Question about Brother LS2020 Sewing Machine
Bicor vx1005 ...thread keeps bunching
When I try to sew the thread keeps bunching up on the bottom of the fabric. I've also, had a problem with the thread breaking.
  • shamch Apr 28, 2008
    Thanks, I tried your suggestions, however, I still have loose threads on the bottom of the fabric. My machine has been unused for a few years so maybe that could be the problem, don't know. My bobbin case is not screwed in. I believe that is normal though.
  • cjnana Jan 22, 2009
    The stitches don't seem to pick up the bobbin evenly. The top stitch will be long and FINALLY a bottom stitch will pick up. It's like the bobbin isn't being picked up continuously. My machine is a bicor vx1005.
    Thanks,
    Cindi
Make sure that you have the top thread in all the correct positions. I missed two and had the same problem. When I rethreaded it my problem was solved.
Posted on Sep 06, 2010
  • Brother Master
  • 1,388 Answers
Ensure that all is clean and free of lint jams....now for tension troubleshooting .......
This solution is for tension problems...if you cannot form any sort of stitch, the issue is quite different, so please let me know if you need a different problem solved.....
It is quite long, but just work through each section in order.
The "knotting up" can reveal a lot. If you have loose threads on one side or the other, the tension on the opposite side will be the culprit.
QUICK SUMMARY FIRST:
Ensure sharp new needle,
Thread guides and Bobbin are Clean & Clear of lint
Set Top Tension to 4 ....then....
Balance Bobbin to suit.
TOP THREAD TENSION:
If the looping threads are on the underside as you sew, it is the top tension. Top tension ought to be between 4 & 6 (this variation to allow for the different weights of fabric in your
projects).
IS YOUR NEEDLE SHARP ?
If you are using a needle that has seen quite a deal of work, or you suspect it may be blunt, change it for a new one !
TOP TENSION & GUIDES:
Make sure that when you thread the machine the presser foot is up so the thread goes between the discs and not to one side, top tension between 4 and 6, and that you have threaded through all the guides, including the last one, usually on the needle arm, just above the needle clamp.
It may be there is lint trapped between the discs, this will keep them slightly apart and reduce the actual tension, sometimes dramatically.
If tensions appear correct, and the thread is definitely in the channel between the discs, but still too loose and looping, try raising presser foot and remove your thread.
Now, with a 2" (50mm) wide strip piece of fabric 8 - 10" (20 - 25cm) moistened with methylated or denatured spirit, gently insert the fabric strip and clean between the discs with
a see saw / to and fro action.
In the worst cases, gentle use of a needle to pick & remove the jam may be necessary, but be very gentle and make sure the tension is set at Zero and the presser foot is raised, (to
disengage tension plates).... do not gouge or score the plates, they need a polished surface to work correctly.
BOBBIN TENSION:
Far less common, but if the loose threads are on the top, it is bobbin tension that is loose, it too may have lint in the spring and be giving a "false" tension.
I would not recommend fiddling with bobbin tension without good reason, it may end up with missing small screws and spring pieces, however, you can take the needle plate off to clean
the hook race area (where bobbin case sits)
...this is just good housekeeping, my wife does this every time she replaces the bobbin....
just take it out and clean the bobbin case and the fixed metal hook race with a small brush to remove lint. If there is a significant amount of lint, use a vacuum and small brush to get the worst.
Then wipe all this area with a cloth or cotton bud (Q tip) moistened (not soaked) with methylated spirit, especially if there appears to be fine dirty deposits....oil and lint combine to conspire against you.
If it seems likely that you ......really ....do .....actually .....need .....to adjust the bobbin case, first check there is no lint trapped in the metal spring where the thread is tensioned.
TOP LOADER:
Drop-in Bobbin case will look similar to this image with the tension screw in the middle of the metalwork....
Bicor vx1005 ...thread keeps bunching - 4c76dc1.jpg ...the other screw at one end is holding it all together, so beware....it is not a tragedy to undo the whole lot and clean it, but very gingerly and lay the bits out in sequence and orientation, or you risk tearing your hair out !
FRONT LOADER:
....this is a bobbin case from a front loading machine and works in a very similar fashion to the top loader with drop in bobbin, again, if you dismantle it, take care so you can put it all
back properly.
165ca5c.jpg FINISHING UP
GETTING THE BALANCE RIGHT:
When you are certain there's no trapped lint in top tension or bobbin, set the top tension to 4 and the bobbin tension to a point where you just begin to feel resistance.
Try using good quality thread of contrasting colours so you can more easily spot the changes.
Set your zigzag to one width less than maximum (eg. 5 of 6 ...or... 4 of 5 etc) and sew a sample for a few inches and check the result.... adjust the bobbin tension screw very little at
a time, perhaps 1/16 of a turn.
