such circumstances, a responsive web design is crucial to developing if businesses want to achieve profitable customers. A mobile-friendly website will permit you to compete together with your competitors and provides your business the boost to remain ahead. 4. Email marketing check-in Email marketing campaign could seem like an obsolete technique to stay up-to-date with your customers, however, of course, it can produce wonders for your business if used properly. email signup Placing an email subscription type will permit you to interrupt through the middle of promoting your services to an audience with revenue generating results. 5. Testimonials Word of mouth advertising is that the most credible means that of promoting your business. a region on your website containing remarks and comments of clients'the purchasers'the shoppers} you've got antecedently served will instantly gain the customer trust. test The client testimonials may be a way of gaining your website visitor trust by exhibiting a decent log of your past performance. confirm to focus on these reviews on your website somewhere close to your services section to realize effective results.
Feb 19, 2018 | Facebook Computers & Internet
Computers & Internet Logo
David Payne
David Payne
