Question about Garmin GPS
My ? Nuvi 710 GPS froze. I restarted it , now all I can get is a blank screen with a black dot in the bottom left corner and a message saying press dot. Holding the off switch over to the left makes it restart but still goes back to the same screen Is there any way I can fix this?
My ? Nuvi 710 GPSMy ? Nuvi 710 GPS - icon1.png froze. I restarted it , now all I can get is a blank screen with a black dot in the bottom left corner and a message saying press dot. Holding the off switch over to the left makes it restart but still goes back to the same screen Is there any way I can fix this?
Posted on Nov 12, 2012
My nuvi 260w screen is black and "blinks garmin". If I touch the screen it does nothing but blink. Has anyone had this problem? Also, I have tried to hit reset and nothing happens.
Posted on Aug 10, 2008
How to calibrae my gps nuvi garmin 255????????????????
For the Garmin 2x5 series GPS
Calibrating the Screen:
1. Turn off the nüvi.
2. Hold the upper-left comer of the screen white turning on the nüvi
3. Release the power key when the Garmin screen appears.
4. Continue to hold the upper-left corner of the touch screen for 30 seconds until a white screen with "Press dot" appears.
Here are links to the manual for both the 255 and the 255W (wide).
I hope helped & good luck! Please rate my reply. Thank you.
Jun 30, 2011 | Garmin nuvi 255W GPS Receiver
When I turn on my nuvi 200 it says press dot. When I press the dot it just moves around the screen to different location.
To calibrate the touchscreen on your nuvi 200 series follow the steps below:
  1. Have the unit turned OFF and unplugged from power.
  2. Slide the power switch to the ON position and hold for about 45 seconds.
  3. A message will display on the screen: Press Dot.
  4. Once this message displays, release the Power button.
  5. Press in the center of the Dot.
  6. Keep pressing in the center of the Dot as it moves around the screen.
  7. Once this is complete, there will be a message: Calibration Complete.
  8. Touch Ok and the unit will restart.
The touchscreen will now be recalibrated.
*Note if unit is running software version 6.00 or newer you will want to follow steps from below.
To calibrate the touchscreen on your nuvi 205 series follow the steps below:
  2. Place your finger in the top left hand corner of the touch screen and apply pressure.
  3. Slide the power switch to the ON position. Once unit powers on release the power button.
  4. Hold pressure in left corner until the Press dot message appears.
  5. Once this message displays, remove your finger from the screen.
  6. Press in the center of the Dot.
  7. Keep pressing in the center of the Dot as it moves around the screen.
  8. Once this is complete, there will be a message: Calibration Complete.
  9. Touch Ok and the unit will restart.
//changed this line from 'solution1description.innerHTML' to use getElementById //to prevent FF warnings. They both appeared to work, but this is cleaner. solution = document.getElementById('solution1description').innerHTML; Last modified on: 09/30/2010
Oct 23, 2010 | Garmin nuvi 205 GPS Receiver
Friend has a problem with his Garmin nuvi: when typing the letter to the left appears. what can be done?
It needs to be calibrated
To calibrate the touchscreen on your nuvi 200W follow the steps below:
Aug 14, 2010 | Garmin nuvi 200W GPS Receiver
I cannot press H, O and V buttons in post code mode. different li
you will need to do a screen calibration. to do this.
press and HOLD the top left hand corner of the screen while sliding and holding the power switch in the on position. Hold bothe for about a minute and eventually a white screen will appear with a black dot which will say press here touch that dot and the following dots that appear until you get a message saying that calibration is complete.
you should no longer have that problem
Jul 08, 2010 | Garmin nuvi 205 GPS Receiver
Garmin nuvi 205, sometimes it won't respond to my touch. Sometimes when I go to give it a name or address it just keeps repeating a letter, "aaaa, or jjjj. then when I touch the botton to go back or clear...
Your touch display is shorting out....BAD
Replace Unit
BUT try this first:
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} To recalibrate the touchscreen on your nuvi 200 series follow the steps below:
To recalibrate the touchscreen on your nuvi 205 series follow the steps below:
Does this help? Let me know. Thank you...
Nov 03, 2009 | Garmin nuvi 205 GPS Receiver
My Garmin nuvi 200w behaves erratically until it has been turned on and warmed up for around 10 minutes. Before this time the touch screen may not work or when pressed respond as if pressed at another...
First make sure the batteries are good and at normal room temperature.
Second, based on your question your touch screen is bad or needs calibrating....
Then
Try to recalibrate your screen:
Sep 23, 2009 | Garmin nuvi 200W GPS Receiver
The screen on my Garmin Nuvi 200W won't respond. I tried the recalibration but the screen doesn't respond when I touch the dot. I also tried a hard reset and that didn't help either. Help please!
There is more than one calibration procedure, but for the 200 it is:
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} To recalibrate the touchscreen on your nuvi 200 follow the steps below:
If this doesn't work you have two choices
Buy a new one
Or
Send your in for repair. Go here for this option
http://www8.garmin.com/support/outofwarranty.html
Aug 23, 2009 | Garmin nuvi 200W GPS Receiver
Nuvi 750 frozen on prss dot screen
maybe a factory reset - but connect to computer and try to back up your stuff since it will erase it all.
Oct 20, 2017 | Garmin nuvi 750 GPS Receiver
I'm getting inaccurate letter entry on the letters I type. For example, when I type a B an M appears - I'm noticing it on the bottom row of letters at this time. Solution?
Are you sure you pressed the correct location on your screen???
If so, you may need to calibrate the screen.
Do this:
Dec 26, 2008 | Garmin nuvi 260W GPS Receiver
GPS Logo
804 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
