The i key came off my laptop computer. How can I put it back on?
The ''i'' key came off my Fujitsu Lifebook laptop computer model A6120. How can I put it back on?
  • 2,069 Answers
Physically do you see any thing broken?
Please follow this help.
Regards
Posted on Jul 22, 2010
Fijustu ah530 corei 5 bios password
BIOS on a Fujitsu C-Series LifeBook b> Resetting the BIOS system of a computer can help revitalize the computer's usage. Oftentimes computers are "broken" when they are misconfigured in the BIOS menu of the computer before it boots up. When the settings are improperly selected, the BIOS prevents the computer from working properly. To get the computer back up and running again, the BIOS needs to be reset. The Fujitsu LifeBook C2111 has its BIOS system located on the motherboard beneath the keyboard.
Turn the Fujitsu laptop over with the computer powered off. Remove the AC adapter and push the battery release latch in and pull the laptop battery out of the Fujitsu. Remove the screw holding the hard drive in place and slide the cover off of the laptop. Remove the two screws underneath the cover that holds the hard drive onto its bracket. Slide the hard drive out of the laptop. Turn the computer back over and lay the screen down so that it is parallel to the surface on which the laptop is resting. Remove the small screw above and to the left of the keyboard with the Phillips screwdriver. Push the keyboard toward the screen until it disengages. Fold the keyboard over the screen and rest it there with the keys facing the screen. You will now see the motherboard of the Fujitsu C2111. Locate the small, round lithium-ion battery on the motherboard and remove it. This is the BIOS battery that stores all of the settings and password of the BIOS when the computer loses power. Hold the power button in on the computer to drain the BIOS system and leave the battery out of the laptop for at least 30 minutes. Place the BIOS battery back into the motherboard and reattach the keyboard. Tighten the keyboard screw that you removed earlier, and turn the Fujitsu back over and reattach the hard drive along with the covers for the hard drive and RAM. Push the computer battery back into place and attach the power cable to the computer. Turn the Fujitsu back on and the BIOS menu will be reset.
or b> Start the computer and press the "F2" key while the system boots, if the computer is currently off. If already on, restart the computer and press the "F2" key while the system boots. The BIOS setup utility will appear. Press the right arrow on the keyboard and scroll over to the "Exit" tab. Press "Enter." A drop-down menu will appear. Scroll down to "Default Settings" using the down arrow key and press "Enter." A dialog box will appear, asking if you are sure you want to load the default settings. Scroll over and select "OK" using the arrow keys and press "Enter." All BIOS settings will reset to the default value. Scroll back to the "Exit" tab using the arrow keys and press "Enter." Scroll down and select "Save Changes and Power Off." Press "Enter." The computer will save the default BIOS settings and power down. Fujitsu Lifebook T Series b> Restart your Fujitsu Lifebook T Series computer. Press "F2" as soon as the computer starts booting. Enter your current BIOS password if prompted. Use your right arrow key to select the "Security" menu. Use your down arrow key to select the password you want to reset. Press "Enter" to select the password. Enter the current password when prompted. Enter your new password or a blank password if you want to clear the password. A blank password resets the BIOS password completely, meaning you do not have to enter a password to enter the BIOS or boot your computer. Press "Enter" to save your password settings.
Repeat the process if you have multiple passwords set. Press "F10" to save all settings and exit the BIOS.
Jan 30, 2013 | Fujitsu LifeBook AH530 NoteBook
How to reset the user authentication password on fujitsu A6120
password authentication system please for fujitsu siemens S7110
Apr 16, 2012 | Fujitsu LifeBook A6120 Notebook
Hello, i have a Fujitsu A6120 laptop and the options for adjusting brightness (thru control panel and manual adjustment by key-function) are not working. the brightness is just set to maximum. I?d like to...
Either adjust them with your graphics cards control panel(right click desktop and screen setting should be there, or from the control panel)
or adjust it through the power options menu in control panel
Jul 10, 2010 | Fujitsu LifeBook A6120 Notebook
Need to reattach the W key on my Fujitsu Lifebook P7230
You may have broken a plastic "hinge", more like a tab or clip. Try taking it off again and examine the underside of the key. If it looks ok, try putting it back on. If a plastic tab/clip is broken on the left side, you should be able to go to a small computer repair shop and get a replacement key for it. That way you don't have to replace the keyboard.
Jan 04, 2010 | Fujitsu LifeBook P7230 PC Notebook
Touchpad stopped working on my Fujitsu lifebook
You need to re-enable it. Hold Fn and hit the F5 or whatever key is appropriately assigned to the touchpad. This should enable it for you.
Oct 19, 2009 | Fujitsu LifeBook A6120 Notebook
Computers & Internet Logo
24 people viewed this question
Alun Cox
David Payne
David Payne
