Question about Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC
My windows installer registery is somehow missing files
  • 496 Answers
This error is caused by an Installation file that is called .msi or application is file that installs a program and it happen when that particular program is improperly installed. If you suspect such a software than you should remove it and to avoid such problems you should avoid other software running while installing a new software to be on the safe side.
Please take a backup of your Windows registry at first
To backup the registry go to Start>Run box or Search Programs and files> type Regedit. When the registry window opens click File>export and give the name to the file and select and remember the location and enter. This will take the back up of the registry.
Now obtain a good registry cleaning software. I recommend ReCure or registry Mechanic make sure the versions are the latest. One of the best Registry software is Uniblue Registry Booster. It takes registry backup automatically. These software should be able to fix your problem.
It is also recommended that you see the following link, This software can also make a difference to you
http://www.instant-registry-fixes.org/windows-repair-installer-configuration-information/
Good Luck!
Posted on Jul 27, 2010
C0000218 registery error
You missed the part where he said he has windows VISTA not xp! This link might help alot more:
http://windows.microsoft.com/en-us/windows-vista/What-happened-to-the-Recovery-Console
I'm having the same problem, i haven't solved it yet but I read this interesting thread:
http://forums.techarena.in/vista-setup-install/677924.htm#post3404664
Feb 17, 2013 | Dell Inspiron Mini 1012 Netbook...
Windows7 registery
Hi,Dear Friends..
Your win7 registery not repair i think some problem occur.
Flow instruction:-
1> Change you current windows7 cd. because i think some error obtain.
2> Another you DVD ROM lance week and not read CD properly.
3> Your Hard Drive create bad sector. When you install windows.
Solution:-
A> Used new windows7 CD.
B> Change DVD ROM Driver.
C> Change HDD Device Driver.
D> Change Install windows location.
Thanks...
Feb 15, 2013 | Toshiba Satellite Computers & Internet
Nntldr missing
NTDLR missing is the baseic directory that hold windows. You have lost this somehow, maybe a virus or similar.
What you now need to do, is obtain the Windows install CD, boot from it and allow it to get to the stage it looks for an existing copy of windows, perform a repair and reboot, this will retain all the files on the HDD
If this fails, then you will need to do a full install from scratch, as before, but the drive will need formatting and you will lose the files you have on the drive
(I suggest you see if you can borrow another computer, slave the hard drive to it and pull off the files you need before formatting it as decribed above)
Jan 29, 2011 | Computers & Internet
Error code in windows vista 64 bit ''0xc00000e9 - windows failed to load because the system registery file is missing or corrupt''
If it is a system registry error, boot up in safe mode and run CHKDSK/F this may find errors on the hard drive. To do this press Start and type CHKDSK/F into search box then run it.
You may have to purchase a registry utility.
Jan 11, 2011 | Computers & Internet
When i start my acer 5570z laptop error window appears, could not load or run c:/users/acer/local specied in the registery. make sure the files exists on your computer or remove the reference in the...
Might be caused by malware . Google malwarebytes download and run update then scan your system. Just post here if problem persist i would gladly help you.
Jul 24, 2010 | Acer Aspire 5500 5570-2609 Laptop
My window xp turn to slow
well thats windows problem, and the problem is normal, and its because to much uneeded files are still there in ur drive or in ur registery, taking memory and space, so get some registery cleaners progs (ccleaner), and clean all your old unneeded files.....
Apr 30, 2010 | Microsoft Windows XP Professional With...
I have to window xp pro x64 installations on the
you can delete one OS from registery.
go to my computer properties > Advance > startup & recovery settings > edit. here you can find two OS registery. now you can remove one OS registery.
Sep 10, 2009 | Microsoft Windows XP Professional
Running Windows XP Home, SP2, Thunderbird and the latest Firefox. Am getting the occasional error for True Vector Service when online and the application shuts down. I note that this is part of ZoneAlarm...
You can clear the registery files associated with this ZoneAlarm but if you do so you may happen to loos eyour internet connectivity altogether. My thought is that ZA is not at all harmfull so you try to install it again and you may evade this error. Sometimes it may slow down your computer but it can be recoverd by restarting the application. Rate me if it is helpful!!
Aug 19, 2009 | Zone Labs ZoneAlarm Pro 5 (1313618SF)
My OS Windows 7 can not Update
The problem might be becoz of service pack of windows 7. Please uninstall the currently installed service-pack and then try to update Windows 7.
Its highly advisable to clean system registery using any good system registery tool like cCleaner.
Please call me for further clarification.
Zulfikar Ali
09899780221
ali_zulfikar@yahoo.com
Feb 28, 2009 | Computers & Internet
Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC Logo
49 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
