Question about Garden
Toro lawn mower wont start (super RECYCLER)1998 module. I have changed spark plug and air filter.have been using fresh gas from start of season. any thoughts of what my next step should be
  • 10,865 Answers
Hi. Get a can of starter fluid from your local auto parts store and a helper. Squirt a little into the air intake, start it and have your helper continue to squirt more fluid to keep it running until you clean the gunk from your carburator. J.
Posted on Jul 22, 2010
My toro super recycler bogs down while mowing. I have fresh gas, just changed the oil and filter. Any suggestions?
check and be sure the blades are sharp. if the blade gets a rounded edge it wont cut properly and will bog down trying to cut.
Aug 15, 2016 | Toro Power Lawn Mower
Will not start toro model143.026706
if it stopped running after hitting something with the blade check the key on the flywheel where it meets the crank
Jun 04, 2012 | Toro Power Lawn Mower
Toro recycler model number SR-21 S lawn mower wont start changed plug, filter, new gas. Mower ran for two lawn cuttings but seemed to overheat and choke out frequintly in high grass now it wont start at...
check your oil is it up to full, then I would check to see if you have compresson, pull your plug and roll over and feel with finger ,but don't touch spark plug wire or you will light up! next I would check for spark, then for fuel, make sure the carb is getting fuel,,,check your hoses and fuel cap and clean your carb and needle/seat and make sure gas will run through the fuel line. Also you could have sheared a flywheel key
the choke out you are talking about could of been a lean condition and smoked the eng rings
Good Luck compresson test should tell all 2StrokeJim
May 17, 2011 | Toro Lawn Mower With Toro Power Tools
I have a 22" self propelled toro recycler, never
did u turn it on its side? change the air filter. change the plug. turning it on its side could cause a fouling in the plug or air filter to fill up with oil and shoot out on the deck. Use Stabil in the gas in the off season.
Apr 28, 2011 | Toro Garden
I have a Toro Super Recycler Mdl 20033 ser 230000001 and up. Lawn mower will not start, there is no spark. New spark plug and fuel line. Change the magneto? Is this simple?
You may not need to change the ignition module. The "air-gap" on it may just need to be adjusted. That is, the distance between the pickup legs of the ignition module and the magnets integrated into the flywheel. You would have to remove the exterior cover and any sheet metal cowling (directs air flow off the flywheel around the engines cylinder). Then, the coil and flywheel should be visible. I use a standard business card as a gauge. Slide it between the coil legs and the magnet area of the flywheel. You should feel just a slight little rub. If it won't slide or the gap is large, no spark will be produced. You will have to loosen the screws holding the coil in place, double up the card. let the magnets pull the legs in against the card with magnets behind and retighten. Then recheck for spark. Post back if needed.
Apr 04, 2011 | Toro Power Lawn Mower
I have a Toro super recycler model 20017 with a tecumseh motor, model LEV120, spec 361541B has spark and is getting fuel but will not start any suggestions? Have already replaced coil cause previously had...
Make sure that the doggone brass bolt that holds the carb bowl on was cleaned as well. It is the main jet and has tiny holes that get clogged from evaporated fuel/varnish and debris (if no inline fuel filter is used). It has holes on the bottom and the smooth part of the sides...it needs to be clean and shiny! If all is well and the motor is an OHV, then maybe the valves need adjusting.
Sep 14, 2010 | Toro Super Recycler Super Bagger Lawn...
After priming starts, runs and stops
If you over fill the oil your mower will not start until you remove excess oil. This should be checked first, This is a much easier fix.
Jun 20, 2010 | Toro Garden
Toro super recycler mower will not stay running, has fuel and oil and air filter was just replaced
Try replacing the fuel and spark plug. Gas may be bad. Get some fresh from the station not from the can sitting in the garage.
Drain the fuel system and put the fresh gas in.
HTH
Good Day.
Oct 30, 2009 | Toro Lawn Mower With Toro Power Tools
Toro recycler will run until primed gas is consumed.
The problem is that the gas that sat in the carb all winter glazed it over and gummed it up. Begin by going to any auto parts store, like an aiutozone, and getting a bottle of carb. cleaner. Seafoam is one I use. Add it to your gas, one ounce per gallon of gas. Also, pick up a can of engine starting spray.
Remove the air filter and spray the engine starting spray into the air intake. Pull start the engine and give it additional squirts of engine starting spray until it runs smoothly.
May 30, 2009 | Toro Lawn Mower With Toro Power Tools
Garden Logo
244 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