You may find you are playing with this balance for some little while and if you are putting the needleplate on and off each time begin to think it cannot be correct to do this.....BUT....it is,
and eventually, you do get a "feel" for the correct tension and then it happens quite quickly.....as a user you won't be doing it very often unless there is lint built up (or are there small hands at work around the house !?!?!)
OTHER ISSUES:
If you live near the ocean as we do, salt air can play havoc with metalwork inside and out, so to help minimise this, keep a few small packets of dessicant (silica gel) in your machine
case....no case ? then make some sort of cover !
Same applies in any damp or humid environment, keep your machine dry and dust free.
Budget for a proper full service every couple of years (more often if heavily used) and if you don't use your machine for a few years, be aware that old oil will dry out and combining with
dust and form a "clag" like glue (another reason for some sort of cover, even a teatowel !)
FINALLY, A WORD ON THREAD:
If it is worth spending the time, energy and money on making something that you would like to give lasting enjoyment......use quality thread, .......it may seem to cost a little more at the
time, but the results, ease of use and added longevity will be worth the extra, and as a bonus, your tension troubles may be fewer and further between, because there is a more consistent diameter with good thread, and less compensating to be done by your tension plates and less thread breaks !
If you want any more help with this, just post back here, or, drop a line through the "Contact Us" page at www.bargainbox.com.au
Posted on Apr 24, 2008
  • Hassy
    Hassy Apr 28, 2008
    If you have looping underneath it can ONLY be your top tension at fault.......be very certain there is no lint jamming the top tension plates ajar, it does not need very much to cause trouble.
Make sure the bobbin is facing the rightt direction. The Bicor I have used has the thread coming off the bobbin in a clockwise direction. Check your manual, if you have one, and see which way the bobbin should go. It seems insignifigant, but it can really be an issue.
Hope that helps!
Posted on Oct 22, 2008
3 Suggested Answers
SOURCE: Bicor vx1005 ...thread keeps bunching
i need needle threder lever
Posted on Aug 10, 2008
Try a different bobbin. Look for one that is a little narrower. I had the same problem and changing to a narrower bobbin fixed it.
Posted on Mar 29, 2009
I NEED A BOBIN AND ALEAVER THAT RAISES THE NEEDLE FOOT
try these sites and see if they can help you,,you'll have to call or
email them
sewvacdoctor.com
a1sewingmachines.com
Jan 16, 2013 | Brother LS2020 Sewing Machine
Thread keeps bunching on the bottom of thick material
try a different needle
here's a link to a free manual from singer
http://www.singerco.com/uploads/download/1199_8770-efs.pdf
some machine can't handle thick fabric & some can
rethread the machine top & bobbin
clean under the needle plate & in the bobbin area
make sure the thread has not come off the thread take up lever
Aug 20, 2012 | Singer Curvy 8770 Electronic Sewing...
Thread keeps on bunching up on the bottom side of the fabric
try changing the needle
check the top thread tension to make sure it's not to loose
rethread the machine top & bobbin, make sure the bobbin is wound
correctly & inserted correctly into the machine
Jul 11, 2012 | Brother CS6000i Computerized Sewing...
Difficulty threading bobbin- thread bunches under fabric. vx1005
I would suggest to check the needle to see if it's damaged
also check to make sure the machine is threaded correctly,,that the thread is in every thread guide
also some sewing machine have a problem with the top thread coming off the thread take up lever
also I would check the bobbin area for lint or any loose threads
also check the top thread tension to see if it's set correctly
also the hook race cover & hook need to be taken out & cleaned & then put back in
some machine have had problems with the hook getting grooves worn into them & need to be fixed or replaced
Oct 08, 2010 | Brother LS-1520 Mechanical Sewing Machine
The tension is off ?? bottom thread bunches
Sounds like it could be! Probably worth trying to readjust it. Are you using a fine fabric too? That can cause bunching.
Apr 05, 2010 | Kenmore 15516 Mechanical Sewing Machine
How do you thread bobbin for Bicor VX1005?
Look through these threading guides for a Brother that has the same features. http://www.sewusa.com/Sewing_Machine_Threading_Diagrams.htm
The above site has a manual, but I not a threading guide. Unless it is the same as another model.
Mar 07, 2010 | Brother LS-1520 Mechanical Sewing Machine
Thread bunching underneath fabric on Bicor VX1005 mahine.
The impulse is to blame the bobbin, because that's where the thread bunches. But the problem is probably with the top thread tension. The tension is too loose, allowing the bobbin to help itself to all the thread it wants. Retrace the path of the thread from spool to needle and see if you missed anything. The instructions in my VX1005 manual are not clear. I had to try a couple of paths before I got it right. Make sure the spring in the tension disk setup is moving freely. You should feel a fair amount of resistance when you pull on the needle thread. Hope this helps.
Terry
Nov 11, 2008 | Bernina Activa 130
Jun 14, 2008 | Brother LS-1520 Mechanical Sewing Machine
Brother LS2020 Sewing Machine Logo
2,299 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
